Shimano parts compatibility question
zaxatron
Postby zaxatron » Fri Sep 22, 2017 6:49 pm
Hi,
I have just joined the forum and am seeking some help and advice.
I am rebuilding my old Merida S3 bike and have the following parts:
Rear derailleur: Shimano RD-4601 GS
Front Derailleur: Shimano FD-4600 34.9mm clamp on
I pulled these parts out of another bicycle which was crashed in an accident in 2015 by a drunk driver, but the parts were intact except for me, the rider.
Now I discovered that the front derailleur will not fit on the seat tube of this bike frame because its diameter is 31.8mm, it is too big.
How can I fit this front derailleur? Can I get adapters for it or will the Shimano FD-4700 front derailleur 31.8mm clampon work with all my other 4600 series parts?
I also do have a Shimano FD-4503 31.8mm clamp front derailleur, but it is a 3 speed one. Can this be used with a 2 speed compact crank 50/34?
Thank you
Regards
Zaxa
Re: Shimano parts compatibility question
Postby Duck! » Fri Sep 22, 2017 9:44 pm
Visit your LBS, they should have some shims to space the 34.9mm clamp down to 31.8mm.
You cannot use the 3-sp. FD with a two-ring crank; the shifting guides on the inner cage plate to not align with the chainrings, so you end up with poor shifting and a hell of a lot of noise.
Users browsing this forum: newierider, outnabike, robbiepapenfus
