Torque wrench, which one
Neddysmith
Postby Neddysmith » Tue Sep 26, 2017 9:44 am
Hey Guys,
Looking at getting a torque wrench for when doing maintenance on the bikes, any recommendations?
I usually look at getting better tools as i find they last longer and prefer working with quality, however, i found these couple and was wondering your thoughts or recommend any others.
https://www.cyclingdeal.com.au/buy/bicy ... VZ-F33-031
https://www.cyclingdeal.com.au/buy/venz ... VZ-F33-055
Also what torque setting range would i require, this will effect my decision, but i would think a 1/4 torque qrench with about torque ranges would be sufficient?
Tim
Re: Torque wrench, which one
Postby Tim » Tue Sep 26, 2017 10:07 am
I think either one of those two torque wrenches should meet your needs. I have the same as the first one though differently branded.
I only bother using a TW on carbon parts such as headsets and seatposts for which the tool setting range is adequate. I'm not too sure how accurate these cheap tools are but I haven't broken anything yet and nothing has rattled loose. A drop of medium grip Loctite helps in some situations such as Shimano crank pinch bolts.
High torque applications such as pedals and cassette lockrings (usually 40nm) and all-metal parts can be tightened with regular tools and a deft touch ie. use a lever/spanner/allen key of appropriate length and leverage for the size of nut/bolt/screw or ring.
Tim
Postby Tim » Tue Sep 26, 2017 10:30 am
I'd choose the second and more expensive of the above tools.
It has finer incremental adjustment than the first choice.
Aussie Bruce
Postby Aussie Bruce » Tue Sep 26, 2017 12:49 pm
I would go the second one too
Both are well spec units I have done a calibration check on the second one for a mate and its bang on I have Warren and Brown units and can calibrate them myself so was very surprised at the price point
A lot of the top tools are made in Taiwan so I say go with it
Neddysmith
Postby Neddysmith » Wed Sep 27, 2017 9:01 am
Thanks guess, looks like ill be making a purchase and seeing how it goes.
Users browsing this forum: 49Vanguard, AndreB1972, Tequestra
