Garmin Varia Radar
- ComradeSpear
Garmin Varia Radar
Postby ComradeSpear » Wed Oct 25, 2017 3:53 pm
Anyone know?
- AUbicycles
- Site Admin
Re: Garmin Varia Radar
Postby AUbicycles » Wed Oct 25, 2017 5:40 pm
I will make a guess as I have used it. I can't judge whether the radar will be degraded from the jersey but the movement is likely to have an effect so it tracks and then looses an approaching 'object'.ComradeSpear wrote:Curious to know if the Garmin Varia radar will work if inserted into a jersey's back pocket instead of installing on a seat post... and obviously facing the right way in the pocket.
Anyone know?
On the seatpost or with a more stable mount, I feel it will operate better (it isn't cheap either).
Postby mikgit » Sat Oct 28, 2017 11:05 pm
however, then you woudn't be getting use of the flashing ability, which I think...well I hope... works well (different flashing as cars get closer).
Postby Discodan » Sun Oct 29, 2017 10:35 am
- ComradeSpear
Postby ComradeSpear » Sat Mar 10, 2018 10:13 am
It also successfully paired and worked with Garmin Edge 25 & 520 as well as the Garmin Fenix 5 but not the Xplova 5 Evo.
I tried testing the radar detection by placing the unit vertically but didn't sit well in the jersey pocket. Unfortunately, the supplied mount can't be rotated to support a vertical configuration. It'd be nice if it could as it's a bit wide and chunky when fitted with my skinny seat post. I wonder if there's a mount or a hack that would allow me to test the vertical configuration, any ideas?
Postby mikgit » Sat Mar 10, 2018 7:31 pm
Postby BugsBunny » Mon Mar 12, 2018 2:51 pm
(PS. I'm not dissing it, but genuinely interested).
Postby mikgit » Mon Mar 12, 2018 7:52 pm
The biggest use more me is a couple of sections of road (old highways), that are long DH stretches where you're cruising at40km/h and you can't hear cars coming behind, it prepares you for a passing car instead of being surprised.
Another style is roads with a wide verge, but it rough/littered so its far better to ride in the smooth worn part of the road, but I wouldn't normally due to being smashed by a truck or something, also quite country roads where I'm riding anywhere on the road, gives you heaps of warning, well before you can hear the cars, to figure out where you want to be on the road.
it doesn't replace your senses, just adds to them. That and the variable flashing as car approaching, I think thats handy too.
Postby warthog1 » Tue Apr 27, 2021 8:19 pm
If it stops me being surprised by passing cars I'll be happy.
I have trouble hearing them.
Postby hamishm » Wed Apr 28, 2021 2:06 pm
The Varia is awesome for that. I find it particularly useful when you're out on country roads not expecting a car and might not hear it over the wind.
Postby warthog1 » Wed Apr 28, 2021 3:32 pm
Yeah I am always on country roads out of town.
Will be nice to get some warning.
- Mububban
Postby Mububban » Wed Apr 28, 2021 4:10 pm
Get some of these, or DIY some - best thing ever:
So simple but so effective.
Postby warthog1 » Wed Apr 28, 2021 5:00 pm
Never seen em.
Cheers.
- AUbicycles
- Site Admin
Postby AUbicycles » Thu Apr 29, 2021 7:24 am
- Daus
Postby Daus » Thu Apr 29, 2021 5:42 pm
- chucknitro
Postby chucknitro » Thu Apr 29, 2021 7:50 pm
I use bone conduction headphones so you can still hear everything else normally.
The latest Garmin Varia (RTL515) can be connected to your headunit by ANT+ and your phone via bluetooth at the same time. On your phone run the Varia+ app which provides the beeps on detection of a vehicle and when it's "all clear". Link your headphones and you can get unmissable beeps.
You do need to alter the "Battery Optimization" to ensure android does not stop either bluetooth or the Varia app.
- MichaelB
Postby MichaelB » Fri Apr 30, 2021 11:15 am
+1
When I tested one as part of the 520+ review, for those quiet roads, especially when you get absorbed in your own thoughts, it was great.
In regular traffic, the usefulness was reduced either somewhat or heaps, as it goes off all the time.
It'd be great if it had the capability of muting the function easily on the head unit, so you can easily turn it on/off depending on where you are riding.
Postby warthog1 » Fri Apr 30, 2021 1:29 pm
Will use it with my edge 1000 head unit.MichaelB wrote: ↑Fri Apr 30, 2021 11:15 am
+1
I think I will be relying on the visual warning more given the audio doesn't appear to loud at all on it.
Will see how it goes. I am not known for my ability or prowess with electronic gizmos so I don't expect to be able to mute or unmute quickly even if it is possible with the head unit.
Will see how useful it is, as I won't be spending my time staring at the Garmin either.
- queequeg
Postby queequeg » Fri Apr 30, 2021 4:05 pm
It does, at least on my Edge 530. I now have a visual overlay alert only, no audio. Yes, you have to navigate into the radar sensor to change it, but not really a huge deal.MichaelB wrote: ↑Fri Apr 30, 2021 11:15 am+1
Postby hamishm » Sat May 01, 2021 5:47 pm
But will not catch your attention, you have to be monitoring it. It doesn’t compare to the Varia.
I find the beeps from my Edge 830 loud enough.
Postby warthog1 » Sat May 01, 2021 6:06 pm
Yeah I still have an Italian road bike mirror somewhere.
It was good but you need to be looking in it.
Bit if a pita to set up though.
Hopefully my Edge 1000 is loud enough too then.
- elantra
Postby elantra » Sun May 02, 2021 12:20 pm
Yeah I love my mirror BUT the mirror tends to be sometimes a bit useless in certain situations.
Like going down some of the steep hills on narrow sh##y roads where there are so many vibrations and potholes that you struggle to be able to look at the mirror and see. And the numpty drivers expect you to occupy a slender margin of this “road” at 55km/hr and they expect to be able to pass you even if the posted speed limit is only 60km/hr.
Also mirrors can be a bit useless at night when some vehicle approaches either with massively excessive illumination power or no lights on at all
Recently I have done a few rides with a bloke who uses one of these Garmin Varia devices and it was quite an eye-opener.
He was almost always aware of cars approaching from behind earlier than me with my mirror.
I am very impressed, and the only thing holding me back from getting one is the cost and the fact that my GPS device that I am used to is not a Garmin (it’s a Bryton)
Postby warthog1 » Sun May 02, 2021 12:48 pm
The Bryton rider 750 apparently supports the varia radar.
Don't think the other Brytons do, but I'm no expert.
https://www.bikeexchange.com.au/blog/br ... ter-review
- elantra
Postby elantra » Sun May 02, 2021 8:54 pm
Thanks, prompted by this thread I have done some digging for more info and, hey presto, it looks like the new Garmin Varia RVR315 only needs a compatible Smartphone to do its job, via the specific Garmin app.warthog1 wrote: ↑Sun May 02, 2021 12:48 pmThe Bryton rider 750 apparently supports the varia radar.
https://buy.garmin.com/en-AU/AU/p/6690 ... 0-02253-00
Users browsing this forum: am50em, piledhigher2
