On mine, when I check on the Mac App it shows the correct version (1.1.25.636). On the iOS App it shows 1.1.25.6. Strange.li2099 wrote:I've just tried the latest firmware update for the Fly6CE again.
It says DSP firmware: 1.1.25.6
Is that the latest as on Cycliq: 1.1.25.636
https://support.cycliq.com/support/solu ... t-firmware
New Fly6 CE and Fly12 CE Camera's
Re: New Fly6 CE and Fly12 CE Camera's
Postby simonf00 » Fri Jun 29, 2018 1:58 am
- AUbicycles
- Site Admin
Postby AUbicycles » Fri Jun 29, 2018 5:32 pm
Postby Jmuzz » Sat Jun 30, 2018 3:08 pm
If you read config.txt from the SD card you will see the full number in there.
Postby li2099 » Wed Jul 11, 2018 3:15 pm
- Drizt
Postby Drizt » Wed Jul 11, 2018 3:18 pm
- Drizt
Postby Drizt » Tue Jul 17, 2018 10:56 am
Are you having the same issues (GPS) when using the Fly12CE ?
https://www.youtube.com/watch?v=5g6juJ5SkzM
Postby dmwill » Tue Jul 24, 2018 10:21 pm
Camera lens is all fogged up and there is condensation over the LEDs. Interestingly enough my friend had the same issue a week prior.
I'm guessing our's are both from the bad batch with the dodgy seal (we got ours from the same store, maybe a few months apart).
I recall having to register my unit and serial when I setup the phone app - I wonder if Cycliq ever thought of informing customers who may have the bad batch or if they are just waiting for people to complain?
Postby dmwill » Wed Jul 25, 2018 2:10 pm
The quality control isn't quite there in my opinion with Cycliq products (I've had 2 warranty replacements on my older gen 2). But to Cycliq's credit they sort out warranty issues rather quickly!
One minor annoyance with the velcro straps is the rubber backing - the longer strap is folded in the box, when you unfold it, the rubber backing has a tenancy to stick together and tear.
- Drizt
Postby Drizt » Wed Jul 25, 2018 2:12 pm
I'm thinking about getting a GoPro Hero 6 and extended battery. To my surprise, there isn't many viable extended batteries that are waterproof.
- jaseyjase
Postby jaseyjase » Wed Aug 29, 2018 2:26 pm
Saddle rail mount and the cycliq adapter works well as previously mentioned, however im running an ass saver so i used a 3D printed bracket insteadtomee wrote:are there any good mounts for under the saddle?
i dont have much seatpost real estate because im a shortarse.
if you have a bit of room to install the mount, you should be ok.
Postby li2099 » Sat Sep 01, 2018 10:30 pm
Gonna contact Pushys to warranty it.
Really don't want to ride around without one.
- AUbicycles
- Site Admin
Postby AUbicycles » Mon Sep 03, 2018 4:21 am
The corrected versions have a slightly different feel to the rubber and a better fit. Strangely, in many many months since riding the replacement, I have not had a single ride with heavier rain.
Until you get it sorted, I was actually able to keep the rubber seal open (with a rubber band) and allow the moisture to dry over a few days... after which the unit continued to work. That could be a temporary solution... If Pushys are slow.. although they are actually your first point of contact, the next option is Cycliq.... and they are usually fairly swift.
Postby Jmuzz » Mon Sep 03, 2018 8:33 am
Postby li2099 » Mon Sep 03, 2018 10:15 am
- jaseyjase
Postby jaseyjase » Wed Sep 05, 2018 12:15 pm
im using VirbEdit, and i can import and edit ok, but it fails to export.
anyone else have similar issues? fixes?
- AUbicycles
- Site Admin
Postby AUbicycles » Wed Sep 05, 2018 6:34 pm
- jaseyjase
Postby jaseyjase » Wed Sep 05, 2018 10:14 pm
Turns out i hadnt updated the software like i thought i hadAUbicycles wrote:On the mac - quicktime is basic but still (should) allow you to trim and export in various resolutions. The best case scenario is probably getting VirbEdit to work than get something new - I would check the version, try a clean install and also test various simple exports and see if you can work around the problem.
Now on 5.4.2
exports fine
- AUbicycles
- Site Admin
Postby AUbicycles » Thu Sep 06, 2018 1:07 am
- jaseyjase
Postby jaseyjase » Thu Sep 06, 2018 1:20 am
AUbicycles wrote:My suggestion for the next technical problem jaseyjase will be to see if the computer is plugged in!
Postby bella26 » Fri Oct 26, 2018 9:45 am
- AUbicycles
- Site Admin
Postby AUbicycles » Thu Nov 01, 2018 6:10 am
Link and process description: https://support.cycliq.com/support/solu ... fbclid=BNABattery Charge Bug - Fixed
Users have reported an issue where the Fly6 CE battery incorrectly appeared to be full, with the charging light turning green before the device is fully charged. This firmware update fixes this bug, so users should experience an increase in the battery life of their device if previously battery life was not as expected.
IMPORTANT: as this is targeting an issue around battery performance, the process for this firmware update is different to previous updates. Please allow extra time as the device will need to be fully charged and fully discharged for the firmware update to be complete.
Other major updates:
Added Footage Lock function similar to the Fly12 CE. Footage Lock can be activated by holding the Q button for 2 seconds during video recording.
HomeSafe mode has been adjusted to give greater recording time.
Improved recording quality and battery life.
Postby jasonc » Sun Nov 04, 2018 8:35 am
Same thing happened to my first ce. Replacement has been fine in the rainli2099 wrote:Well after yesterday's wet ride back from work, I noticed my Fly6CE has the same fogged up lens as others.
Postby jasonc » Sun Nov 04, 2018 8:36 am
Use smart converter first? Btw - can I have a copy of your 3d printer file for the fly6ce mount please?jaseyjase wrote:Any recommendations for editing software for Fly6CE?
- queequeg
Postby queequeg » Sun Nov 04, 2018 11:11 pm
Can confirm. I rode to work on Thursday with the camera running in 1080p@60fps, without any lights running. When I got to work, 90 minutes elapsed time, it was down from 100% battery to 34% remaining, which is just terrible. I did the firmware upgrade, by which time my Fly6 was up to 50% charge for the ride home. Rode home with same camera mode, then turned on the lights to run it totally flat as per the instructions before recharging.AUbicycles wrote:New firmware for Fly6 CE - to solve (mainly ?) charging issues where a full charge is indicated before the unit is correctly charged AND to increase the runtime of units.
On Friday morning, I rode to work with camera in the same mode as Thursday. Roughly the same ride time, maybe more because after 5 days of riding my leg was pretty tired. Anyway, checked the battery level when I got to work and it was on 74%! That is a pretty massive improvement. I'd the issue went far deeper than just the light turning green too early. Since my camera is left on the charger overnight, I'd say that when the green light comes on, the camera stops charging the battery or something.
Either way, this means I can run the camera to and from work without a recharge (finally!).
Next issue is to get myself a decent seatpost go-pro mount because the velcro mount is too floppy and the camera bounces around. My old Garmin VIRBs had rock solid footage on even the worst of Sydney' potholes roads, but the Fly6CE mount is rubbish.
Postby caneye » Mon Nov 05, 2018 12:57 pm
you can try splicing up an unwanted tyre tube and wrap it around the seatpost. Doesn't have to be too long. Just extend a little wider than the velcro strap so that it appears neat & tidy. Cable-tie one end of the tube to prevent it from coming undone.queequeg wrote: Next issue is to get myself a decent seatpost go-pro mount because the velcro mount is too floppy and the camera bounces around. My old Garmin VIRBs had rock solid footage on even the worst of Sydney' potholes roads, but the Fly6CE mount is rubbish.
The rubber tube will absorb some of the vibration from the seatpost to minimise the Fly bouncing around but more importantly, stops the the Fly from rotating around the seatpost <-- I hate it when that happens!
Users browsing this forum: chalkie, find_bruce
