Help with new road tyres
Dudeman
Postby Dudeman » Mon Dec 18, 2017 12:23 pm
Hi guys,
I've been running the Gavia Race 1 25mm tubeless tyres that cane with my TCR but got a large gash on the rear.
Im going to change both tyres to either 25mm again or 28mm.
I don't want to spend $100 each at this point so was wondering what are some good tubeless options (25 or 28) that are no more than $70 each?
Any advice appreciated!
Lan Wing
Re: Help with new road tyres
Postby Lan Wing » Mon Dec 18, 2017 4:33 pm
I put Schwalbe pro1s on my TCR on removal of the gavia. Around 5,000km with zero punctures on the gavials and only changed them as I flattened the profile of the rear using it on my trainer when laid up with an injury. The Pro1s are allegedly the same 25mm as the gavias, but are actually about 3mm wider. Hence running a lower, more comfortable tyre pressure.
I think I paid $70 or maybe $80 at the LBS but can be had cheaper online.
Mububban
Postby Mububban » Tue Dec 19, 2017 11:57 am
How have you guys found the Gavia tubeless tyres compared to other tyres you've used before for grip and comfort etc?
Lan Wing
Postby Lan Wing » Tue Dec 19, 2017 3:33 pm
Sorry, I can't comment on that as the TCR was my first roadie, so nothing for comparison. As the gavia got older the grip dropped off a bit, but this was only noticed as the rear locking a bit under panic braking. (Which fortunately I don't do very often.)
In very unscientific comparison, the Pro1 is more comfortable, (and grippy I think), but my 2cents worth is really only worth 1.5 in this instance.
sammutd88
Postby sammutd88 » Sun Jan 21, 2018 12:04 pm
As far as tubeless, Schwalbe Pro One or Vittoria Corsa Speed. Hutchinson make some models as well. There aren't that many choices for high performance tubeless tyres.
Users browsing this forum: opik_bidin
