Tread peeling off new Michelin pro4 service course
Postby eeksll » Sun Feb 11, 2018 10:32 am
My gp4000s tyre had a hole blown in it from a punctured tube. Keen to try the first different tyre and then notice this.
- uart
Re: Tread peeling off new Michelin pro4 service course
Postby uart » Sun Feb 11, 2018 4:44 pm
I've never seen that before on a new tyre, looks like a manufacturing fault to me. Definitely return it if you can.eeksll wrote:Anyone had this before? Common issue?
BTW. The gp400s probably had damage to the casing that allowed the tube to "escape" and blow up. It's really unusual for it to happen the other way around, for a punctured tube to blow the hole in the tyre.
Postby eeksll » Sun Feb 11, 2018 8:51 pm
unfoprtunately I got it second hand here so no returning.uart wrote:I've never seen that before on a new tyre, looks like a manufacturing fault to me. Definitely return it if you can.eeksll wrote:Anyone had this before? Common issue?
I have not had time to properly investigate/look at the blow out. But I suspect your correct here. I found the puncture on the tube but after aligning it with the tyre, I couldn't really see anything on the tyre. New tube in, got home and repaired the flat tube.
Went and put that repaired tube back in the tyre (I prefer to ride on a patched tube and carrying a unblemished spare tube). Pumped up and then a few mintues later another puncture at a different spot but could clearly see a "ripped" tyre where the air was coming out.
- 10speedsemiracer
Postby 10speedsemiracer » Mon Feb 12, 2018 1:44 am
I've never seen it on bike tyres, have actually experienced it on a car (track car).
Postby eeksll » Mon Feb 12, 2018 12:37 pm
- biker jk
Postby biker jk » Mon Feb 12, 2018 1:38 pm
My brand new Michelin tyres never had a waxy coating like that depicted in your photo.eeksll wrote:I suspect it is new. The waxxy coat is still all over the tyre.
Postby Hergest » Mon Feb 12, 2018 2:23 pm
- uart
Postby uart » Mon Feb 12, 2018 2:50 pm
- 10speedsemiracer
Postby 10speedsemiracer » Mon Feb 12, 2018 7:15 pm
I thought this as well...uart wrote:Could have been a bad batch or it could have been badly stored. Either way though, I'll bet that the secondhand seller knew that they were "off" and was looking for a mug to offload them to.
Postby eeksll » Mon Feb 12, 2018 10:10 pm
10speedsemiracer wrote:I thought this as well...uart wrote:Could have been a bad batch or it could have been badly stored. Either way though, I'll bet that the secondhand seller knew that they were "off" and was looking for a mug to offload them to.
tempted to buy a service course tyre to see. Also wandering if I should use the other on the front since its got the same waxxy substance and in general all round appearance as the one in the photo except tread isnt coming off.
- uart
Postby uart » Mon Feb 12, 2018 10:49 pm
As long as the fault doesn't involve the casing then yes it should be safe to use the other one on the front. Run it for a while and keep an eye on it in case it also starts delaminating. But that type of fault is more likely to progress slowly rather than sudden catastrophic failure.eeksll wrote:10speedsemiracer wrote:I thought this as well...uart wrote:Could have been a bad batch or it could have been badly stored. Either way though, I'll bet that the secondhand seller knew that they were "off" and was looking for a mug to offload them to.
Postby eeksll » Sun Feb 18, 2018 7:50 pm
Postby Farmer Elvis » Sun Feb 18, 2018 7:57 pm
Users browsing this forum: Amazon [Bot]
