Hey all,
I picked up a fixer upper vintage mountain bike, Shimano SIS 5 Speed (3x5) with the old friction shifters seen here: https://ssli.ebayimg.com/images/g/CS4AA ... s-l640.jpg.
I bought some 7 speed ST-EF51 shifters from ebay thinking the cassette was a 7 speed, would they work with the 5 speed derailleur?
Also, it appears they're fake. Does anyone know if counterfeit gear will still work the same-ish? Anything is better than the rusty old friction shifters.
Upgrading old SIS 5 speed with 7 speed shifters?
- find_bruce
- Moderator
Re: Upgrading old SIS 5 speed with 7 speed shifters?
Postby find_bruce » Tue Apr 10, 2018 1:20 pm
There was a small difference in spacing between 5 & 7 speed- 5 speed is 5.3 mm while 7 speed is 5 mm.
The ST-EF51 is an index shifter, & while the difference means it is sub-optimal, if you have already spent your money, you might as well hook it up & see if you can get it to work.
As for fake, its a lottery - might work, might not, only one way to find out
- Duck!
Postby Duck! » Tue Apr 10, 2018 1:32 pm
The indexing won't work nicely due to the shorter gear stops, and will get progressively worse further across the cassette as the discrepancies accumulate. Just chuck a 7-sp. freeheel cluster in place of the 5-sp.
- find_bruce
- Moderator
Postby find_bruce » Tue Apr 10, 2018 1:37 pm
That's the joy of 5 speed duck - set it up on 3rd gear & the indexing only has to work for 2nd & 4th - 1st and 5th are covered by the limit screws
- 10speedsemiracer
Postby 10speedsemiracer » Tue Apr 10, 2018 5:54 pm
Can you not do a return/trans dispute via eBay, i.e. the item wasn't what it purported to be? Or contact the seller, and indicate you want to return them as not suitable/not as advertised....if the seller is a long-term eBay presence with a lot of feedback, they will care about negative.
- 10speedsemiracer
Postby 10speedsemiracer » Tue Apr 10, 2018 6:03 pm
Oh and those shifters you linked to as being the originals aren't friction, they're early-gen index. Just replace them with a newer equivalent, like :
which are available online for $20-30, but LH shifter (friction) is separate usually. SJS Cycles (UK) have them, plus they're freely available on eBay.
- Duck!
Postby Duck! » Tue Apr 10, 2018 7:05 pm
What gives you the impression the shifters are fake?
- Duck!
Postby Duck! » Tue Apr 10, 2018 7:07 pm
Still doesn't address the fact that the index stops are shorter than the sprocket spacing, and will still accumulate the out-of-whackness at each shift.find_bruce wrote:That's the joy of 5 speed duck - set it up on 3rd gear & the indexing only has to work for 2nd & 4th - 1st and 5th are covered by the limit screws
Postby twowheels » Tue Apr 10, 2018 7:47 pm
My question also.Duck! wrote:What gives you the impression the shifters are fake?
- 10speedsemiracer
Postby 10speedsemiracer » Tue Apr 10, 2018 8:11 pm
I was also wondering....twowheels wrote:My question also.Duck! wrote:What gives you the impression the shifters are fake?
Postby pteknae » Sat Apr 14, 2018 11:02 am
Thanks for the help guys, I guess it'll probably work (just) but wont be worth the effort for sub-optimal performance.
I actually just tightened the cable using the threaded tension-er on the derailleur and it shifts great now.
The print on the numbers and logo is faded and not clean or crisp, and the orange gear indicator is a poorly stuck on sticker, which ever Asian sweat shop worker put it on didn't even stick it on properly, its got a crease in it and is wonky.Duck! wrote:What gives you the impression the shifters are fake?
