Heart rate monitor
Heart rate monitor
Postby GraemeT » Thu Apr 12, 2018 7:39 am
Do any of you have a cycle computer with a heart rate monitor the one I have is a real pain when it needs re pairing . Does anybody have a similar problem. It does hook up but more often than not wont hook up I go through the trouble shooting guide that is in the phone app but still a hit and a miss.
Re: Heart rate monitor
Postby Neddysmith » Thu Apr 12, 2018 8:48 am
In saying this i have a garmin watch which works off a heart rate monitor and it works fine, and i also have a Bryton cycle computer which can pair to the heart rate monitor but i havent tried it yet.
Postby Noviss » Thu Apr 12, 2018 7:30 pm
Postby mikgit » Fri Apr 13, 2018 1:56 pm
Postby madmacca » Sun Apr 15, 2018 1:34 pm
ANT+, BLE and wifi all work in the same broad 2.4 GHz band, and can cause some interference.GraemeT wrote:Hi All
If you are having trouble pairing, try shutting down the Bluetooth on your phone, and shutting down or moving out of range of your wifi (especially if you use a wifi range extender).
- Duck!
Postby Duck! » Sun Apr 15, 2018 8:59 pm
And as above, make sure you're well clear of any other ANT+ or Bluetooth sensors when pairing, otherwise the computer will pair to those instead.
Postby djw47 » Wed Apr 18, 2018 4:28 pm
Postby AlanAtom » Sat Apr 21, 2018 9:59 am
..how accurate is the Garmin watch HR monitor? I have a Fitbit Charge 2 and it is inaccurate, the readings are generally way lower than actual, e.g. on my rides it says my max HR is around 110 when it should be around 170 to 180. However, when I'm not cycling it is generally accurate. And yes, like you I find my Wahoo chest HR monitor cold to put on in winter. If I don't wet the contact pads, they give intermittent readings.djw47 wrote:I used to hate the HR with the chest strap - it was cold to put on in the winter and not very comfortable for the first while so I never really got into it. I've got a Garmin watch now though with HR transmitter that hooks up to my Edge 510 and does the job perfectly, so much easier and literally never misses a beat.
Postby mikgit » Sat Apr 21, 2018 11:06 am
On another note, one feature I was really looking forward to was the temp function, I was dubious as to how it would work on the wrist (edge 1000 works fine)...and I was right, it's complete garbage, shouldn't even be a feature, grrrr
Postby madmacca » Sat Apr 21, 2018 1:20 pm
I think DC Rainmaker reports vibration from the handlebars often causing issues with wrist based OHR. If you want to avoid using a chest strap with a Garmin Edge, the Sosche Rhythm may be a better option (still OHR, but moving it away from the wrist helps considerably).mikgit wrote:Yeah I jsut bought a new garmin watch with wrist monitor... y to see how accurate it is, just wearing around I think its OK (my regualr HR is lower than I thought)...but will have to do some testing with my other watch or cycle computer to check it.
The temperature sensor on the watch is really intended to calibrate the altimeter, not to tell you what the ambient temperature is. Although it is reasonable if you mount the watch on the handlebars rather than your wrist.
Postby mikgit » Sat Apr 21, 2018 2:24 pm
I still dont get the temp thing for the altimeter, how it going to calibrate it when its so far out, like todays run, the air temp was 7 or 8, but the watch was saying 20 something, so its not body temp, its not ambient...but i guess its is the temp of the air at the sensor...
- foo on patrol
Postby foo on patrol » Sun Apr 22, 2018 8:25 am
Foo
Goal 6000km
- Tim
Postby Tim » Sun Apr 22, 2018 9:31 am
My experience too but I buy the even cheaper eBay straps for about $7.00.foo on patrol wrote:With the straps, I won't ever buy the genuine Garmin one. Mine lasted only 12mths and crapped itself and at $80 (at the time) I wasn't in a hurry to get one. I picked an Ebay one up for $29 delivered and that was 2yrs ago and it's still working well.
Foo
They work fine for between 1 and 2 years for me.
I reuse the Garmin sensor and just replace the straps.
Postby mikgit » Sun Apr 22, 2018 11:23 am
Postby djw47 » Mon Apr 23, 2018 3:31 pm
Seems very accurate. I've sat and counted my HR manually and it's identical to the value on the Garmin. Not sure about when I'm riding but the HR recorded does seem to go up when my effort goes up and vice versa.AlanAtom wrote:..how accurate is the Garmin watch HR monitor? I have a Fitbit Charge 2 and it is inaccurate, the readings are generally way lower than actual, e.g. on my rides it says my max HR is around 110 when it should be around 170 to 180. However, when I'm not cycling it is generally accurate. And yes, like you I find my Wahoo chest HR monitor cold to put on in winter. If I don't wet the contact pads, they give intermittent readings.djw47 wrote:I used to hate the HR with the chest strap - it was cold to put on in the winter and not very comfortable for the first while so I never really got into it. I've got a Garmin watch now though with HR transmitter that hooks up to my Edge 510 and does the job perfectly, so much easier and literally never misses a beat.
