Will a 20 x 1.50 / 2.10 replace a 20 x 1.50/1.75 tube.
IamGroot
Postby IamGroot » Sun Apr 15, 2018 8:17 pm
Will a 20 x 1.50/2.10 replace a 20 x 1.50/1.75 tube.
Having trouble finding the thorn proof tubes in the 20 x 1.50/1.75 size with the car valve for the dogs trailer.
Re: Will a 20 x 1.50 / 2.10 replace a 20 x 1.50/1.75 tube.
Postby Duck! » Sun Apr 15, 2018 8:38 pm
Yes.
IamGroot
Postby IamGroot » Sun Apr 22, 2018 7:25 am
Thanks and managed to buy a pair of these gel fitted heavy duty thorn resistant tubes from Woolies.
https://imageshack.com/a/img921/7047/egIVQu.jpg
Postby bychosis » Sun Apr 22, 2018 7:54 am
It seems your replacement exceeds the specs of the original. Min width 1.50 for both. Max width 2.10 for replacement vs 1.75 currently. Because they are suited for a larger width they will probably have more rubber and be thicker to allow more stretch. As you are buying slime filled tubes I’m guessing that weight isn’t an issue! The thicker tubes will probably also be more robust Which is good for puncture protection.
Bunged Knee
Postby Bunged Knee » Sun Apr 22, 2018 8:59 am
IamGroot wrote:Thanks and managed to buy a pair of these gel fitted heavy duty thorn resistant tubes from Woolies.
Woolies don't sell Slime tubes but I think that you bought it from Big W as it do sell these tubes. :)
IamGroot
Postby IamGroot » Fri Jun 15, 2018 6:49 am
Woolies, Big W same place.
Mugglechops
Postby Mugglechops » Fri Jun 15, 2018 8:23 am
I have been looking for a slime filled 20in tube. Currently running a 1.50 tube in a 2.8in tyre so a 2.10 will work far better.
Users browsing this forum: Jmuzz, Scott_C, splash_dad, tomness
