Bike Lights
warthog1
Re: Bike Lights
Postby warthog1 » Mon Sep 03, 2018 8:15 pm
No mate. Definitely the luxos u.
It is left well behind for beam spread by even cheap led battery lights.
The philips saferide is way better as a shaped light for spread.
You can have the luxos if you want. PM me a postal address and I'll send it to you.
Scintilla
Re: Bike Lights
Postby Scintilla » Mon Sep 03, 2018 11:23 pm
Meh! Nup. I'm fine thanks; have the IQ-X now and the wife likes her new Luxos U.
BTW, has the Phillips Saferide been upgraded or something. Described by many as a great light, spoilt by an average housing and inadequate mount. Last I looked it was only 80 lux. My new IQ-X is 100 lux, and has an excellent fork-crown mount..... right where I want the light to be.
MattyK
Re: Bike Lights
Postby MattyK » Tue Sep 04, 2018 9:14 am
Scintilla wrote:Meh! Nup. I'm fine thanks; have the IQ-X now and the wife likes her new Luxos U.
Numbers are one thing, actual results are another.
Philips no longer make bike lights. The design was sold to Spanninga, a similar model (same optics, new body and Li battery) is now sold as the Axendo model. But claiming 60 lux/300 lumen (Philips was 80/270)
http://www.spanninga.com/products/headl ... do-60-usb/
There's an 80 lux e-bike version but needs an external battery.
Lezyne do a StVZO model which looks very interesting but I don't know much about, and of course isn't sold in Aus.
https://www.lezyne.com/product-led-perf ... 0stvzo.php
Beam width would be the interesting one. 80 lux, 290 lumen claimed (very similar to the Saferide)
Other cutoff beam battery powered lights:
Garmin Varia
Specialized Flux (Elite and Expert)
Knog - not familiar with this, lens optics not reflector: https://www.knog.com.au/blinder-mob-stv ... =knogcomau
Something cheap maybe worth throwing a lobster at to try:
https://www.banggood.com/XANES-XL05-Ger ... 78385.html
Lupine SL A - looks OK, very wide, VERY bright beam, not the most even beam though. https://www.lupine.de/products/bike-lig ... ights/sl-a
ironhanglider
Re: Bike Lights
Postby ironhanglider » Tue Sep 04, 2018 10:55 am
This thread is an interesting example of YMMV.
Some prefer to use dynohub lights because of their reliability and not having to charge lights.
Others have stopped using dynohubs because of a lack of reliability.
There are those praising the german style optics (such as with the Luxos U) because they limit light to where it is useful and doesn't 'waste' light by shining it where it isn't needed, yet that is not suitable for others.
FWIW I am a dynohub user (with a Luxos U). I like the reliability, but also carry little lights as spares. I recently had to ride home with no tail light because the wire broke, and of all the rotten luck I had moved my spare onto a new bike and forgotten to move it back, so I had to buy another spare (which it turned out wasn't charged). A little bit of electrical fettling and it is doing the right thing again.
As for the german style optics of the Luxos U, I can see where both warthog1 and Scintilla are coming from. The light beam has a very distinct horizon and I set mine up as per the Peter White pictures with the beam at about knee hight at 50m. With the bike upright there is a really wide field of view and it is terrific for the long straights of the unlit paths that I use. However when the bike is cranked over into a tight turn, the horizon means that there is no light shining in the direction where you want to go. I have often considered getting a helmet mounted light with a tight beam to specifically deal with these situations, but for me it is only a minor irritant at low speed, rather than a major issue at high speed. Standing the bike up in the corners like a wannabe motoGP rider does work to some extent but it is hardly worth the effort.
BTW warthog1, I'd be interested in the Luxos U, because it works for me, but it would be even better with some sort of gimbal arrangement.
Cameron
warthog1
Re: Bike Lights
Postby warthog1 » Tue Sep 04, 2018 9:14 pm
ironhanglider wrote: With the bike upright there is a really wide field of view and it is terrific for the long straights of the unlit paths that I use. However when the bike is cranked over into a tight turn, the horizon means that there is no light shining in the direction where you want to go. I have often considered getting a helmet mounted light with a tight beam to specifically deal with these situations, but for me it is only a minor irritant at low speed, rather than a major issue at high speed. Standing the bike up in the corners like a wannabe motoGP rider does work to some extent but it is hardly worth the effort.
Cameron
I agree with the horizon, yes it is a problem for me on the downhill corners.
I disagree with the width of the beam however. Not deliberately trying to be diagreeable, but my biggest hazard on the commute is roo strike. Happened once and several other near misses.
I want a beam that sprays light everywhere so that I can see movement in the scrub off to the side of the road.
The luxos has a great beam for seeing where you need to go on the road.
The cut off is a problem when turning and the beam, whilst perfectly adequate for illuminating your path of travel on the road, is a bit narrow for seeing off to the side of the road in my use.
Tim
Re: Bike Lights
Postby Tim » Tue Sep 04, 2018 10:07 pm
warthog1 wrote: ...my biggest hazard on the commute is roo strike. Happened once and several other near misses.
I have the same problem at night and can add to the list rabbits, wombats, wallabies and in recent years whopping great almost horse sized Sambar deer.
The deer have become a serious problem for all night time road users around here. Not to mention the damage to native flora and farmer's diminishing grass and hay reserves.
A couple of years back I bought a helmet mounted My Tiny Sun Head 1000 Pro lamp.
German made, expensive, but very good quality.
The little lamp supplements a powerful bar mounted light (a bigger 2600 My Tiny Sun product). Mounted on my head I can look into and around corners and most importantly scan the surrounding paddocks and bush for grazing and browsing wildlife.
It's quite incredible the number of animal eye-shine reflections I pick up on night rides.
Interestingly, some spider's eyes glow quite intensely. Just as well, I haven't been attacked by a giant hairy Trianchoola yet, I pedal real fast away from them. :D
rangersac
Re: Bike Lights
Postby rangersac » Wed Sep 05, 2018 3:06 pm
Dynohub user here, started out with a SP PV-8 and now on a SON, and have used B+M Cyo Premium and now an IQ-X paired with a Hermanns H-Track with no reliability issues whatsoever. I agree with what's been pointed out with regards to cornering. Here in Tassie, Pademelons are almost perfect night camouflaged moving bike traps that emerge from dark places, especially when you are descending at 50kph on unlit windy roads. For additional ommph I have a Cateye Volt300 on the bars which supplements the IQ-X very nicely, has an excellent mount that can be switched between steeds in 30 seconds, and the ability to replace the battery. A Fly 6 on the seatpost completes the setup.
Helmet mount I find it hard to go past Ay-Ups. Yes they are not the most powerful units out there and are an investment but my original battery and light set is 10 years old and still going strong, and they provide great support
De Rosa Macro | Intense Primer | Wayward Cape York | Banshee Spitfire
Bunged Knee
Re: Bike Lights
Postby Bunged Knee » Thu Sep 06, 2018 11:08 am
Arrgh, my eyes,where am I?
Not good to use this light and not recommended it.
Re: Bike Lights
Postby Mulger bill » Thu Sep 06, 2018 8:32 pm
Second the helmet light option for peripheral assistance.
It's also a pretty good deterrent against side street pullouts at night...
madmacca
Re: Bike Lights
Postby madmacca » Fri Sep 07, 2018 1:51 pm
Bunged Knee wrote:Arrgh, my eyes,where am I?
Especially not recommended for a helmet mount.
vodafone_au
Re: Bike Lights
Postby vodafone_au » Sun Sep 09, 2018 3:28 pm
Front: Cateye Volt 800 (handlebar mount) and Moon Comet-X (fork)
Rear: Moon Comet-X (helmet) and Topeak Tail Lux (seatpost)
All of them are USB rechargeable except for Topeak one (this uses the coin battery).
I'm using the multiple lights in case one fails without noticing (this happened to me before) and to be seen easily both during the day and night time. I spent total $170-ish on the lights but definitely worth it.
Mububban
Re: Bike Lights
Postby Mububban » Mon Sep 10, 2018 1:05 pm
vodafone_au wrote:Front: Cateye Volt 800 (handlebar mount) and Moon Comet-X (fork)
I'm the same, on dark early morning rides I've got my Fly6 and Fly12 but I also use some Lezyne lights as backup just in case they die for whatever reason (which I've had before, the Cycliq products are not without their problems).
They're also useful if I'm planning an all day ride and want to maximise battery life for video recording, I'll disable the lights on the Fly cameras and use these little lights for maximum run time.
Users browsing this forum: Thoglette
