Does your MET helmet flip over?
- sogood
Postby sogood » Thu Oct 30, 2008 5:18 pm
I am wondering if the same happens with your MET helmet and whether this is a common issue with MET's design and a potential design fault? As a reference, my Giro helmet does not do that.
- Moderator
Postby timbo » Thu Oct 30, 2008 6:01 pm
You guys are experienced cyclists, so would know all about fit etc.
Perhaps you are going so fast that us mere mortals would never understand the problems you face.
Perhaps you could spend some time in the BNA wind-tunnel to work out the airflow problems.
- sogood
Postby sogood » Thu Oct 30, 2008 6:19 pm
Postby rustychisel » Thu Oct 30, 2008 6:43 pm
Mine is a 2006 model Ippogriffo.
- il padrone
Postby il padrone » Thu Oct 30, 2008 7:13 pm
- sogood
Postby sogood » Thu Oct 30, 2008 7:37 pm
All very logical potential solutions. Tried all that but no help.il padrone wrote:My old MET helmet never had such a problem. The rear 'nape' strap tensioning system holds it in place very well on its own. Maybe tighten this a bit. And set the side straps so the front retention straps are shorter than the rear ones. This will pull down more on the front of the helmet and prevent it rising above your forehead.
My suspicion is that the MET Scatto is relatively shallow and the rear tensioning system does not go low enough, resulting in this behaviour. I should take a look at some of the other MET models next time I visit a LBS. maybe there's a difference b/n the Scatto and others in the range.
- mogwaiboi
- twizzle
Postby twizzle » Thu Oct 30, 2008 9:08 pm
Postby b4igo » Thu Oct 30, 2008 9:14 pm
Now this begs me to ask, how tight should you have the straps done up? If I pull the strap vertically below my chin, I can fit two to three fingers between my chin and the strap. Maybe its a bit loose?
I'll try the adjustments suggested above.
Now, after trying my helmet on again, and having ridden home from work tonight, this begs me to ask another question. How often do you wash your helmet? ewww
- Bnej
Postby Bnej » Thu Oct 30, 2008 9:34 pm
Take the whole thing with you in the shower every now and then. I also pull the pads off and put them through the washing machine.b4igo wrote:Now, after trying my helmet on again, and having ridden home from work tonight, this begs me to ask another question. How often do you wash your helmet? ewww
The Fox Flux is the most secure helmet I've used BTW, once it's on it doesn't like to come off. Not a road helmet at all though.
- sogood
Postby sogood » Thu Oct 30, 2008 9:36 pm
As for washing... Just walk into your shower with it on top once a week and shampoo.
Postby b4igo » Thu Oct 30, 2008 9:45 pm
Tightened the straps a bit, but I can still flip it. I dunno, maybe we have odd shaped heads.sogood wrote:The straps should be snug to ensure your protection cap stays in place. But it shouldn't strangle you along the way.
hahahaha. I think I'll wait til noone else is home before I try that. I already get bemused looks, what with the lycra, jersey, gloves, arm warmers, shoes, ...As for washing... Just walk into your shower with it on top once a week and shampoo.
- sogood
Postby sogood » Thu Oct 30, 2008 10:01 pm
Well, the problem is that there are quite a few of us who have this problem. I strongly suspect there's a basic design issue with that particular model/s. If the numbers come to bear, I may even question Standards Australia about their test result. A helmet that flips over should not have received approval from them.b4igo wrote:Tightened the straps a bit, but I can still flip it. I dunno, maybe we have odd shaped heads.
No joke really. Shampoos are usually neutral and would not damage the polystyrene base material of our helmets.hahahaha. I think I'll wait til noone else is home before I try that. I already get bemused looks, what with the lycra, jersey, gloves, arm warmers, shoes, ...
Postby b4igo » Thu Oct 30, 2008 10:13 pm
You could well be right. I might even pop over to the LBS tomorrow and take a look at a couple of other brands. Its the store I bought the helmet from, so will be interesting to see what they have to say.sogood wrote:Well, the problem is that there are quite a few of us who have this problem. I strongly suspect there's a basic design issue with that particular model/s.
- tatt2
Re: Does your MET helmet flip over?
Postby tatt2 » Fri Oct 31, 2008 10:06 am
A lady in our riding group has this problem with her Met helmet ,she just thought it was her..will mention this thread to hersogood wrote:A fellow club member observed over Sun coffee that his MET helmet flips over easily to expose his forehead even when done up tightly. Since, identical issue was confirmed with mine and Mikebyte's MET helmets. This is potentially a serious issue as a properly designed and fitted bike helmet should protect the forehead foremost in the event of frontal impact. A helmet that easily flips up would not protect the forehead properly. And IIRC, bike helmet testing specifies that helmets should not flip over when fitted.
I like poetry, long walks on the beach and poking dead things with a stick.
- Hebden
Postby Hebden » Fri Oct 31, 2008 10:36 am
The Estro is under crash replacement at the moment but I will test it when I get it back. I hit the back of my head in the crash.
For those of you that don't notice you helmet, Met or other, moving upward with a light push under the front, where do you feel the pressure? Is the chin strap holding it down? Or is it pushing at the back of your head?
- MichaelB
- sogood
Postby sogood » Fri Oct 31, 2008 2:45 pm
Just as well it doesn't move around when riding regularly. The issue raised here relates to a gentle upward push at the front. And as one can imagine, a helmet that flips on gentle contact is not going to be a protective one.Hebden wrote:...although it fits nicley and doesn’t move around while I ride I can easily flip it upwards at the front. So I voted yes.
- twizzle
Postby twizzle » Sun Nov 02, 2008 9:42 am
Tried my other helmet (a 'Tec') and it's far more secure and quite difficult to rotate backward. And it's a cheaper helmet.twizzle wrote:MET "Testagrossa" (what a name) - even holding the straps tight, far tighter than I could ever ride with, I can rotate the helmet backward over the head without much effort. Never moves under normal usage... and I'll compare to my 'Summer' helmet when I have a chance.
