Z-Plus Bike brand
uart
Re: Z-Plus Bike brand
Postby uart » Sat Sep 29, 2018 9:07 am
JFAR96 wrote:In terms of fit, its quite interesting because I've ridden just about 1000k with that setup with no apparent issues but a mate of mine said the saddle looks too high when I was riding it (as my hips were moving) so I've started moving it down incrementally. I find the angled saddle much more comfortable, my understanding is that saddles have always been flat due to UCI's 2 degree limit (which has now been changed to 9). However it's possible that I've just had to angle it down like that because my seat post is too high. I agree the bars need to be angled up I didn't notice that until I looked at the photo strangely however I do like the bars low so will probably get a longer and negative stem on there as I have a long reach.
Regarding the saddle angle. Yeah some people like them pretty flat and others like them angled a bit, but yours seems quite extreme at what looks like about 30 degrees to me. With such an extreme saddle angle you don't really have a well defined saddle height, because if you slide even slightly forward or slightly rearward then it changes the effective height significantly.
The other issue with such a "slammed" riding position (high seat and low bars) and extreme saddle angle is that it puts way more weight on your arms and shoulders compared to a more level saddle and less slammed position. Essentially what happens is that your arms are constantly fighting the tendency to slide forward.
I'm not sure if you've ever ridden a bike with a more level setup to compare, but my arms and shoulders would be screaming at me after 15 minutes on that bike.
JFAR96
Postby JFAR96 » Sat Sep 29, 2018 2:28 pm
uart wrote:I'm not sure if you've ever ridden a bike with a more level setup to compare, but my arms and shoulders would be screaming at me after 15 minutes on that bike.
Yeah, I think dropping the seat post and angling the saddle up would be a good idea. The slammed setup works quite well for me, I usually ride about 30k spending a fair bit of time in the drops and haven't noticed any discomfort.
adam0bmx0
Postby adam0bmx0 » Wed Oct 10, 2018 3:24 pm
Have you tried a magnet on the 'carbon' tubes?
We all know what the answer is if the magnet sticks.
uart
Postby uart » Wed Oct 10, 2018 4:15 pm
adam0bmx0 wrote:Have you tried a magnet on the 'carbon' tubes?
Only if it's steel under there though. I'm pretty sure however that it's either carbon or aluminum, and a static magnet wont test that.
MichaelB
Postby MichaelB » Fri Oct 12, 2018 8:34 am
Every time I see that setup, I shudder. It's all sorts of wrong, but if it works for you, great !!
What's the latest re the 'resto' that you were planning ?
Users browsing this forum: P!N20
