E Bikes in the late 1800s
Postby ldrcycles » Fri Oct 12, 2018 5:26 pm
Stumbled across this gem while searching Trove today, a tandem e-bike made in 1897! The technology has improved a touch since then, for starters modern e-bikes don't weigh TWO HUNDRED AND NINETY FIVE KILOS :shock:
Bottom half of the 3rd column-
1897 tandem e-bike
foo on patrol
Re: E Bikes in the late 1800s
Postby foo on patrol » Sat Oct 13, 2018 3:40 am
:lol: :lol: :lol:
Foo
Goal 6000km
Postby find_bruce » Sat Oct 13, 2018 6:28 am
Who would want to be a wheel builder to carry 295kg + 2 riders.
I wonder if you could use the battery to make it easier to push it uphill after the riders got off & walked, remounting for a scary descent with ineffective brakes
Tamiya
Postby Tamiya » Sat Oct 13, 2018 9:54 am
Sounds like it's built to be a record maker/breaker? Geared to 120" & meant to go 35mph for an hour on zinc-carbon primary cells (aka "Super Heavy Duty" single use batteries today).
Probably needed to be a tandem for pilot to steer & first engineer to throw the switches.
Amazingly it ran, given that it was built by BMC at the Humber motorcar factory in Coventry... it'll be using LUCAS ("PRINCE OF DARKNESS") electrics :D
