MIPS helmets
MIPS helmets
Postby TeVoRo » Wed Nov 07, 2018 11:10 am
Love to know everyones opinions on MIPS helmets. Are they worth the extra money?
I'm currently using a basic helmet that came with my bike. I would say around the ~ $30 - $40 mark?
While it does have the Australian Standards safety sticker on it, I sometimes wonder if I do take a tumble, would it provide sufficient protection.
Oh I ride on bicycle paths and the occasional road cycling on a flat bar roadie. + some weekends on MTB trails on a hardtail.
Re: MIPS helmets
Postby cogs19 » Wed Nov 07, 2018 11:28 am
It's a good question that I would suggest can only be answered if you have an accident and your helmet strikes something with any appreciable force.TeVoRo wrote:Hello,
I have a MIPS helmet. I like the helmet as it is comfortable and has good coverage - but this would be true even if it was non-MIPS. I suppose you pay for the extra protection afforded by MIPS (if you believe the research). Whether that research is sound or just a veiled marketing ploy to get you to pay more is the question. If you search online there'll be differing views on the value of a MIPS enabled helmet.
I paid extra for MIPS because I do a fair bit of MTBing and have a high-ish risk of coming off. Whether it will make any significant difference I really couldn't say.
Re: MIPS helmets
Postby human909 » Wed Nov 07, 2018 12:32 pm
With no real comparison testing nor anything known about the type of impact it is REALLY hard to say. We have threshold testing of helmets but that is about it.TeVoRo wrote:Hello,
Helmets vary significantly in strength, protection and behavior. And falls vary too. Eg a full face MTB helmet that is non MIPS vs a road bike MIPS helmet. If you dive jaw first into a rock I know which one I would want. Plenty of non MIPs hipster type helmets with more solid outer may also offer better protection some types of impacts against a roadie helmet that is more holes than foam.
Short of comprehensive testing from multiple types of impacts (like car impact testing) it is mostly just guess work.
Also to note that MIPS is a propriety and licenced name. Other helmets may offer the same or better multi-directional protection without being called 'MIPS'.
Re: MIPS helmets
Postby human909 » Wed Nov 07, 2018 12:48 pm
But there is some testing here, though it would be nice to see some more rigorously written up testing.
https://www.iihs.org/iihs/news/desktopn ... han-others
MIPS helmets are in the top ranks....
Re: MIPS helmets
Postby Calvin27 » Wed Nov 07, 2018 12:59 pm
I've had the unfortunate pleasure of breaking 3 helmets. Helmet 1 was a $50 bell cheapie, helmet 2 was a $120 lazer, helmet 3 is a high end kask. None of them are MIPs but they all saved my head and the foam split in all of them taking the load. Head had zero injuries but the neck and other bits copped it fairly bad in 2 of the crashes.TeVoRo wrote:Love to know everyones opinions on MIPS helmets. Are they worth the extra money?
My current helmets consist of a mtb non-mips and a road bike mips. Comfort wise, the mips is nice as it offers some rotation but it does get stuffy in the heat.
General consensus is all helmets do a good job of protecting you in most cases the more you pay, the more holes you get - simple as that.
Cushy dirt bike
Very cushy dirt bike
Bike crushed by car (RIP)
No brakes bike
Ebike
Re: MIPS helmets
Postby Jmuzz » Wed Nov 07, 2018 1:03 pm
I think it is mostly just a good marketing drive to turn a basic design feature which any $10 helmet can have into an overhyped trademark.
The concept is just that it allows the helmet foam to slip around more, which means less torsional forces at some angles.
However put your hand on top of scalp now and move skin around, it already has movement right?
Bicycle helmets are also soft foam and very thin plastic which will rip apart before the twisting forces to your scalp will be significant.
By all means get a MIPS logo helmet, it will probably be the best fitting most comfortable one. But wouldn't be replacing perfectly good helmets just to have it.
Re: MIPS helmets
Postby Jmuzz » Wed Nov 07, 2018 1:08 pm
Yep and big holes are what add the cost. Because big holes need reinforcement inside the foam to add strength because thin struts of foam are too weak. They can also need multiple foam densities since foam in a thin strut needs to offer the same compression as 10x the foam in a holeless section.Calvin27 wrote: General consensus is all helmets do a good job of protecting you in most cases the more you pay, the more holes you get - simple as that.
Big holes are great in out summer climate though and make helmets much more comfortable.
A bit too cool in winter, but can adjust heat with a cap or over cover.
Re: MIPS helmets
Postby human909 » Wed Nov 07, 2018 2:05 pm
I agree with your comments regarding marketing. But I'm not sure about your other comments regarding torsional forces. I believe there is a decent amount of legitimate academic research showing the dangers of torsional forces during head impacts. That said has any research been done into the relative risk likelihood of those torsional forces in a real impact? I'm not sure.Jmuzz wrote:I think it's just a gimmick, though the internal plastic cage is the better design for manufacturing anyway and was being done before "MIPS" trademark marketing.
But like yourself I'm not about to grab myself a fancy 'MIPS' helmet. My regular one serves it's primary purpose as a fine protection device perfectly.
Re: MIPS helmets
Postby Calvin27 » Wed Nov 07, 2018 2:15 pm
I did a bit of research into this is some detail and concluded that the benefits are there, but hardly groundbreaking. As a result, I'd go MIPS if it were available, even at a slight premium, but would not go out of my way or discount a helmet simply because it doesn't have MIPS. Number 1 factor for me is still how the thing feels on my head.human909 wrote:That said has any research been done into the relative risk likelihood of those torsional forces in a real impact? I'm not sure.
Cushy dirt bike
No brakes bike
Ebike
Re: MIPS helmets
Postby human909 » Wed Nov 07, 2018 2:57 pm
https://www.sporttechie.com/mammut-laun ... l-impacts/
That helmet looks pretty impractical for my needs. But hey it is MIPS!
(Most climbing helmets are built to be a fair bit more durable than that. That thing barely looks like it would survive transport into many destinations. Plus many of the associated sports can be a bit more rough on your helmet.)
Re: MIPS helmets
Postby TeVoRo » Wed Nov 07, 2018 4:21 pm
So... that said, does that mean a $20 KMart helmet is sufficient for a casual cyclist?
No need to get a $100 helmet.
Calvin27 wrote: I've had the unfortunate pleasure of breaking 3 helmets. Helmet 1 was a $50 bell cheapie, helmet 2 was a $120 lazer, helmet 3 is a high end kask. None of them are MIPs but they all saved my head and the foam split in all of them taking the load. Head had zero injuries but the neck and other bits copped it fairly bad in 2 of the crashes.
Mate, lucky you were not seriously injured in those falls!
Re: MIPS helmets
Postby Calvin27 » Wed Nov 07, 2018 5:00 pm
Dude, I get seriously stuffed up two of those falls - about 3 months off 'real' riding. My head was ok though. Funny thing is the $50 helmet was a head dive after the mtb gave out straight into an arrow shaped rock (you can't make this stuff up) split the helmet but head was ok.TeVoRo wrote:Lots of good points!
Cushy dirt bike
No brakes bike
Ebike
Re: MIPS helmets
Postby human909 » Thu Nov 08, 2018 11:39 am
Yes pretty much, if it is comfortable and fits your other needs. Ask yourself what your risk profile is and what sort of riding you will be doing. There is a big difference between cruising around the inner city or around bike paths and road cycling at 35kph (or MTBing). For me whatever is comfortable and cheap. I'll save my money for stuff with more tangible benefits.TeVoRo wrote:Lots of good points!
-Remember your best protection is not taking a tumble.
-Second best is knowing how to tumble and not hit your head.
-Your helmet (and your skull) is your last line of defense if you don't achieve the previous to points.
I wear helmets in many of my sporting activities and I have never had a head strike or broken one in a fall. (Including a ~7m rock climbing fall where I inverted Damn glad to be wearing a helmet in that fall, but my natural instinct to tuck and protect my head meant no head strike, if I had rag dolled then it would absolutely have been a rear head strike.)
- Mububban
Re: MIPS helmets
Postby Mububban » Sat Nov 10, 2018 5:11 pm
Any helmet sold in Australia must comply with minimum safety standards so yeah, a $20 helmet from K-Mart will protect your head to minimum standards.
What you get for more money is:
- more stylish
- more comfortable/much better fit
- better ventilation
- more research and development to give you even better protection than the minimum required
I needed a replacement road helmet after getting hit by a car and my head hitting the pavement. The current model of the helmet I needed to replace now has MIPS, so I got it. After getting concussion, and for the same price as the first gen with no MIPS, why not try it out?
Well, hopefully I'll never prove the effectiveness of MIPS because my head won't hit the ground again
Re: MIPS helmets
Postby Jmuzz » Wed Nov 14, 2018 4:42 pm
The Kmart will likely be better in a crash.TeVoRo wrote: So... that said, does that mean a $20 KMart helmet is sufficient for a casual cyclist?
But it will be hotter (not a bad thing in winter), look more dorky, heavier (won't feel it on head), less adjustable.
- AUbicycles
- Site Admin
Re: MIPS helmets
Postby AUbicycles » Thu Nov 15, 2018 4:18 am
The principle is that with a impact, your brain has velocity and bangs against the inside of your skull. The MIPS system with the tethered cage is a type of suspension to allow your head to ‘more naturally’ roll inside the helmet during impact and provide better deceleration and through this it is suggested a better protection against brain damage.
As a licensed system it is more expensive so for some brands you can get the same helmet with or without MIPS.
It is hard to say definitively that any helmet is good or bad because every crash scenario is different with velocity, direction, surface type and hardness. In some circumstances MIPS enhanced helmet could be better and in others it may not be (for speculation, if it leads to a neck injury from the twisting).
- Mububban
Re: MIPS helmets
Postby Mububban » Thu Nov 15, 2018 12:20 pm
Why would it be better in a crash?Jmuzz wrote:The Kmart will likely be better in a crash.TeVoRo wrote: So... that said, does that mean a $20 KMart helmet is sufficient for a casual cyclist?
- AUbicycles
- Site Admin
Re: MIPS helmets
Postby AUbicycles » Sat Nov 17, 2018 7:03 am
Re: MIPS helmets
Postby vodafone_au » Sun Nov 18, 2018 8:51 pm
My small complaint about my MIPS helmet is it is harder to wash & dry because of the shallow gap between the MIPS plastic and the inner part of the helmet.
- Howzat
Re: MIPS helmets
Postby Howzat » Fri Nov 30, 2018 11:32 pm
Re: MIPS helmets
Postby Calvin27 » Sat Dec 01, 2018 11:23 pm
I suspect that MIPS licensing is a bit on the steep side of things.Howzat wrote:I see POC no longer make MIPS helmets. They've discontinued them in favour of a new system with claims of similar effects... but it look like pads to me.
Cushy dirt bike
No brakes bike
Ebike
Users browsing this forum: OnTrackZeD
