by mikesbytes » Mon Sep 05, 2011 11:15 am
I'm trying to describe to someone how to get onto the Gladesville bridge footpath, but my description is not understood. Can someone please write up a better description than mine following; Take the footpath on the right hand side of bridge, ie the northern side. When you get to the Huntley Point end there will be a fence that turns you around. Now you have 2 options; 1. Cross the road at the end of the fence and ride along the dirt on the right hand side until it takes you within some armco, where you join a footpath that takes you all the way to the Hunter Hill overpass. 2. Go down the staircase that takes you under the road, turn left and keep left going onto the footpath that appears to your left, it will take you up a short steep hill, where you will join the same footpath that takes you to the Hunter Hill overpass. http://maps.google.com.au/maps?hl=&q=gl ... 2&t=h&z=20
mikesbytes
by Forum Ads » Mon Sep 05, 2011 12:48 pm
by duncanm » Mon Sep 05, 2011 12:48 pm
I'm confused.
You've described *Exiting* the Gladesville bridge onto the Northern Burns-bay Rd exit.
Approaching from the West (Victoria Rd).
1/ Hop onto the left footpath at the lights before Riverside Girls, you'll see a concrete bus shelter (although I think they were pulling that out last week). 2/ duck down the path behind the bus shelter and under Burns Bay Rd. 3/ up the stairs, go between the wire fence and armco onto the slip lane 4/ ride down a slip till you see a wire fence opposite. Watch for cars 5/ cross onto the path on the other side, which will take you up to the bridge.
The tragic thing is, that whole Gladesville Bridge northern end is so f*cked up, I don't even know what the official route onto the bridge is!
duncanm
by duncanm » Mon Sep 05, 2011 1:18 pm
duncanm
by CommuRider » Mon Sep 05, 2011 1:20 pm
CommuRider
by find_bruce » Mon Sep 05, 2011 1:38 pm
Hi Mike, I had the joy of going that way recently and your difficulty in describing the path is because it is difficult to find the right path. What is not clear to me though is where is the person riding from and to in that the heading is "Entry to Gladesville bridge from the west side" but the path you describe sounds like they are riding from Drummoyne to Hunters Hill I would describe the path from Drummoyne to Hunters Hill as follows As you exit the Gladesville Bridge, the designated cycle route is via a 180° corner at the end of the bridge, down alongside the access loop (from Burns Bay Road at Hunters Hill to Victoria Road at Gladesville). You will drop below the road level where there are four stairs on your right. Go down the stairs and through the tunnel before descending a further two flights of stairs to Huntleys Point Road.
Ride north along Huntley's Point Road for about 100 metres where there is a path to the left. Take the path up the hill past the southern end of Keeyuga Road, keep to the left hand path which will take you onto the bridge over Tarkan Creek.
I wouldn't recommend anyone crossing the access loop from Burns Bay Road at Hunters Hill to Victoria Road at Gladesville because cars are travelling at least 70 kmh and IMO there is not enough visibility to cross the road safely, especially if they are not sure where they are going. When I am heading west though, that is precisely the route I take - do as I say, not as I do As best I can tell, the "offical route" when travelling east along Victoria Road is as follows: On Victoria Road heading east, join the footpath at Mortimer Lewis Drive. The path drops down away from Victoria Road and goes under Burns Bay Road, coming out at the northern end of Keeyuga Road. 50 metres up Keeyuga Road, cross the road where there is a path to the right. Follow the path to the T junction and turn left which will take you past the southern end of Keeyuga Road. The path stops at the bottom of the hill on Huntley's Point Road. Continue along the grass for 100 metres and turn right up the two flights of stairs, through the tunnel and up a further four stairs. Turn right up the hill where there is a 180° corner that will take you up and over the bridge If we can make the directions clear, I will update the section in Bike Paths in Sydney. Thanks duncamm for the link to the bikenorth page which I will add now.
I was going to buy a fast, stylish bike, but I looked in the mirror & thought " you're not fooling anyone, you know"
by mikesbytes » Mon Sep 05, 2011 11:49 pm
sorry Duncanm, by west, I meant coming from the north on the western side
mikesbytes
by rogan » Tue Sep 06, 2011 7:48 am
It's not for everyone, and it depends on the time of day/week, but my preference when I lived in the inner west was to do Gladesville Bridge on the road.
rogan
by duncanm » Tue Sep 06, 2011 7:29 pm
mikesbytes wrote:sorry Duncanm, by west, I meant coming from the north on the western side
I'm still a little confused... but here goes. If coming from the North (Burns Bay Rd).. don't use the western side. Approach using the Eastern Side of Tarban Ck Bridge (ie: the 'correct' left traffic side when approaching gladesville bridge), either on the road or adjacent shared path. Do that by crossing over Burns Bay Rd using the Ryde Rd/Church St overpass at Hunters Hill. As you cross the overpass, you have two options: 1/ (off-road): cross overpass, turn right down Durham, follow path at end of straight bit (opposite scout hall) down across footpath on Tarban Ck bridge, then exit onto slipway between armco and wire chainlink fence. Continue as described above. or 2/ (faster, for the brave-ish): cross overpass, but take the slip lane down onto Burns Bay Rd (go flat chat here. 60+ is easy) then across Tarban Ck bridge with the traffic and then pull left into the slip once over the bridge. Continue as described above.
duncanm
by mikesbytes » Wed Sep 07, 2011 11:48 am
Thanks for the info guys, they understands the options
I haven't been on the new iron cove bridge, is it obvious how you get on it from the Drummone end?
mikesbytes
by find_bruce » Wed Sep 07, 2011 2:30 pm
mikesbytes wrote:I haven't been on the new iron cove bridge, is it obvious how you get on it from the Drummone end?
Yep easy as. Two options - cross Victoria Road at Park Avenue, ride straight up the new ramp.
- follow Cary Street around and under Victoria Road, turn left onto the ramp up to the bridge.
The other advantage of the new bridge is that the shared path on the old bridge is quiet so no great dramas if you want to use that instead.
by duncanm » Wed Sep 07, 2011 3:57 pm
..... or if coming from the Gladesville bridge (down through Wrights Rd then Renwick St).. it's a pretty obvious continuation of the footpath on the old bridge.
duncanm
Return to New South Wales
