Hawkesbury Heights on a Standard Crank
GasCyclist
Postby GasCyclist » Fri May 24, 2013 4:28 pm
Hey Guys,
Planning to do this ride for the first time from Agnes Banks with a few mates. My Cannondale Supersix is on a standard crank with a 12-25 cassette at the back. Did the Galston Gorge ride with it and while being a grind found it to be ok.
How does this ride compare to Galston?
Or should I be weak and bring my heavy Trek with the compact gearing instead.
Trek 1.5, Cannondale Supersix, Specialized Langster
michaelten
Re: Hawkesbury Heights on a Standard Crank
Postby michaelten » Fri May 24, 2013 6:37 pm
I've got standard cranks and a 28 cassette. The first hill is the worst part, it's much easier past there. Having said that, I was on the 28 on the first section and then 24 and 21 for the rest of it. I would say it's certainly doable with the 25.
GasCyclist
Postby GasCyclist » Fri May 24, 2013 7:37 pm
Thanks for the reply. How hard is this first climb were you spinning it or grinding on the 28?
michaelten
Postby michaelten » Fri May 24, 2013 7:42 pm
Spinning.
My wife did it with a standard crank and 25 cassette, although she only weighs 49kg.
GasCyclist
Postby GasCyclist » Fri May 24, 2013 8:00 pm
Hmmmm food for thought.
Users browsing this forum: tez001
