Any SSCX stockists in Adelaide?
goudgey
Postby goudgey » Fri May 16, 2014 10:51 am
Hi All,
I'm after a single speed CX bike but haven't had any success in finding one locally. Anyone know which stores stock these in Adelaide?
Mark
edsa
Re: Any SSCX stockists in Adelaide?
Postby edsa » Fri May 16, 2014 5:06 pm
You could try treadly, they specialise in single speeds and probably could build one up for you from a cinelli frame.
http://treadlybikeshop.com.au/
goudgey
Postby goudgey » Sat May 17, 2014 12:04 pm
Cheers, will give Treadly a go and see what they can do for me. Any other suggestions?
edsa
Postby edsa » Sat May 17, 2014 3:30 pm
BMCR are surly stockists and could build a SSCX on a Surly Karate Monkey frame.
http://www.bmcr.com.au/surly.html#!prettyPhoto
Here is a blog where the user uses the frame for cyclocross http://jeffsbike.blogspot.com.au/2011/1 ... sions.html
You could build it as a sscx with disc brakes and when you retire it from cx you could fix gears and have a disc braked, geared commuter/tourer =)
versatile frame if a bit on the expensive side.
larfinboy
Postby larfinboy » Thu Aug 07, 2014 9:48 pm
Sam (AT) Treadly can certainly help you out with Cinelli.
I've just ordered a Soma Wolverine frameset from BMCR - SSCX/Monster cross/gravel grinder.
Otherwise BMCR could get you a Surly Cross Check single speed.
TailWalker
Postby TailWalker » Wed Sep 10, 2014 1:00 pm
larfinboy wrote:Sam (AT) Treadly can certainly help you out with Cinelli.
Can I ask how much the Wolverine frameset cost you?
