Who is going to Fitz's Challenge / Epic / Extreme?
Postby ausrandoman » Fri Aug 10, 2012 8:53 am
I've started serious hill climbing training for the 250 km. :shock:
I'm looking forward to my cruise up the Hume and riding with hundreds of other knee-busting nut cases :lol:
Nobody younger than 27 has experienced a month with temperatures lower than the 20th century global monthly average.
ausrandoman
by Forum Ads » Fri Aug 10, 2012 6:06 pm
Re: Who is going to Fitz's Challenge / Epic / Extreme?
Postby jcjordan » Fri Aug 10, 2012 6:06 pm
Based on my privious experience unless your in the top 20% in terms of speed you also need to be prepared to be completely self sufficient as well.
Pedal power always seem to run out of water at the check points.
Sent from my HTC Sensation Z710a using Tapatalk 2
James
jcjordan
Postby mrgolf » Fri Aug 10, 2012 9:42 pm
Planning on 250. Lots of water to go under plenty of bridges before then. May my health remain thumbsup...
Merida Reacto 907 TWE wheels, Merida HFS 1000D, Merida Cyclocross CX4 Disc, Custom HongFu 29, Norco Diamond, Chariot CX1+CX2
mrgolf
Postby Ross » Sat Aug 11, 2012 9:03 am
mrgolf wrote: May my health remain thumbsup...
And your wheels rubber side down...
Ross
Postby mrgolf » Sat Aug 11, 2012 11:40 pm
Thank you, and you too... :beer:
mrgolf
Postby Cruiserman » Thu Aug 23, 2012 10:28 pm
Sure you arent being a bit one eyed on this one Mr Golf.....
2008 Specialized SWorks Roubaix SL - Zipps - Campag - Nuff Said
1986 Spokesman Model 11 Racing - Campag Nuvo Record - Stronglight - Shimano 600
Cruiserman
Postby mrgolf » Fri Aug 24, 2012 8:35 pm
Both were functioning fine at the time of posting. But thanks for asking.
mrgolf
Postby skull » Sat Aug 25, 2012 9:42 am
I am considering this.
Tho OCT is an epic month for me, doing the Scott 24, ADF Champs, then Fitz's. Should all be good training for the tour of Bright.
skull
Postby rogan » Mon Oct 08, 2012 6:50 am
Signed up for the 205 with some mates. We're doing a 240 km training ride this Friday. I'm putting the compacts on next week. Looking forward to it...
rogan
Postby the_big_fella » Mon Oct 15, 2012 7:15 pm
Yep. Signed up for the 105km.
Should be good fun. Then next year the 165...
the_big_fella
Postby nickdos » Tue Oct 16, 2012 8:58 am
Also planning to do the 105km. This will be my first Fitz's so I'm not sure what to expect.
I did my longest ride to date on the weekend in preparation - 95km ride via Gunderoo (only had a road bike for 8 months). Pulled up ok but it only had about half the elevation of the Fitz 105 so I'm expecting my average speed to be a fair bit below the 30.5 km/h I managed on my Gunderoo ride (which included a 1 hour coffee stop).
Having ridden the Uriarra/Cotter loop a few times, I'm thinking it's probably a good idea to keep a few matches in store for those climbs at the end. I've bonked once before on the Uriarra Road return (newbie mistake) so I'll not want to repeat that.
nickdos
Postby HAKS » Tue Oct 16, 2012 11:49 am
You'll find you actually save a fair bit of energy once you settle into a group. If you get caught in-between bunches my advice is to sit up and save energy until the next group arrives then get on the back of them. Def save some energy for the 3 sisters climb and make sure you have a bite to eat at each of the feed stations along the way.
Current Ride: Giant 2010 TCR Advanced 1
HAKS
Postby mrgolf » Tue Oct 16, 2012 4:27 pm
The 105 is deceptively hard. There is a lot of climbing and a lot of exposed plains where the wind can hit you. It is rarely calm on Fitz rides, so take it easy to Tharwa and leave some in the bank for the last half of the return. I did the 105 recovering from a flu a couple of years back at near my race pace and the last 40kms were tough.
I am a bit more concerned about the 255. I havent ridden over 80kms in a day in months, and have done very little climbing. Looks like I will be relying on being fully recovered from the chest thing and hoping my legs hold up. Eep!!!
mrgolf
Postby the_big_fella » Wed Oct 17, 2012 4:11 pm
Thanks HAKS and mrgolf for your advice.
The 105km does have a fair amount of climbing involved - I will definitely be pacing myself - that last slog along Uriarra Rd back to Stromlo will be a little gruelling.
As for the 255, I can't even begin to imagine tackling that one...
Also, does anyone know what sort of "snacks" are usually available at the feed stations?
the_big_fella
Postby HAKS » Thu Oct 18, 2012 11:40 am
the_big_fella wrote:Also, does anyone know what sort of "snacks" are usually available at the feed stations?
Mainly oranges & apples pieces and jelly lollies (snakes etc) if I recall correctly. Make sure you take enough of your own though in case they run out towards the end.
HAKS
Postby singlespeedscott » Fri Oct 19, 2012 1:40 am
Only 9 days to go and I'm getting excited and nervous. Signed up for the 255km. Haven't done nearly enough km's or climbing. I did manage a 193km ride a couple of weeks ago. Unfortunately with only 1000m of climbing. I hope I can hold it together to finish in time.
Postby skull » Fri Oct 19, 2012 8:17 am
Yay.
I am sick and this is only a week and a bit away.
Sent from my not iDevice using Tapatalk 2
skull
Postby rogan » Mon Oct 22, 2012 11:44 am
The weather prediction is -1C to 18. Should be fun sitting on the start line at SFP for 30 minutes at minus 1.
For those of us not used to riding below about 5C, does anyone have any gear recommendations?
rogan
Postby Ross » Mon Oct 22, 2012 3:09 pm
Stuff that you can peel off and store easily such as arm/leg warmers and gillets. It will be cold descending into the Cotter but once you start climbing Pierces Creek you won't notice the cold, though you will still be cool on the rolling hills beyond Pierces. Probably once you get to around Tidbinbilla you will be warmed up enough I expect to just have short sleeves and no leg warmers, though depending on which ride you are doing you may want to layer back up for the descents of Fitz's, Honeysuckle and Corin. By the time you get back to Pierces Creek again it will be mid day/mid afternoon so you shouldn't need to dress up for that descent, but watch for potholes. The rest of the ride (Mt McDonald and 3 Sisters) is mostly climbing (except for false flat from Uriarra Homestead to Uriarra Crossing), so you won't need much clothing there.
Edit: I should mention a couple of Magpies that are enroute - one just south of Tharwa, another further south after Fitz's hill, after the cattle grid in Namadgi NP, another at KOM point of Mt McDonald, another on Uriarra Rd false flat near the Homstead and another on the 1st Sister. If you are riding in a group you are probably going to be ok, if solo then they may have a swoop. My advice is to be alert, not alarmed and avoid waving your arms or other weapons at them and after a couple of swoops they will get bored and look for someone else to annoy.
viewtopic.php?f=17&t=55836
Ross
Postby Howzat » Mon Oct 22, 2012 8:09 pm
I see Tony Abbott is up for the 50km ride.
Howzat
Postby mrgolf » Mon Oct 22, 2012 8:19 pm
I dont know which is worse: the prospect of swoopy magpies or the prospect of abbott...
In other news, 1350gm wheels and an 11-28 (non compact) installed. Ready! I only agreed to go soft on the cassette range when I heard the tour guys ride some pretty interesting gearing.
mrgolf
Postby jimsheedy » Mon Oct 22, 2012 8:27 pm
in for the 205. been battling a stomach virus for the pst couple of weeks though. will have to see how i pull up.
jimsheedy
Postby singlespeedscott » Mon Oct 22, 2012 8:41 pm
mrgolf wrote:In other news, 1350gm wheels and an 11-28 (non compact) installed. Ready! I only agreed to go soft on the cassette range when I heard the tour guys ride some pretty interesting gearing.
Ha. 1980gm. 13-32 x 48-42-30 triple. You got nothing. :)
Postby mrgolf » Tue Oct 23, 2012 4:20 pm
Wow! they dont call you singlespeedscott for nothing...
mrgolf
Postby Cossie Phil » Tue Oct 23, 2012 6:40 pm
A mate and I are entered in the 205km Epic...biggest ride so far is a 200km stint on the M7, but been doing Razorback down south and 3/4 Gorges north of Sydney for the last 5 weekends...hopefully a 39/27T granny gear will be sufficient!!
Were planning to do a recon drive on Saturday afternoon to check out what were in for given we have never been near the ride area before.
Phil.
Cossie Phil
Return to ACT
Users browsing this forum: Ross, x8pg2qr
