Have Your Say - Maintenance of Main Roads Shared Paths
Postby Aushiker » Wed Jul 18, 2007 4:10 pm
G'day
From the MRD website:
About the survey to evaluate Main Roads shared-path maintenance trial
Over the last sixth months, there has been a shared-path maintenance trial. We now want to find out how effective this has been.
Already, we have received regular feedback about the standard of maintenance. As a result of this feedback an improved set of maintenance standards is being trialled. We now need to find out if these standards will be operationally possible.
Since April 2007, a two-person crew has been dedicated to the maintenance of Main Roads controlled shared paths. View or download the map linked below to see where these paths are located.
* Map of Main Roads controlled shared paths - A3 size
(1-page PDF 540 KB opens in a new window).
The paths are inspected at least once a week more frequently in areas where they are used a lot or require extra maintenance - and the crew do the following jobs:
* maintain and clear obstructive or hazardous vegetation;
* surface maintenance;
* drainage maintenance;
* monitor and maintain structures (fencing and retaining walls) within the Main Roads controlled path;
* maintain signs, line marking, bollards and grab rails; and
* monitoring and maintenance in respect to debris, litter, graffiti, lighting and vandalism.
Note: the maintenance crew are not responsible for improvements or the construction of new paths and facilities - for example, installing new lighting, signs or line marking.
The survey can be found by clicking here - Word document and the map at here.
Regards
Return to Western Australia
