Closure of Hutton Street PSP
20thCB
Postby 20thCB » Fri Jan 23, 2009 12:43 am
Presumably the footbridge to Osbourne Park is still accessible?
TCR-A1
Postby TCR-A1 » Tue Jan 27, 2009 4:34 pm
Hi People.
I am delighted to report that there is a nice new smooth, super wide ashpault surface being laid today along the Fwy side of the princeton wall.
It looks like a Fwy for cyclists.
ABout time!!! :) :) :)
rolandp
Postby rolandp » Tue Jan 27, 2009 10:52 pm
It is good news, though the signage is not clear if it is open or not.
Please take care as I saw one cyclist go through the original diversion this evening where the diversion has a signficant amount of sand, and almost lost it in the sand.
Will there be any legal action taken against these developers for this delay (ie 10 months)? If not, one has to question why not.
moosterbounce
Postby moosterbounce » Tue Jan 27, 2009 11:13 pm
rolandp wrote:Please take care as I saw one cyclist go through the original diversion this evening where the diversion has a signficant amount of sand, and almost lost it in the sand.
Wasn't Mr Moo this time :wink:
He's almost healed from his 2nd fall this month so I'd better get out the dettol as he's probably due another. I'll keep him away from this area until I get the green light :)
gdl_gdl
Postby gdl_gdl » Wed Jan 28, 2009 10:58 am
The new path is now "unofficially" open - I rode past this morning and it does say the path is closed (with a sign blocking the path) but you can easily ride through to the other side. (I didn't ride on the new path but I saw a few cyclists who did quite successfully).
I'm assuming it is just waiting to be marked up?
Gary
gdl_gdl
Postby gdl_gdl » Wed Jan 28, 2009 9:29 pm
The path is now officially open - as you travel Northbound, the link to the housing estate is cut off as you exit Hutton Street so you only have the path as the option.
Gary
rolandp
Postby rolandp » Wed Jan 28, 2009 11:49 pm
Moo, I got talking to this cyclist and it turned out that this was his second spill in the area. Put two-and-two together, so I asked if he was 'Mr Moo.'. Blank look. Your wife isn't Moo, no it's Anne. We had a good chat after that and I explained that he wasn't the only one who had fallen off in this area.
His preference was for the diversion or some form of it (as it is currently not rideable) to remain as he lived East of Princeton Estate. Unfortuantly this may not occur as Gary reports, this diversion is now fenced off with signficant earth works where we were riding yesterday. It is a shame for those who live in Princeton Estate as their access to the Perth Bicycle Network has been effectively cut off with the limestone wall and further demonstrates the lack of planning for cycling infrastrcture in this area.
Note, that there is no markings on this path, so see When is a path a shared path?, so technically we should not be using this path and using the original diversions (which the developers pulled up today), or walking your bike until the path signs are installed.
Now, when will the path lights be installed?
Postby Aushiker » Wed Jan 28, 2009 11:52 pm
rolandp wrote:Note, that there is no markings on this path, so see When is a path a shared path?, so technically we should not be using this path and using the original diversions (which the developers pulled up today), or walking your bike until the path signs are installed.
I don't think that is a valid comment re walking at all. You seem to be taking a definition and then applying an "instruction" to it, which is not appropriate. There is no evidence from what I have read or seen that would indicate that the new path is a footpath as defined in the Road Code 2000 .
Furthermore common sense should and does apply in this case IMO
rolandp
Postby rolandp » Fri Mar 13, 2009 12:31 am
It is now 12 months since the closure of the dual-use path, and there should be a minute silence to reflect the last 12 months and the pains that we have gone through due to a private developer destroying the dual-use path, and taking 11 months to re-implement the path.
The path is still 'technically' not able to be used by cyclist based on the Road Traffic Code 2000. There is no signage at Hutton St indicating that this is a shared path, however, personally I have been riding on it since it was completed. Confirmation via e-mail indicates that MainRoads recognise the lack of signage and will be correcting this in the future.
However, my concern is with the lack of prosecution of the developer who caused the initial outage. A letter from Minister of Transport indicates 'While is it unfortunate that the works to reinstate the PSP have taken longer than expected, Main Roads has no plans to seek compensation from the developers.'. Didn't the number of accidents that occured on this diversion warrent the prosecution?
Main Roads/City of Stirling, please reflect back on this closue, and learn from it. Don't allow this to happen again.
gdl_gdl
Re: Closure of Hutton Street PSP
Postby gdl_gdl » Sat May 16, 2009 4:03 pm
I note that the cycle path running by the Princeton Estate has now been painted!
(I guess they had to clear the leaves for this job! :wink: )
Gary
