Railway Reserves Heritage Trail
bjohnson
Postby bjohnson » Mon Sep 24, 2012 1:32 am
I'm keen to get out into the hills,
I like the look of the railway reserves trail http://www.railwayreserves.com.au/Documents/Railway%20Reserves%20Heritage%20Trail%20brochure.pdf.
I'm pretty keen to incorporate it into a longer ride. It looks quite smooth on a lot of the images.
For anyone that has ridden it before, is it doable on a road bike or am I dreaming?
mitzikatzi
Re: Railway Reserves Heritage Trail
Postby mitzikatzi » Mon Sep 24, 2012 8:32 am
Baalzamon
Postby Baalzamon » Mon Sep 24, 2012 9:19 am
CX can do it, but road bike naah. My trike could do it as well :)
Phil
Postby Phil » Mon Sep 24, 2012 12:26 pm
A few bit gets a bit loose in summer, but now its a very decent surface. Doable on a hybrid or anything running 32+mm tyres currently.
bjohnson
Postby bjohnson » Mon Sep 24, 2012 11:25 pm
Cheers.
While I was hopeful, that's pretty much what I expected :(
Good excuse to save for a CX bike I guess :wink:
Pravda
Postby Pravda » Tue Sep 25, 2012 2:48 pm
The roads running adjacent to the trail are reasonably good for roadies. I went up there this weekend just gone. It's not the most direct route into the hills but it ain't bad.
Sent from my GT-I9100 using Tapatalk 2
2014 Canyon Aerode SLX
Puegeot Aneto 105
Kona Jake the Snake CX
bazilicus
Postby bazilicus » Wed Oct 24, 2012 4:57 pm
Very much ridable on a road bike
http://youtu.be/geOFzYjV4O4
fixed
Postby fixed » Wed Oct 24, 2012 7:14 pm
My first ride on the heritage trail was on Ricardo Viva roadie running 27x1 1/4 tyres.
Two sections were slightly more difficult:
The cutting into Glen Forrest going uphill, and downhill the exposed railway ballast once in John Forrest National Park.
The tunnel is always fun regardless of which bike you're running.
Larger cross-section tyres do make it easier
The bicycle is a curious vehicle. Its passenger is its engine.
Sprocket
Postby Sprocket » Wed Oct 24, 2012 9:16 pm
I grew up out that way and used to ride a ladies 3-speed with something around 30mm tyres (Can't quite remember but certainly narrower than 35mm and wider than 25mm :) ) along the railway reserve and all through John Forrest. Rarely had to get off and push along the Railway path, and was usually due to the blue metal rather than the pea gravel, and they've removed a lot of this.
RobertFrith
Postby RobertFrith » Wed Oct 24, 2012 11:36 pm
You can do most of it on a roadie easily. While it is gravel much of the surface is surprising smooth. Being an old rail track the grades are very mild. The worst of it is on the north side through the national park, the tunnel is rough, dark and can be wet. You'd probably want to walk a roadie through there (or take the route that goes around it). My review of it is here
Pravda
Postby Pravda » Mon Oct 29, 2012 4:16 pm
Anyone know what kind of time you're looking at for a return journey of the full track (out to Worooloo and back). From memory its about 57km so I'm thinking around 4 hours depending on how often you were to stop.
Thinking of giving my CX bike a christening with a ride out there.
Puegeot Aneto 105
Phil
Postby Phil » Tue Oct 30, 2012 1:21 am
Just doing the loop of Bellevue to Mundaring to Stoneville to JFNP to Bellevue is 41 kms, usually work on just on two hours normally.
Out to Wooraloo has got to be a fair bit further. From Mundaring Sculpture Park to Bakers Hills and return is 84kms and a relatively flat easy run with a decent food stop.
And whilst some people have done it on roadies - I wouldn't be abusing my rims with that sort of treatment, your bike - your choice.
sambo3
Postby sambo3 » Wed Oct 31, 2012 7:08 pm
I did this ride today 110km round trip from Woodlands on my Alan CX bike. I would echo what others have said and would say you could do it on a road bike.
As Robertfirth has described in his great review the Nth section has an area of about 3-5kms that would give some trouble to road bikes.
Its not the pea gravel being soft that is the problem or excess use of this area, rather the fact that the base consists mostly of rail base rocks. You know those pointy edge ones . Even on the Alan I had to take extra caution through this section but it does only last for those 5ks or so.
I went up the nth side then down the south side, the easterly was a PITA getting there but great comming home. The only other section that may be a problem was between Darlington and Boya. The pea gravel had a few extra soft sections here (this would only be a hassle if going east west). Overall a great ride on the CX and will do again in the next few weeks as prep for my Kep track run. I will also hook up the GoPro and take some vid of the good and bad sections.
I did notice two water fountains on the Nth side, basically on the track so could you top up water on your trip. Also if doing this on a road bike there are tarmac roads beside most of the track which would enable you to bail to the tarmac if needed.
A few pics only had a crappy phone camera with me next time will shoot some of the scenic nth side but was pressed for time.
Signage that is throughout the trail
Wildflowers
Morning Tea at Mt Helena
Darlington Train Station
Thoglette
Postby Thoglette » Wed Oct 31, 2012 11:40 pm
bazilicus wrote:Very much ridable on a road bike: http://youtu.be/geOFzYjV4O4
But out your Paris - Roubaix 28mm dugasts on. 27 x 1 1/4 are better (or 700C/32).
Pravda
Postby Pravda » Sun Nov 04, 2012 11:58 am
Rode the trail on my cross bike yesterday morning. Its easily doable on something running slightly wide tyres. That said i wouldn't take my readied on it. Too much chance of a stack on loose surfaces.
Puegeot Aneto 105
Phil
Postby Phil » Mon Nov 12, 2012 12:59 pm
Did this yesterday with my usual crowd who are a bunch of die-hard roadies.
The only comments afterwards were when we were going to organise the next one, and what time is the Bakers Hill pie Shop open?
I think the rain the night before did a great job of keeping the dust down.
Sprocket
Postby Sprocket » Mon Nov 12, 2012 1:16 pm
I rode part of this trail yesterday as well, picking the trail up at Swan View and out to Parkerville - on my steel frame tourer with 35mm (1.4") slick tyres. No problems except going through the railway tunnel - just had to see if it could be done.... it can, but it wasn't fun. Wouldn't recommend the tunnel on anything less than MTB tyres. The rest was just fine and a very nice ride.
Phil
Postby Phil » Mon Nov 12, 2012 9:09 pm
Sprocket wrote:I rode part of this trail yesterday as well, picking the trail up at Swan View and out to Parkerville - on my steel frame tourer with 35mm (1.4") slick tyres. No problems except going through the railway tunnel - just had to see if it could be done.... it can, but it wasn't fun. Wouldn't recommend the tunnel on anything less than MTB tyres. The rest was just fine and a very nice ride.
yeah went through yesterday - the surface is quite lumpy - like rocks that have been glued down?
No dramas though on the 29er at 30psi. Dark though.
conche
Postby conche » Sun Nov 18, 2012 3:50 pm
Hi,
I am heading out for my first venture riding the heritage trail sometime early this week. I currently have a set of Conti City Contacts tyres (28 x 1 3/8 x 1 5/8) on my 29er, but have a spare set of Maxxis MTB tyres that came with my bike when I originally purchased it. Will the Conti's be suitable for the terrain on the trail or should i swap to the Maxxis'.
Here is a link showing what the conti city contacts look like. http://www.cellbikes.com.au/Continental ... -Bike-Tyre
Any recommendations as to where to start the trail and park my vehicle (safe area) ?
Your comments are appreciated :D
Giant TCR Advanced, Giant XTC 29er 1
mitzikatzi
Postby mitzikatzi » Sun Nov 18, 2012 4:54 pm
conche wrote:Hi,
I would fit the Maxxis MTB tyres but I suspect you could do it on the City Contacts. I did it today on Maxxis MTB tyres.
Today I parked at Sculpture Park in Mundaring (nice toilets)
On Sundays I have parked at Bellevue Returned Services Community & Sporting Club, : Purton Place, Bellevue WA 6056
You can park at any number of places.
Here is a Map linked above map here parking is noted
Phil
Postby Phil » Sun Nov 18, 2012 5:15 pm
mitzikatzi wrote:Today I parked at Sculpture Park in Mundaring (nice toilets)
Agreed seen too much broken glass in the carpark at the top of Morrison Road to be comfortable parking there.
Sculpture park is a good spot too - close to Dome for a coffee after the ride.
conche
Postby conche » Mon Nov 19, 2012 12:02 am
Thanks Mitzikatzi. Is it possible to park at the Bellevue Returned Services Community & Sporting Club any time of the week? Looks like a great place to start....cheers! :D
mitzikatzi
Postby mitzikatzi » Mon Nov 19, 2012 1:55 pm
No idea if the RSL get grumpy if you park in there car park.
You can just park in the Park where the trail starts. There is a info board there.
MikeRoadie
Postby MikeRoadie » Mon Dec 22, 2014 4:05 pm
Hi guys and girls - I live very close to the heritage trail and make use of it on a mountain bike that is too small for me (wifes bike) but still a bit of fun. I have a roadie that i ride on the tarmac on and just rebuilding an old kuwahara pro series 2000. That has 23s on it at the moment but would have thought 23s would be pretty awful on the trail. I know 28s would probably go on the bike. I was recommended 35's by the LBS but they didnt fit the bike, rubbing on the brake. I would think about a 30 to 32 depending on the tyre would fit - but just seeing if anyone has put bigger tyres on an old road bike (circa probably 1996/1997 something like that) and can give me an idea of what has fit on other peoples bikes. Yes selling it off and buying a cyclocross or something similiar would be the smart option, but I'd like to give it a crack on bigger tyres. ALso anyone done the trail on 28s recently?
Troy C
Postby Troy C » Tue Dec 23, 2014 3:33 pm
I ride the trail at least once a week as my office is at the base of the hill. I use 3 different types of bikes, but i have problems with pinch flats on my CX bike with 35mm tires on it.
Its the section of John Forrest national park where the bridges have been renovated and they have stirred up all the old railway blue metal.
I run a good amount of pressure but descending the trail at speed, narrow tires cant handle these type of rocks.
I use a 26" hardtail (29" would be better) with 2.0 and run 40+ PSI
Rota-M Cycling Team, Board Member of ATTA, Member of CWA, WCMCC
Users browsing this forum: neild, rolandp
