Joondalup to Perth best route
The JPs
Postby The JPs » Fri May 31, 2013 1:48 am
Hi all,
I am thinking about cycling to work in East Perth from Joondalup. Can anyone suggest the best route for a novice rider.
Also, how long do you think it will take?
Chef
Re: Joondalup to Perth best route
Postby Chef » Fri May 31, 2013 9:29 am
Hi,
The cycle path runs along side the freeway into the city from Joondalup most of the way, with some detours through suburban streets.
It would be worth doing the ride on a day you aren't time pressured the first as it isn't as straight forward as you would think.
The path is not the fastest route into the city, but by far the safest - you are also close to stations along this route so it is easy to hop on to a train if you want to.
I found Wanneroo road to be a little faster than the bike path, but like most main roads it is not the most cycling friendly environment in peak hour.
http://www.transport.wa.gov.au/activetransport/24815.asp link to dept of transport bike path maps here
Hope that helps
Chef
Postby Chef » Fri May 31, 2013 9:30 am
Oh, and it will take an hour - hour 1/2 (depending on your level of fitness, which will improve a lot if you do this regularly!)
mitzikatzi
Postby mitzikatzi » Fri May 31, 2013 9:53 am
Route to ECU Joondalup from the city
try the search function as well
Pravda
Postby Pravda » Fri May 31, 2013 1:53 pm
Yup freeway bike path is the best, if not quickest, bet. My preference is ocean reef/gnangara/alexander dve/Fitzgerald for speed but its nit the safest route. Better than Wanneroo in my experience.
Sent from my GT-I9300 using Tapatalk 2
2014 Canyon Aerode SLX
Puegeot Aneto 105
Kona Jake the Snake CX
