Burswood Shared Path Diversion
Scott_C
Postby Scott_C » Wed Nov 16, 2016 9:52 pm
There is a diversion planned for a section of the shared path between the Causeway and Windan Bridge on the Burswood side of the river, starting from the 21st of November.
http://www.perthstadium.com.au/news-and ... on-impacts
The diversion will be 'slightly narrower' than the existing path and will be fenced off from the rest of the construction site.
BandedRail
Re: Burswood Shared Path Diversion
Postby BandedRail » Thu Nov 17, 2016 8:28 pm
If they plan to put the detour in place by Monday then they'll have to get a wriggle on - the path isn't even sealed yet.
And while we're on the subject of the detours due to the footbridge - please take care when cycling through these as I've nearly had several head-on crashes with people cutting the corners or swinging wide. It'll only cost you a few seconds to slow down a bit and take the corner on your side of the path.
BandedRail
Postby BandedRail » Tue Nov 29, 2016 9:08 am
The diversion is now in place. It gets quite narrow, particularly at the small bridge, so extra care is required.
Scott_C
Postby Scott_C » Wed Jun 21, 2017 2:51 pm
They will be temporarily diverting the current diversion near the future Swan River bridge from the 27th of June to mid-July, adding 4 new right angle turns to the path.
PDF with picture of the diversion.
wexford
Postby wexford » Sat Jun 24, 2017 9:28 am
Cue new Strava segment :roll:
roller
Postby roller » Wed Aug 23, 2017 11:20 am
absolutely loving the latest (non) diversion.
inflammatory statement or idea
