Panniers
- Aushiker
Re: Panniers
Postby Aushiker » Fri Oct 28, 2011 1:32 am
Here is another approach to carrying water on your panniers
This is the CyclingDutchGirl's setup. She and her friend where carrying 54 litres at one stage.
Aushiker.com
- elStado
Re: Panniers
Postby elStado » Fri Oct 28, 2011 1:36 am
Re: Panniers
Postby Uncle Just » Sun Oct 30, 2011 10:49 am
Did you use the appropriate sized fitting on the inside of the top latch to match the diameter of the Tubus rack? One other possibility might be if you pack too much so that the pannier is a bit misshapen it may twist the pannier top track slightly that can compromise its attachment ability. I also set up the panniers so they fit cleanly on the top rail by moving the adjustable clips along the track attached to the pannier so as not to interfere with the rack struts but in such a way they don't have any movement.
Re your last point I originally installed the wrong diameter clip but didn't have any probs removing them, I think IIRC I used a little screw driver to gently prise them out.
- RonK
Re: Panniers
Postby RonK » Sun Oct 30, 2011 12:32 pm
You should be using the large inserts on the Tubus rack, not the small ones.elStado wrote:Does anyone else find the Ortlieb QR2 release system quite annoying with a Tubus rack? I find that mine are really hard to attach or remove, sometimes I have to manually push the catch down so it latches onto the rack. When I remove it I have to pull the handle up to open the catch and then give it a bit of a yank to get it off. Not sure what I am doing wrong. I installed the optional fitting things so its a nice snug fit on the rack tubes so it doesn rattle around, but I think it might be a bit too tight hence my issues. I can't seem to get them out again though.
- stubbie
Re: Panniers
Postby stubbie » Mon Oct 31, 2011 7:14 am
+1 If they feel a bit loose wrap a strip of insulation tape around the rack at the attachment point.RonK wrote:You should be using the large inserts on the Tubus rack, not the small ones.elStado wrote:Does anyone else find the Ortlieb QR2 release system quite annoying with a Tubus rack? I find that mine are really hard to attach or remove, sometimes I have to manually push the catch down so it latches onto the rack. When I remove it I have to pull the handle up to open the catch and then give it a bit of a yank to get it off. Not sure what I am doing wrong. I installed the optional fitting things so its a nice snug fit on the rack tubes so it doesn rattle around, but I think it might be a bit too tight hence my issues. I can't seem to get them out again though.
- elStado
Re: Panniers
Postby elStado » Mon Oct 31, 2011 2:40 pm
Large as in the bigger, fatter inserts? Because that is what I am using. I have a little bit of electrical tape wrapped around the rack tubes to stop it rubbing.RonK wrote:You should be using the large inserts on the Tubus rack, not the small ones.
I'm using a Cosmo as well btw. Awesome rack now I have it fitted correctly on the bike.
- RonK
Re: Panniers
Postby RonK » Mon Oct 31, 2011 3:18 pm
There are two sets of inserts provided with Ortlieb bags. One set is obviously intended for a larger size rack tubing. RTFM. Since the Cosmo rack is not powder coated it's not necessary to insulate the tubes from rubbing, even though Tubus provide a set of tapes. That is the reason for choosing a stainless steel rack.elStado wrote:Large as in the bigger, fatter inserts? Because that is what I am using. I have a little bit of electrical tape wrapped around the rack tubes to stop it rubbing.RonK wrote:You should be using the large inserts on the Tubus rack, not the small ones.
I have fitted the Tubus tapes to the tubes as shown in the pictures in my previous post. I've never had a problem mounting or removing the panniers, or had any problem with them rattling.
- elStado
Re: Panniers
Postby elStado » Mon Oct 31, 2011 3:34 pm
OK. I'll have another look at it later. I have to admit I installed it and have been using it in a rush, so haven't had a chance to have a look at why it isn't working. I've got some free time this week now I have finished my studies.RonK wrote:There are two sets of inserts provided with Ortlieb bags. One set is obviously intended for a larger size rack tubing. RTFM. Since the Cosmo rack is not powder coated it's not necessary to insulate the tubes from rubbing, even though Tubus provide a set of tapes. That is the reason for choosing a stainless steel rack.elStado wrote:Large as in the bigger, fatter inserts? Because that is what I am using. I have a little bit of electrical tape wrapped around the rack tubes to stop it rubbing.RonK wrote:You should be using the large inserts on the Tubus rack, not the small ones.
- rifraf
Re: Panniers
Postby rifraf » Mon Oct 31, 2011 7:49 pm
I'm wondering if anyone's come across a rubber or plastic cover either purpose built to cover boltheads or nuts
or has come up with an idea of their own?
I'm just thinking there might be potential wear issue from the M8 bolts nuts where they touch the bags.
- il padrone
Re: Panniers
Postby il padrone » Mon Oct 31, 2011 8:10 pm
If you had installed the wrong size inserts your bags would not hook on properly to the rack (the clips would not close over it). There are inserts for 7mm racks a la Blackburn, and then inserts for 10mm rack tubes a la Tubus. 7mm inserts would not ft over the Cosmo's 10mm tubes.elStado wrote:OK. I'll have another look at it later. I have to admit I installed it and have been using it in a rush, so haven't had a chance to have a look at why it isn't working. I've got some free time this week now I have finished my studies.
My panniers have lost the inserts over time. In more than one of them carrying heavy loads has caused the hooks to distort a little bit and the inserts have come out. It's mainly the rear bags but they still remain secure on the bike. On tour I usually have a racktop drybag above them so they don't rattle about at all.
Re: Panniers
Postby polishbiker » Thu Nov 03, 2011 6:56 pm
Found on:
http://2cycle2gether.com/
- il padrone
Re: Panniers
Postby il padrone » Thu Nov 03, 2011 7:14 pm
That is BNA member Detail (aka gcoop) who she bumped into on the Warburton Road.Aushiker wrote:Hi
- Aushiker
Re: Panniers
Postby Aushiker » Sun Nov 06, 2011 12:49 pm
My Bike Pack Plus rear panniers arrived during the week from Evan Cycles via UPS. Look very nice indeed. Assuming the material handles life on the road okay (five year warranty so it should) I don't think I would get the standard panniers again. These look much nicer in the flesh.
Aushiker.com
- rifraf
Re: Panniers
Postby rifraf » Sun Nov 06, 2011 1:15 pm
Pics or it didnt happenAushiker wrote:Hi
- CommuRider
Re: Panniers
Postby CommuRider » Sun Nov 06, 2011 5:16 pm
I faced that with my panniers which had some magnificent receding/rubbing and basically I wrapped foam around the bolts and nuts and gaffer taped them so it provided some padding. I also padded the back of the panniers where they touched the nuts and bolts for extra protection and reduce friction. Wear and tear doesn't look good at the places where they rub. Friction accelerates the deterioration.rifraf wrote:Just noticed my Ortlieb pannier bags touch the lower bolt heads and nuts on my front rack.
I'm just thinking there might be potential wear issue from the M8 bolts nuts where they touch the bags. ]
- il padrone
Re: Panniers
Postby il padrone » Sun Nov 06, 2011 7:24 pm
Coat that part of the back of your panniers with some Sugru ??rifraf wrote:Just noticed my Ortlieb pannier bags touch the lower bolt heads and nuts on my front rack.
- Aushiker
Re: Panniers
Postby Aushiker » Sun Nov 06, 2011 7:30 pm
or apply it to the nuts/bolts.il padrone wrote:Coat that part of the back of your panniers with some Sugru ??
Aushiker.com
- il padrone
Re: Panniers
Postby il padrone » Sun Nov 06, 2011 7:39 pm
- rifraf
Re: Panniers
Postby rifraf » Sun Nov 06, 2011 10:53 pm
The hex-key boltheads shown were just to hold the rack in place for a pic.il padrone wrote:I'd thought of that, but it might make it a bit difficult for rifraf to get his hex-key in to remove the rack.
The only bolts available I could get in quickly were just standard bolt heads but at least in stainless steel with a ss nyloc nut.
I've seen somewhere, but memory currently fails me, a plastic cover (or maybe it was rubber) specifically for nuts and bolts in positions
where abrasion could be an issue.
It'll come to me (at 3am sometime) but probably after I've paid for another and probably inferior solution.
I'm a little too fussy to want beads of gloop on my bike or panniers no matter how good the cause but thanks for
the thoughts guys.
Re: Panniers
Postby Ronbellows » Mon Nov 07, 2011 8:23 am
- rifraf
Re: Panniers
Postby rifraf » Tue Nov 08, 2011 1:33 am
Hi Ron,Ronbellows wrote:Rifraf, you can insert an M8 helicoil (using a helicoil kit) in the tube you currently have your bolts running through. This allows you to use a bolt with a very flat dome head and allen key socket like the ones the rack should have come with. I haven't done this yet, but the procedure was described in the latest MBC journal.
longtime no see
Thanks for the interesting tip
When are you going to post a pic of your wheels?
Love to see it
- Aushiker
Re: Panniers
Postby Aushiker » Thu Nov 10, 2011 5:23 pm
A few happy snaps of the Ortlieb Bike-Packer Plus rear panniers. The full set of snaps can be found here.
These are yet to be used in anger ... should be this afternoon on a shopping trip
Regards
Aushiker.com
- il padrone
Re: Panniers
Postby il padrone » Thu Nov 10, 2011 6:34 pm
Nice looking panniers, makes me think that I'd be better off with these rather than my Bikepacker Classics . The pockets on them are nice and they have a better mounting system. The Germans sure know how to do warranties. I recently received a new Tubus Cargo for my daughter and on the documentation see that they now guarantee these for 30 years !
I see that you've gone for the Mars 4.0 tail-lights in a pair as your main tail-lights. How have you found them? I use one as secondary to my dynamo rear light and it is a very bright flasher, and pretty waterproof so far.
- Max
Panniers
Postby Max » Thu Nov 10, 2011 7:30 pm
Max
Re: Panniers
Postby }SkOrPn--7 » Thu Nov 10, 2011 8:56 pm
Ricky
