Page 2 of 2
Re: Sleeping mat alternatives
Posted: Thu Oct 04, 2012 4:52 pm
by Aushiker
il padrone wrote:All Exped mats now use a built-in hand pump with a valve for air in and a valve for air out= two valves. .
Sorry but need to correct you there. Not all Exped mats come with a built-in hand pump. The Synmat ULs for starters do not have pumps. Neither do the Downmat UL mats but they are supplied with a Schnozzel Pumpbag. I didn't bother to check the other models but I suspect that your statement does not apply to all models.
Posted: Thu Oct 04, 2012 5:02 pm
by il padrone
Aushiker wrote:il padrone wrote:All Exped mats now use a built-in hand pump with a valve for air in and a valve for air out= two valves. .
Sorry but need to correct you there. Not all Exped mats come with a built-in hand pump. The Synmats for starters do not have pumps. Neither do the Downmat UL mats but they are supplied with a Schnozzel Pumpbag.
Strange, my Synmat, and my mate's Downmat* both have
this style of built-in hand-pump
* both recent purchases in the last 12 months.
Posted: Thu Oct 04, 2012 5:12 pm
by Aushiker
I stand corrected. I should have included the UL in the reference to Synmats; my bad. You can easily verify which models have built-in pumps and which don't at
http://exped.com" onclick="window.open(this.href);return false;.
Posted: Fri Mar 22, 2013 7:46 pm
by Aushiker
I had pretty much given up on my
Exped Synmat UL 7S as I couldn't find the cause of it deflating and was pretty close to pulling the trigger on a
Big Agnes Air Core or a
Therm-a-Rest NeoAir Trekker when I did one more search on ideas as to how to find leaks in Exped mats. My search turned up a post at the
Backpacker forums where it was recommended to use warm to hot water; water at a temperature you can get your hand in so not too hot, but still hot in a bath or tub and then dunk the inflated mat.
Well blow me down it worked! I found a leak on a part of the mat that I had tested more than once in cool water and
Mainpeak had also tested for. So now I have repaired the hole and hopefully it will stay inflated overnight and my wallet is happy to
Posted: Tue Mar 26, 2013 12:29 pm
by Benfruns
I use a Kathmandu 25mm inflatable mat, and it's awesome. Slept on a rocky cliff with it, didnt feel anything - might post a pic from home later. Had no troubles with it. Rolls down very small, and is light. The pillow from Kathmandu, however, sucks. Doesn't stay inflated (found out on a trek to everest base camp, the sealant around the valve has degraded), takes up too much room, and is extremely uncomfortable. I used to use the inflateable pillows from Big W - light, takes up less room than my spare jocks, and it's $5, so I'll probably be going back to that.
Posted: Thu Apr 04, 2013 9:07 pm
by bumblebea
For a mat I use a 3/4 length thermarest for fast and light trips and I augment this with a full length strip of that bubble wrap style building insulation for longer and colder trips.
where do you get this bubble wrap stuff from? it sounds good.
Posted: Thu Apr 04, 2013 9:20 pm
by Aushiker
bumblebea wrote:For a mat I use a 3/4 length thermarest for fast and light trips and I augment this with a full length strip of that bubble wrap style building insulation for longer and colder trips.
Officeworks is one source.
Posted: Thu Apr 04, 2013 10:05 pm
by wurtulla wabbit
Hammock.
Posted: Thu Apr 04, 2013 10:16 pm
by Aushiker
wurtulla wabbit wrote:Hammock.
Great idea if and it is a big IF there are good opportunities to actually set it up. Wouldn't work so good here for example ...
Posted: Thu Apr 04, 2013 10:27 pm
by wurtulla wabbit
Yeah bit there so adaptable. Tie ropes off to anything solid.
Fence post.
Tree trunk
Branch
Towbar of 4by (done this one)
Lamp post
Keep you off the cold deck
Great photo by the way
Posted: Fri Apr 05, 2013 11:42 am
by il padrone
wurtulla wabbit wrote:Yeah bit there so adaptable. Tie ropes off to anything solid.
Fence post.
Tree trunk
Branch
Lamp post
Been there - no such luck.
"Where was that lamp-post Rob??"
What keeps me off the cold deck is this:
Posted: Sat Apr 06, 2013 8:13 pm
by Cheesewheel
Bad idea IMHO.
I tried using one during a 2 week tour once and regretted it every evening.
Sleeping posture in a hammock is painfully similar to one's riding position. And if the temperature is anything close to making you think about the type of sleeping bag you are bringing, you will also get these cold drafts on your back that make the prospect of a bad night's sleep even worse.
I had a small thin woolen blanket that I used to lay on (and which is a real work out to get positioned correctly as you wiggle around in the hammock). Sometimes I even use a small inflatable mattress .... which I guess defeats the purpose of looking for a mattress alternative ....
That said, I still use it occasionally when I do the odd quick 1 or 2 nighter spin.
Posted: Sat Apr 06, 2013 8:34 pm
by wurtulla wabbit
Dunno if you can get them here but to kept my para regt gear and the sleeping bag is top notch. Yes, it's 22yr old and still in perfect nick.
Slept in it for 6 wk exercise, nov/Christmas about 3 deg to about -15.
Find somewhere flat, throw down some pine needles or branches etc , good to go !
Just want that barrier between you and the deck, even if its 2mm thick.
Posted: Sat Apr 06, 2013 9:16 pm
by il padrone
wurtulla wabbit wrote:Find somewhere flat, throw down some pine needles or branches etc , good to go !
Good grief! That was the bedding technique of the mid-70s (don't forget digging the hip-hole)...... before they came out with the 'revolution' of closed-cell foam mats. They seemed like luxury by comparison to the pine needles, leaves and moss.
My current sleeping mat is 2-3 generations further on from the closed-cell mat. You can keep your pine needles
Posted: Sat Apr 06, 2013 9:59 pm
by wurtulla wabbit
Parachute regt breacon beacons and mt snowdon mid winter.
Not for school teachers ill padrone, only real men.
