Rinko Bags and Australian public transport?
Postby Vintagetourer » Fri Aug 14, 2015 9:31 am
An example of one here
https://www.compasscycle.com/shop/bags/ ... rinko-bag/" onclick="window.open(this.href);return false;
The question is, has anyone tried these for combining cycle-touring with bus/train in Australia. With a full-sized, non-folding bike?
Re: Rinko Bags and Australian public transport?
Postby just4tehhalibut » Fri Aug 14, 2015 10:25 am
Essentially, it might help you using a Rinko bag but it'd be better if you could pack it down smaller than just wheels, fork and handlebars slashed across the frame, and into a discreet bag that won't identify the contents or bike shapes like the wheels.
Postby Vintagetourer » Fri Aug 14, 2015 12:55 pm
Thanks for the tip not to label the bag 'BIKE'
Perhaps a big label such as GRANDMA'S ASHES or SINGLE MALT SCOTCH would distract transport officialdom enough to get the bike onto verboten transport systems.
- RonK
Postby RonK » Fri Aug 14, 2015 1:14 pm
As for suburban services - you have a bike, why do you need 'em.
Postby Vintagetourer » Fri Aug 14, 2015 1:32 pm
But believe it or not, Canberra to Sydney is not serviced by an Intercity service. I don't think NSW rail has worked out that a national capital with 340,000 people has popped up on the Monaro. It's a real palaver trying to get a full sized bike onto the Can-Syd train service. Much easier to take a bus.
And I'm talking mostly about NSW, and what used to be called CountryLink. Not sure what it is these days.
Like for example last year I cycled from Canberra to Tamworth on my Thorn Audax. To get home by train with my bike would have been a pain in the proverbial. The Intercity only goes as far as Scone. After that one is at the mercy of a a bike unfriendly XPlorer service.
Thanks goodness a friend's wife brought my bike home in her car, and I flew home on a cheap airfare. Bugger the train:)
- il padrone
Postby il padrone » Fri Aug 14, 2015 5:18 pm
However there is the plus that if you can make your bike look just like a case or package then you will not be charged an additional transport charge. This Rinko bag may be enough to avoid charges.
Postby Espresso_ » Fri Aug 14, 2015 5:23 pm
I'm not sure mine would take anywhere near as long but your point is taken - it takes more than 15 mins!!il padrone wrote:If you can "reduce your bike to a neat, small package" like that in 15 minutes, then you are doing a lot better than I can do. Such a pack-down would take me at least 60-90 minutes.
I thought the point of Rinko bikes were that they were specifically built to be able to be broken down in that way easily?
E
- il padrone
Postby il padrone » Fri Aug 14, 2015 5:52 pm
- front wheel
- front mudguard (3 fiddly bolts)
- front racks (4 fiddly bolts)
- headlight
- handlebar, at times, or reposition it. And Klickfix bar-bag mount.
- seatpost and saddle
- pedals
Then secure all of these within the bag in a manner that they do not get damaged. It does take about 45 mins. I think the 90 mins mentioned I was thinking of doing two bikes when we went to Italy.
Postby Vintagetourer » Fri Aug 14, 2015 8:03 pm
I think quite a few of us have tried the Ground Effect bags, or various other heavy duty bags. They are great, but they are a step up from Rinko in weight ... and in bike protection.
My curiosity is much more about the bike as accompanied, supervised luggage situation. That is the bike being close and preferably in sight during the journey albeit lightly covered. If it was on a train, ideally it'd be in the same carriage as me. On a bus, I would see where it went into the luggage hold.
My understanding of the Rinko concept is that it is about protecting other luggage and passengers from the bike's real or imagined grime. A Rinko bag doesn't look like it'd protect the bike from much. Well...protecting bikes from the glare of rail or bus staff might be the main advantage.
Postby just4tehhalibut » Fri Aug 14, 2015 11:43 pm
Rinko has its uses, a skill to learn perhaps. However all you'll be doing is trying to find ways to make your favoured tourer break down a little better or faster, and fill a niche in the choice of 'folding' bikes. Small-wheeled folders will do it better for inner city and the normal frames with Ritchey breakaway or S&S-couplers for most else. The prepartion that they did in the BQ articles was sort of a denial that they really needed to just buy proper 'folding' bikes, all those modifications and component choices and they still couldn't get their bikes to pack as well or as small as my S&S-coupled tourer. So, are you in denial too?
- il padrone
Postby il padrone » Fri Aug 14, 2015 11:56 pm
Postby Vintagetourer » Sat Aug 15, 2015 8:04 am
The BQ article was more about a frame builder-randonneur showing off their craft, inventiveness and willingness to experiment with design. There wouldn't have been a story for BQ if he'd opted for S&S or a folder. Sure he could have taken the easy, commercially available option but bike tinkerers don't do that if they can find an excuse to play with the TIG welder. For them, it's all about the design & build process.just4tehhalibut wrote: The preparation that they did in the BQ articles was sort of a denial that they really needed to just buy proper 'folding' bikes, all those modifications and component choices and they still couldn't get their bikes to pack as well or as small as my S&S-coupled tourer. So, are you in denial too?
I have a Bike Friday NWT, and it works well with train/bus/plane, but there are tours where conditions/circumstance which don't suit the BF; and I don't want the cost/weight of S&S on my Thorn bikes.
Hence the question about the Rinko bags in the opening post as another option.
The advert for the Compass Rinko bag doesn't mention any need for a special Rinko bike. Their claim is that it will hold a full sized randonneur bike.
- il padrone
Postby il padrone » Sat Aug 15, 2015 8:58 am
- RonK
Postby RonK » Sat Aug 15, 2015 8:59 am
Seems like there is a more relaxed attitude about what is carried as luggage in Japan. The concern is to protect other passengers from the greasy parts of the bike.
Here it seems passengers and their luggage are merely inconveniences, and to be discouraged. It's working.
- RonK
Postby RonK » Sat Aug 15, 2015 9:16 am
It comes in a plethora of configurations - there is one to suit almost everybody.
I like the two-stage fold - stage one quick and easy for public transport, and stage two minimal size for transit.
Postby Vintagetourer » Sat Aug 15, 2015 9:55 am
No firm cycle-touring plan unfortunately Ron. Almost the opposite. Work has kept me too busy to tour for over 12 months.RonK wrote:You've been quiet lately Graham - sounds like you're hatching a plan?
I have been doing a lot of cycle-commuting though and developing a vague Wishlist of Cycle-tours. Like you, I'd love to do some riding in South America and I think one of my big wheeled Thorns would be more fit for purpose over there. Being able to combine the bike with public transport also has appeal.
But the real motive for the opening post was genuine curiosity after reading the BQ articles and seeing the advert for the Compass rinko bag. I know there are numerous options for combining bikes/trains/buses/planes. Rinko is just one.
And ditto for your comment about the lack of customer focus in Australian rail services. No wonder rail is losing passengers. No problem. Let's convert the abandoned rail corridors to rail trails:)
Postby Vintagetourer » Sat Aug 15, 2015 10:10 am
il Padrone I have to confess I also have a Tikit in my bike menagerie. It is excellent and has saved me a fortune in taxi fares.il padrone wrote:The tikit is one answer
Typical use has been for Canberra-Sydney day return trips by bus for work and family stuff over the last few years.
Pattern has been:
-Early morning ride to Canberra Jolimont bus station. Two minute pack/fold into the BF soft bag. Hand it to bus staff and they place it carefully in with the suitcases.
-Arrive at Central. Two minute unpack. Ride to meeting(s) in CBD.
-Late arvo. Ride back to Central. Reverse the process. Home by 7ish.
Saves 4 taxi fares at about $30 each. Over three years, it's saved it's cost. I bought it as a $900 special.
The Tikit is very much a metro bike. Same class as a Brompton. Folds quick and small. I wouldn't try it for long distance touring.
- Thoglette
Postby Thoglette » Sun Jul 03, 2016 5:05 pm
Postby Virgil Walker » Wed Sep 21, 2016 10:00 am
- Bendo
Postby Bendo » Wed Feb 08, 2017 3:54 pm
All this I'd do if I had faith in the rail network. The one time I took a bike from Southern Cross to Bacchus Marsh it was great: dedicated space for bikes at the end of the carriage and a helpful conductor. I'm not sure that's such a common experience... b
