My reynold 653 i pick up
Brett3938
Re: My reynold 653 i pick up
Postby Brett3938 » Sun Oct 21, 2018 8:09 pm
P!N20 wrote:^ I admire your diligence, but I think we can safely say it’s a Hopkins based on the evidence at hand.
I’ve said it once and I’ll say it again; that fork is a thing of beauty.
Thanks for that and i know what we all think it should and points to any yes they are a nice fork and will be better when i strip them back and paint them there powder blue
Brett3938
Postby Brett3938 » Mon Oct 22, 2018 6:58 pm
Did a bit more work on the frame today its now all undercoated and i have taken the races out of the head tube now as well and you can really see the powder blue in there now
NASHIE
Postby NASHIE » Mon Oct 22, 2018 8:38 pm
For when you know what she is, cyclomondo does most decals.
http://cyclomondo.net
Frame weight compares to Reynolds 753 tubing ?
Derny Driver
Postby Derny Driver » Mon Oct 22, 2018 9:26 pm
NASHIE wrote:For when you know what she is, cyclomondo does most decals.
You need to read the whole thread Nashie.
Its a Kerry Hopkins - Columbus tubing
Brett3938
Postby Brett3938 » Mon Oct 22, 2018 9:30 pm
Thanks Derny driver
Postby QuangVuong » Mon Oct 22, 2018 9:57 pm
I’m quite certain it is a Kerry Hopkins. But it’s not necessarily Columbus. Fork tips and dropouts are Columbus branded(as with a lot of his frames), but Kerry could have used any tubing.
Brett, have you tried calling the shop and talking to Kerry?
NASHIE
Postby NASHIE » Mon Oct 22, 2018 9:59 pm
Fair call, i did read whole thread. Just posting link to decals and tubing seems undecided ......... Columbus tubing what ?
NASHIE
Postby NASHIE » Tue Oct 23, 2018 7:03 pm
Never owned a reynolds frames so havent taken much interest in them, but based on the obvious (sticker)....yes replaced, and frame weight Im putting my money on reynolds 653. Bit of reading and 653 post size can vary from 26.8-27.2 and 27mm isn't unusual. Frame weight is a very light 653 which sounds like were are mix of 753, 531 tubing. Not SLX and SL frames i have are all over 2kg frame only.
Roisin79
Postby Roisin79 » Mon Oct 29, 2018 10:24 am
NASHIE wrote:Never owned a reynolds frames so havent taken much interest in them, but based on the obvious (sticker)....yes replaced, and frame weight Im putting my money on reynolds 653. Bit of reading and 653 post size can vary from 26.8-27.2 and 27mm isn't unusual. Frame weight is a very light 653 which sounds like were are mix of 753, 531 tubing. Not SLX and SL frames i have are all over 2kg frame only.
Your frames must be big then Nash - SL/ and SLX are, if I am not mistaken, usually sub 2Kg. From personal experience, my Rob Bailey SLX at 52cm = 1.9kg, my old man's Paconi 57cm SL at 1.85kg.
Postby familyguy » Mon Oct 29, 2018 10:53 am
Big frames were (from what I can read) more commonly built out of SP, which is a heavier tubeset than SL and aimed at bigger frames.
uart
Postby uart » Mon Oct 29, 2018 1:43 pm
The OP's frame also looks quite big to me though. Judging from the length of the head tube I'd estimate about a 62cm seat tube (C-T).
Brett3938
Postby Brett3938 » Mon Oct 29, 2018 2:23 pm
uart wrote:The OP's frame also looks quite big to me though. Judging from the length of the head tube I'd estimate about a 62cm seat tube (C-T).
What the best way to tell how big it is from what point to what point do u need to know and i can let u know when i get home all new to this sorry
Derny Driver
Postby Derny Driver » Mon Oct 29, 2018 2:31 pm
Hi Brett
Measure the seat tube from the centre of the bolt that holds the cranks and chainrings on, up the seat tube to the top collar where the seatpost sits.
The flat top tube which runs from the seatpost to the handlebar stem is measured from the centre of the tubing it butts into at each end.
You can google it .."how to measure a road bike"
Brett3938
Postby Brett3938 » Mon Oct 29, 2018 2:59 pm
Derny Driver wrote:
Hi Brett
Thanks for that i will have a look when i get home
P!N20
Postby P!N20 » Mon Oct 29, 2018 3:12 pm
Just to illustrate DD's post, see 'seat tube length' below:
Brett3938
Postby Brett3938 » Mon Oct 29, 2018 3:42 pm
Seat tube length is 57 cm
Top tube length is 57 cm
NASHIE
Postby NASHIE » Mon Oct 29, 2018 3:47 pm
59cm Clamont SLX 2.11kg, 56cm Colnago Super SL 2.08kg but does have chrome rear chain and seat stays so could be close to your Paconi less chrome. Not saying its not columbus, just very light. Be interesting to see what it turns out to be.
uart
Postby uart » Mon Oct 29, 2018 4:04 pm
Brett3938 wrote:Thanks
Is that centre to centre (C-C) or centre to top (C-T)?
Many people prefer to measure the seat tube C-T, but it doesn't really matter as long as you specify which it is.
Brett3938
Postby Brett3938 » Mon Oct 29, 2018 4:19 pm
It was center to center
Center to top is 59 cm
