Dem old brakes you see on British movies
- europa
Postby europa » Sat Feb 10, 2007 12:30 pm
- mikesbytes
Postby mikesbytes » Sat Feb 10, 2007 12:47 pm
- Mulger bill
Postby Mulger bill » Sun Feb 11, 2007 3:23 pm
- mikesbytes
Postby mikesbytes » Sun Feb 11, 2007 3:57 pm
I think the metal rod going along the handlebars rotatated to put the brakes upwards. Can't remember how the brake leave action was converted into a rotation.
- Mulger bill
Postby Mulger bill » Sun Feb 11, 2007 4:32 pm
- europa
Postby europa » Tue Feb 20, 2007 2:51 pm
KAREN. I need you. Haven't got something in your supply have you?
I love the way old movies show people wandering along on their bikes. Sure, the reality was that they were so low geared you couldn't get out of the way of a loud sneeze and that after thirty seconds you were soaked with sweat under all that tweed, but by cripes it looks cool, far more so than lycra, drop bars and legs going like blazes
Anyone read Nancy Wake's story? And her monumental bike ride through France to contact other groups? Man was she tough. Still is actually, when you see her interviewed
Postby cludence » Tue Feb 20, 2007 3:01 pm
Karen.
- sogood
Postby sogood » Tue Feb 20, 2007 3:36 pm
I can't quite remember the details of the rear brake system setup but know the calipers were positioned at the chain stay level, just behind the BB.
Postby gsxrboy » Fri Oct 10, 2008 4:45 pm
While in Melb last week I saw an Avon in St Kilda, not knowing what it was, I www-ed and then looked here for any threads !
I took a few iPhone snaps, and seeing this thread is about the very thing I found interesting on the bike, here it is..
- AUbicycles
- Site Admin
Postby AUbicycles » Fri Oct 10, 2008 11:43 pm
I ride the bike occasionally, very powerful and have a nice feel.
Want to know how it works... take a look
Google Keywords: "bayliss wiley" +drum
- Kid_Carbine
Postby Kid_Carbine » Sat Oct 11, 2008 12:17 am
They also produced a 3 speed hub gear with the drum brake, like the one in the illustration, known as model AB if rod linkage operated & ABC if cable operated. [A= 3 speed & when combined with a drum brake was available in wide ratio only, so the letter 'W' for 'wide ratio' was not required]
These units were only ever marked with the code AB.
Rod linkage brakes that pulled the brake blocks up into the Westwood style rims are still produced in some parts of the world & have been in use for the better part of a century.
- AUbicycles
- Site Admin
Postby AUbicycles » Sat Oct 11, 2008 9:52 pm
That would be the ones on the Gazelle.
- mikesbytes
Postby mikesbytes » Mon Oct 13, 2008 10:43 am
gsxrboy wrote:Holy thread resurrection batman !
Are they 28" wheels?
Postby gsxrboy » Mon Oct 13, 2008 1:32 pm
General Specpotatoes-mikesbytes wrote:Are they 28" wheels?
Frame: 55cm (22"), 60cm (24"), Dip brazed.
Wheels: 40-635 (28 X 1 1/2). <------------------ Why yes, yes they are!
Handle: PH/T handle with grips.
Saddle: Scooter type PVC top.
Brakes: Side pull roller brakes.
Chain Cover: 1/4 Chain Cover
- Hally
Postby Hally » Mon Oct 13, 2008 1:51 pm
i had one 30 years ago. stopped trying to make the front brake work after a while. there are inherent weaknesses in the design...mine was a very cheap bike, so probably the specific engineering was at fault but it did show up the weaknesses in the concept...its all about the way that front brake shoe retains stability in relation to the wheel and the fork...if those brackets you see on the fork of the avon, which hold the bottom of the caliper, come loose or weaken and bend...or if the short rods which slide through the brackets bend or weaken...thanks fer comin'!
i remember it used to spit out the brake blocks too...that may have been about the metal used in the mounting lugs...basically everything has to be aligned evenly to resist the force of the wheel pulling it into the fork...if it gets a little out of line it will twist with painful results...
yep, cable stretch is not an issue...but there are several more diseases suffered by this system which are all at least as bad. cable stretch is easily fixed by comparison to all the things which can go wrong with these brakes
Humber with REAL rod brakes . . .
Postby bridgethegap71 » Mon Oct 13, 2008 11:05 pm
Weren't repro's like the Avons & Gazelle's - they were the real thing.
I'm not worthy to post pics yet apparently so I just want to say that when I rode this bike, the stopping power of the brakes was incredible - much better than you would think. We did pull the bike down completely and also rebuilt the brakes, which were fiddly, but hell did they STOP! The chrome quality was superior to anything we see today too, just a thicker, softer look and this bike would have been very old. I've seen the chrome repro rod brakes on the Dutch Indian repro's deteriorate after only a few years - sad.
- Hally
Postby Hally » Tue Oct 14, 2008 10:14 am
(oh and of course the wheel pulls the caliper away from the fork .)..but it was still a disaster...
but yeah, its down to quality of materials and engineering i guess...
- pvb123
Postby bridgethegap71 » Wed Oct 29, 2008 10:03 am
- pvb123
Postby pvb123 » Wed Oct 29, 2008 10:20 am
According to Wiki, Pigeon have been around since 1950.
"Origins
Flying Pigeon bicycles have a long history. In 1936, a Japanese businessman built a factory in Tianjin which was named “Changho Works†and started to make “Anchor†bicycles. The brand name was changed to “Victoryâ€, and then renamed to “Zhongziâ€. After the Communists led by Mao Zedong came to power in 1949, the bicycle industry was revived. In April 1949, Chairman Mao's heir apparent, vice president Liu Shaoqi paid a visit to the factory and commanded that it become the first bicycle manufacturer in New China. Their workers were aimed to build a generation of strong, durable, light and beautiful bicycle for New China. On July 5th, 1950, the first Flying Pigeon bicycle was produced. It was the brainchild of a worker named Huo Baoji. He based his classic model on the 1932 English Raleigh roadster. The name chosen to represent the most prominent bicycle trademark was an expression for peace amidst the raging war in Korea. The logo is a stylised bird which represents concord and harmony, resting on the initials FP."
Postby bridgethegap71 » Wed Oct 29, 2008 10:22 am
