Re: eBay prices on the rise, good time to sell old junk?
Posted: Tue Feb 25, 2014 8:39 pm
Love that triple pulley-wheel SunTour RD.
BNA - For the Australian Cycling Community
http://www.bicycles.net.au/forums/
Forged dropouts and downtube braze-ons, together with the fluted seatpost and aero levers, are all I can see to indicate that it's a better-than-gas-pipe frame. Photo isn't clear enough to make out much more than that.QuangVuong wrote:Seen that for a while now. I think it was Suntour GPX bits on it. Any thoughts to what the frame is?
Yes, but I think i got around it by setting my address in ebay as well as in PayPal (which normally determines where things are sent) to my MyUS address. Best of luck.frailer5 wrote:Looking at something on US fleabay. Seller has flagged 'Does not ship to Australia'. No probs, I have a myUS A/C in FL, which I use for work and play; consolidate parcels... ship around monthly.
But, looks like fleabay geo-blocks you from even contacting the seller. Anyone experienced this?
Just from the cross over period, I dare say. A bit like seeing 1" threaded forks on O/S tubing through the later 90s.barefoot wrote:The above-the-BB front gear cable routing is a bit unusual to my eye. Everything else says "generic Japanese mid-80s CrMo", but they all usually run the cable through the guide under the BB.
looks original bar the seat. 1988 model.amrjon wrote:Nice looking miyata
http://www.gumtree.com.au/s-ad/wollongo ... 1040056122" onclick="window.open(this.href);return false;
I wouldn't mind owning the road version of the Miyata Century.
Wouldn't want to leave that outside ALDI for too long.
I've seen a few of these in the flesh and they seem well put together, as well as having paint that is pretty resistant to the passage of time. I think in general they were made from Reynolds 531 tube sets so should be robust enough. I'd certainly consider one if it came up in my size.frailer5 wrote:A TREK330 in Sydney. What were they, 4130 sorta stuff?
Interesting. To satisfy my own curiosity I've messaged the seller and asked for a TT measurement, as well as HT. Yes, I described what to do... I'll post here if they get back to me.rangersac wrote:I've seen a few of these in the flesh and they seem well put together, as well as having paint that is pretty resistant to the passage of time. I think in general they were made from Reynolds 531 tube sets so should be robust enough. I'd certainly consider one if it came up in my size.frailer5 wrote:A TREK330 in Sydney. What were they, 4130 sorta stuff?
Why the HT?frailer5 wrote:Interesting. To satisfy my own curiosity I've messaged the seller and asked for a TT measurement, as well as HT. Yes, I described what to do... I'll post here if they get back to me.rangersac wrote:I've seen a few of these in the flesh and they seem well put together, as well as having paint that is pretty resistant to the passage of time. I think in general they were made from Reynolds 531 tube sets so should be robust enough. I'd certainly consider one if it came up in my size.frailer5 wrote:A TREK330 in Sydney. What were they, 4130 sorta stuff?
Second most important measurement on a bike frame, IMO.singlespeedscott wrote:Why the HT?
On an old steel frame with an horizontal top tube it is irrelevant.barefoot wrote:Second most important measurement on a bike frame, IMO.singlespeedscott wrote:Why the HT?
Seat tube length is irrelevant, up to a point, because I can move the seatpost up and down (and buy a longer one if I need it).
Head tube length is important, because there's only so much adjustment you can make to a quill stem, and only so many spacers you can add or remove under a threadless stem.
Top tube length is key, because anything else you change to adjust the length of the cockpit (saddle position WRT cranks, stem length, bar reach) changes ergonomics or handling.
Anything with a short top tube and long head tube has my name on it
Sold for $119, quite high considering the state of it. If it was bigger and in WA I would've pilfered it just for those damn panto forks!!!! [fistshake]LugNut wrote:There's also a ratty looking but very small Nishiki Cresta in Queensland. Seems to be a pretty underrated sport touring bike from what I can see.munga wrote:that nishiki is a bit small for me, but i'm watching it all the same. I know the guy selling it, but he's no dealmaker. 4 bids, all by the first and only bidder, so i expect it to go a bit silly anyway.
At the risk of going OT and getting in trouble again, I call bunkum on that (in a nice way of course ). The problem with that approach is that it gets you the "traditional" position of being ridiculously stretched out which will destroy your back in short order, unless you are able to find an incredibly short stem which might then make the handling twitchy. Plus the larger frame means more weight, so it's lose-lose. When picking a frame having the correct top tube length to allow a comfortable reach is the ONLY measurement of any real importance, whether it's steel or carbon, brand new or a hundred years old. Fashion is fleeting but you only get one spine .singlespeedscott wrote:
Old steel frames should be fitted like they were intended, not forced to fit like some modern bike. Their handling characteristics are not the same as a modern bike.
The measurements that matters the most with old steel bikes is the centre of bottom bracket to the top of the set tube. Top tube length is usually accommodated by adjustment in stem length.
If your old steel frame requires you to use a seatpost with more then 15cm of extension it's to small. Quill stems such as Cinelli and Nitto only give you about 7.5-8.5cm of max extension. Add about 3.5cm for the headset extension above the top tube and your done. Work out how much saddle to bar drop you like and go from there.
ie say your preferred saddle height is 76cm and you like a drop of 70mm you really should be looking for a steel frame with a seat tube c-t top measurement ranging from 57cm to 60cm.
But back in the day, they didn't make every bike in 15 sizes. They'd make small, medium and large. And many of them had the same TT length for all 3 sizes.ldrcycles wrote:At the risk of going OT and getting in trouble again, I call bunkum on that (in a nice way of course ). The problem with that approach is that it gets you the "traditional" position of being ridiculously stretched out which will destroy your back in short order, unless you are able to find an incredibly short stem which might then make the handling twitchy. Plus the larger frame means more weight, so it's lose-lose. When picking a frame having the correct top tube length to allow a comfortable reach is the ONLY measurement of any real importance, whether it's steel or carbon, brand new or a hundred years old. Fashion is fleeting but you only get one spine .
How and why does a modern bike handle differently to an old steel bike?singlespeedscott wrote: Old steel frames should be fitted like they were intended, not forced to fit like some modern bike. Their handling characteristics are not the same as a modern bike.
