Would it be a sacrilege....
Postby triode12 » Thu Jun 28, 2007 5:34 pm
to put new 2007 parts on a restored 80s bike?
Or should I try and track down NOS 80s parts for it? which would be a hassle I would think.
triode12
by Forum Ads » Thu Jun 28, 2007 6:02 pm
Postby LuckyPierre » Thu Jun 28, 2007 6:02 pm
It depends. :wink:
In my opinion, a 'restoration' would be an attempt to return a bike to its former glory, so contemporary parts wouldn't really fit in - I'd be chasing 'new old stock'.
I've 'refreshed' a late 80's / early 90's Shogun Katana. 'Tojo' now wears 9-speed components - predominantly Ultegra, with 105 brake calipers and hubs.
I'm also 'rebuilding' (well, building actually because the frame has never been built up before) a late 80's Hillbrick with a Campagnolo Record groupset. It's 9-speed because I fluked it on eBay - the photos showed the shifter levers which are pretty scratched and must have scared bidders off, but they're readily replaced (and they worked just fine when I put them on Tojo as a test bed). The rest of the components have normal usage wear, but no damage. Because of the age of the frame, I have to get the rear stays 'reset' so that contemporary hubs will fit - but because it's a Hillbrick, the guy who built it is only an hour and a half away. :). I tossed up whether to build it using a 'period' Campagnolo groupset, because components are still pretty readily available as used or NOS, especially from the US or Europe. In the end, I decided that I would use reasonably recent gear and transition to contemporary components over time.
So, a lot of drivel and no real answer. :? My advice is to decide for yourself what you want to do and do it.
LuckyPierre
Postby Kalgrm » Thu Jun 28, 2007 6:09 pm
LuckyPierre,
Contemporary means parts from the same time period as the frame. Do you mean today's current parts when you say "contemporary parts wouldn't really fit in"?
Graeme
Kalgrm
Re: Would it be a sacrilege....
Postby europa » Thu Jun 28, 2007 6:39 pm
triode12 wrote:to put new 2007 parts on a restored 80s bike?
No, it wouldn't be sacrilege, but it wouldn't be a restoration either. It would produce a very nice road bike upon which you will travel great distances and which will become a good friend ... if you do it properly of course, but it won't be a restoration.
Of course, you'll have to spread the rear forks to take the modern rear wheels ... but that can be done (and you can ruin frames in the process).
So, do you want a nice bike to ride or a restored 80's bike? Horses for courses mate, but you won't get a good, butted steel frame for less than a second hand 80's bike.
europa
Postby LuckyPierre » Thu Jun 28, 2007 8:51 pm
Kalgrm wrote:Contemporary means parts from the same time period as the frame. Do you mean today's current parts when you say "contemporary parts wouldn't really fit in"?
Oh no Graeme, you've picked on my understanding of language - them's fighting words! :wink:
As I understand it, 'contemporary' is used to refer to something that is characteristic of, or belonging to, the present. On the other hand 'contemporaneous' is used to refer to things occuring in, or belonging to, the same period of time.
So, by 'contemporary', I was referring to components of current, or reasonably recent, design. 'New old stock' components would be 'contemporaneous' ones. :wink:
For 'restoration' I would advise that triode12 use 'new old stock'. To build a damn fine bike that would ride very sweetly and weigh only a kilogram more than one with a carbon composite frame, I would advise the use of the components that you prefer from those currently available. :)
ps. I'm not really fighting. I've had a long day, with extended periods of choosing both my written and spoken words very carefully. Now, with a glass of Coopers Stout close at hand, it is time to relax - if only I could get carefully crafted language out of my head!
LuckyPierre
Postby mikesbytes » Thu Jun 28, 2007 9:14 pm
It's your bike, do whatever you want with it.
Are the 2007 parts compatible ?
I've got stuff on ebay
mikesbytes
Postby Kalgrm » Thu Jun 28, 2007 9:19 pm
Now you've got me reaching for the Macquarie Dictionary on my bookshelf! :roll: Anyway, it has four main definitions, the first two are as I've said, the next two are as you've said. Where does that leave us?
Well, you're drinking a Coopers Stout - the drink of champions throughout Oz - making you the supreme authority in my view. I bow to your wisdom. I will also defend your honour to the death should someone else question your carefully crafted language! :D
Graeme
Kalgrm
Postby LuckyPierre » Thu Jun 28, 2007 9:25 pm
Kalgrm wrote: ... you're drinking a Coopers Stout ...
Who said anything about a Coopers Stout?
LuckyPierre
Postby Kalgrm » Thu Jun 28, 2007 9:38 pm
You did .... or do you have two straws? :)
LuckyPierre wrote:ps. I'm not really fighting. I've had a long day, with extended periods of choosing both my written and spoken words very carefully. Now, with a glass of Coopers Stout close at hand, it is time to relax - if only I could get carefully crafted language out of my head!
Kalgrm
Postby LuckyPierre » Thu Jun 28, 2007 10:00 pm
I referred to '... a glass of Coopers Stout ...', which should not be taken to imply ' ... drinking a Coopers Stout ...' in anything other than a temporaneous sense.
Yes, gentle readers, more than one glass has passed my lips - but enough, of banter anyway, let us return to more significant discourse.
ps. don't ask me why I channelling one of the Bronte sisters, because I don't know!
LuckyPierre
Postby MichaelB » Fri Jun 29, 2007 9:52 am
Re the sourcing of NOS parts. There is a mob on USA EBay (probably many others) that have a lot of gear like 5/6 speed casseettes etc
Bicycle Reatreat - Ebay
Here is a link to their stuff for sale. 940 items listed atm.
I bought some long fingered LeMond gloves to match the bike, and the quality and service were great.
MichaelB
Postby triode12 » Fri Jun 29, 2007 4:43 pm
Thanks to all who replied for the advice and information! :)
triode12
Postby triode12 » Fri Jun 29, 2007 4:44 pm
mikesbytes wrote:It's your bike, do whatever you want with it.
Yes to a certain extent.
Apparently bolts can be removed from both ends of the newer hubs to make them fit into the narrower rear forks.
triode12
Postby mikesbytes » Fri Jun 29, 2007 4:58 pm
I might try that tonight
mikesbytes
Postby triode12 » Sat Jun 30, 2007 3:14 pm
Hi Mike,
I was wrong - not bolts but spacers. And you may have to redish the rear wheel if the rear forks are 126mm and you remove the spacers.
Sorry for the misinformation. I checked with the friend who had told me before.
triode12
Postby mikesbytes » Sat Jun 30, 2007 4:06 pm
Hi Mike,
I've got a spare 9 speed wheel that has a small bolts on each end, I was thinking whether the bolts were just spacers or actually held the wheel together. Only one way to find out.
mikesbytes
Postby GaryF » Wed Jul 11, 2007 6:46 pm
If you remove spacers/nuts/etc to reduce the 'across locknut width' for a 130mm hub to fit a 126mm frame...you will have to reduce the length of the axle and you might have to alter the quick release as well.
GaryF
