Shogun Appreciation Society
Re: Shogun Appreciation Society
Postby skyblot » Sat Jul 18, 2015 8:40 pm
Postby coolbull » Mon Jul 20, 2015 12:08 am
Sample photo from internet.
Postby davidfntau » Mon Aug 10, 2015 4:40 pm
The frame dimensions are perfect for me but she's done many miles and getting very long in the tooth. The bottom bracket is due for another replacement and I'm tossing up wether or not to keep her. Having found this forum I don't think I can part with the bike!
- yugyug
Postby yugyug » Mon Aug 10, 2015 8:03 pm
I'd give it a strip down, clean and rebuild with new wheels, saddle and bar tape.
Postby davidfntau » Tue Aug 11, 2015 11:30 pm
Postby Mediocratus » Sun Aug 16, 2015 6:03 pm
If one tyre blew out I would have a very good look at the other one. They are probably the same age. It might be safer to get a pair of new tyres. Rubber items don't last forever. They go hard, crack and perish after about ten years. Perhaps less if left in the sunlight. A new set of brake blocks might be a worth while investment also. They shouldn't cost much.davidfntau wrote:Well I rode it to work today and after the front blew out my priority was a new tire and tube.... Next will be the bottom bracket and if it roles straight that'll do. Rat bike
Postby floody » Sun Aug 30, 2015 6:14 pm
Postby calblam » Thu Sep 10, 2015 2:00 pm
So I would like to make it shine and rebuild it as my cross-townie (to complement the single speed now that I no longer have a car).
It has tektro cantis and original 27" wheels. Would like to convert from 27" to 700c wheelset.
Guys at LBS said at a glance it wouldn't work with the cantis, but I am not convinced. I have seen references to it being possible but not finding a resource pointing to what might work or how I can work out what might work.
Any ideas out there? Would prefer to stay with cantis, of some sort, but its not the only option I guess. Definitely do however want to get away from 27".
- yugyug
Postby yugyug » Thu Sep 10, 2015 2:48 pm
- singlespeedscott
Postby singlespeedscott » Sat Sep 12, 2015 8:21 pm
It depends on what brand of canti's you use. Some models may have enough adjustment in them to reach down to the 700c rimscalblam wrote:I have an early 80s Shogun Alpine GT - Japanese, Tange. All of the drivetrain and gears (that sugino cycloid touring stuff) is running really nice!
Postby calblam » Sun Sep 13, 2015 4:27 pm
It works! Had a 700c on the front today. All good, room to adjust. Sadly though, the reach is not faring well for me. 56 seat tube, 57 top-tube. Just a tad too much for me with the drops, which is what I really want for this bike. It's going back up to flea bay or via the forums here. I'm a bit sad its pretty sweet (as a bit of a sad nut for vintagey things) but NQR for my needs.singlespeedscott wrote:It depends on what brand of canti's you use. Some models may have enough adjustment in them to reach down to the 700c rimscalblam wrote:I have an early 80s Shogun Alpine GT - Japanese, Tange. All of the drivetrain and gears (that sugino cycloid touring stuff) is running really nice!
Postby coln72 » Fri Sep 18, 2015 12:59 pm
The first one is a Shogun Samari that I bought for my wife to compete on back in the 2000's.
The second Shogun in a 1980's Sport that was given to us. I have been slowly rebuilding it for my son to ride. It features a Tange frame, Araya rims, Simano STS(?) shifter/derailer. It seems to be a very unusual bike as it has a a 27 x 1 1/4 rear rim and a 24 x 1 1/4 front rim. Unfortunately, now where I tried could supply a tyre to suit the original front rim, so that has been replaced with a 24 x 1 3/8 rim and tyre. Everything else, apart from a couple of gear cables, has been polished up and reused.
Postby commando » Sun Sep 20, 2015 11:40 am
I picked up a Prairie Breaker frame from Adelaide Community Bicycle Workshop, where I volunteer, and just want to get an idea of what year and model it might be. I've checked out some of the online catalogues but not getting an exact match. I think it's a 'Pro', as that's what the ST sticker says, but not sure if that's to do with the 'Tig' welding etc. The FD cable routes along the TT and then down the ST and through a pulley near the bottom (I have the wheel). The frame is in pretty rough shape and worse still is the seat post which appears to be way too big and is well stuck. Check out the photos:
Postby beclewis » Fri Sep 25, 2015 5:27 pm
Always kept inside, so is in perfect condition! It's now my about town bike and have converted it over to a single speed.
Postby floody » Mon Sep 28, 2015 12:52 am
Reckon it's a 1991 Prairie Breaker Pro. I imagine it would take a 26.8 post. Any idea if the rear brake mount is for a U-brake or canti?commando wrote:Hey Guys,
Basically it's the point between the Trail Breaker and the Japanese made Prairie Breaker Team Issue; still made in Taiwan ROC like the Trail Breaker 3, but nicer tubing, detail and geometry more like the Prairie Breaker Team Issue.
Postby commando » Mon Sep 28, 2015 8:58 am
Cool, thanks Floody.floody wrote: Reckon it's a 1991 Prairie Breaker Pro. I imagine it would take a 26.8 post. Any idea if the rear brake mount is for a U-brake or canti?
Not sure what I'm gonna do with it, just couldn't let it go to waste. I've got the little FD cable guide wheel too.
Postby petie » Tue Oct 06, 2015 10:25 pm
Current issues are finding a seatpost binder bolt and seatpost. The frame has recessed bolt holes either side and I haven't even come close to finding something suitable. Does anyone have any links?? Apart from that it's just dithering over whether to build up with the well used 9 speed ultegra group, or give it the royal treatment and buy a new groupset. Thoughts anyone? Hoping to black out as much as possible to counter the fluoro orange....!
Postby petie » Thu Oct 15, 2015 12:12 pm
just bumping this up, I'm drawing blanks at every turn with the seatpost binder bolt....!!!!petie wrote: Current issues are finding a seatpost binder bolt and seatpost. The frame has recessed bolt holes either side and I haven't even come close to finding something suitable. Does anyone have any links??
- gm6046
Postby gm6046 » Thu Oct 15, 2015 7:44 pm
If you have the dimensions of the bits you need I'll machine up some new ones for you.petie wrote:just bumping this up, I'm drawing blanks at every turn with the seatpost binder bolt....!!!!
Postby petie » Fri Oct 16, 2015 11:05 am
WOW! thanks heaps, I'll send you a PM!gm6046 wrote:If you have the dimensions of the bits you need I'll machine up some new ones for you.petie wrote:just bumping this up, I'm drawing blanks at every turn with the seatpost binder bolt....!!!!
Postby Paulfs67 » Fri Oct 23, 2015 8:36 pm
with a few changes
On another note, does anyone have any info about a Prairie Breaker Team Issue with a 24" front wheel?
Postby Champenstein » Thu Oct 29, 2015 7:51 pm
On my Celeste Beau I ended up using an allen nut taken from a v-brake pad with a suitable sized allen bolt. You can get some nice chrome ones too if you look around. Works well and the only thing I found to fit.petie wrote:just bumping this up, I'm drawing blanks at every turn with the seatpost binder bolt....!!!!petie wrote: Current issues are finding a seatpost binder bolt and seatpost. The frame has recessed bolt holes either side and I haven't even come close to finding something suitable. Does anyone have any links??
Postby petie » Sat Oct 31, 2015 6:41 pm
Thanks for that, I discovered that and it got me through until Stu's specially machined nut arrived!Champenstein wrote:On my Celeste Beau I ended up using an allen nut taken from a v-brake pad with a suitable sized allen bolt. You can get some nice chrome ones too if you look around. Works well and the only thing I found to fit.petie wrote:just bumping this up, I'm drawing blanks at every turn with the seatpost binder bolt....!!!!petie wrote: Current issues are finding a seatpost binder bolt and seatpost. The frame has recessed bolt holes either side and I haven't even come close to finding something suitable. Does anyone have any links??
- roosta
Postby roosta » Sun Nov 01, 2015 10:56 pm
Im still yet to date my Shogun Trailbreaker 1 frame, but im guessing the lovely pink factory paint will narrow down the years.
As soon as i get my post count up I will return to post some pictures to help others, and to provide some more eye candy for all the shogun lovers.
Postby coln72 » Tue Nov 10, 2015 3:05 pm
Just wondering if anyone has any decent photos of the Shogun logo on the fork tube or any other logos/stickers. Stupid me forgot to take pictures before the repaint
Any help would be great.
Colin
