What year / model was it? Looks like you mention a Samurai previously?coln72 wrote:Hi all,
Just wondering if anyone has any decent photos of the Shogun logo on the fork tube or any other logos/stickers. Stupid me forgot to take pictures before the repaint
Any help would be great.
Colin
Shogun Appreciation Society
Re: Shogun Appreciation Society
Postby simon.young » Fri Nov 13, 2015 10:14 am
Postby Bcallcott » Sat Nov 14, 2015 8:37 am
1st time poster..
I have recently been given a Shogun Selectra. It is in pretty good nick for its age. I don't know much about these bikes and found this page after a quick search.
What sort of value are these bikes? Should I try and clean it up for a sale? Or are they not worth much as a collectable?
Any advice would be much appreciated
Postby simon.young » Sun Nov 15, 2015 8:14 pm
They are a great solid bike, but not much value - great for a commuter. I paid $180 for a really clean 1990 NinjaBcallcott wrote:Hi
1st time poster..
The Shogun Road Range:
Team Issue
Ninja
Samurai
Katana
Selectra
Postby Bcallcott » Mon Nov 16, 2015 1:01 pm
- familyguy
Postby familyguy » Mon Nov 16, 2015 1:31 pm
Shogun 1000
Tange Champion 2
61.5cm centre to centre seat tube
55cm centre to centre top tube
Shimano EF rear dropouts, fork ends are unstamped
Takes a 27.2 seat post, and has a somewhat unique binder bolt arrangement (which I have yet to sort out)
100mm front, 126mm rear
Most 1000 models I've seen online are touring frames with canti studs and double eyelets front and back. But there are a couple of race style frames like this one. I know nothing of where this would sit in the Shogun hierarchy.
3550gr with headset and sealed BB.
Listed weight of BB is 300gr.
Listed weight of HS is 100gr.
3150gr. bare frame and fork.
Pics:
Postby petie » Tue Nov 17, 2015 2:59 am
- familyguy
Postby familyguy » Tue Nov 17, 2015 11:14 am
Postby JasperJochems » Tue Nov 17, 2015 10:27 pm
https://www.facebook.com/kildalebikes/p ... 7405874026
thanks!
Postby coln72 » Wed Nov 18, 2015 4:31 pm
The Samari is my wife's bike. The bike I'm chasing the logo's for is a Shogun Sport (I think). It was red/silver from the factory. Tange frame - stickers on frame and forks. As for the year, I don't know. It has a 27" rear wheel and a 24" front wheel, 5 speed rear cluster and SIS shifter on the rear cluster only. Hope this info helps.simon.young wrote:What year / model was it? Looks like you mention a Samurai previously?coln72 wrote:Hi all,
Colin
Postby Aftheref » Thu Nov 19, 2015 4:34 am
What year is it? How do I post photos?
Postby simon.young » Thu Nov 19, 2015 8:45 pm
I can take pics of a 1990 Shogun Ninja, but i think your model maybe later 80s. Look through some of these shogun pages and find another member with something similar...coln72 wrote:The Samari is my wife's bike. The bike I'm chasing the logo's for is a Shogun Sport (I think). It was red/silver from the factory. Tange frame - stickers on frame and forks. As for the year, I don't know. It has a 27" rear wheel and a 24" front wheel, 5 speed rear cluster and SIS shifter on the rear cluster only. Hope this info helps.simon.young wrote:What year / model was it? Looks like you mention a Samurai previously?coln72 wrote:Hi all,
Colin
viewtopic.php?f=23&t=21141&p=1201950#p1201950" onclick="window.open(this.href);return false;
- roosta
Postby roosta » Sun Nov 22, 2015 1:53 pm
My recently acquired 1992 Trailbreaker 2, 1996 Trailbreaker 3 and early 90's(?) Trailbreaker - in order of pics.
89 Southern Cross Decathelon MKII
95 Giant YukonSE
96 Shogun Trailbreaker 3
09 Shogun Katana
- familyguy
Postby familyguy » Mon Nov 30, 2015 12:42 pm
Brake reach looks like it will suit the front...
But not the rear??
- gm6046
Postby gm6046 » Mon Nov 30, 2015 7:27 pm
- grantw
Postby grantw » Sun Dec 06, 2015 6:37 am
- KGB
Postby KGB » Sun Dec 06, 2015 10:20 pm
Pro. Make more and sell them.gm6046 wrote:I had a similar problem on one of my Shoguns. I machined up an adapter to make it sit lower....
Postby adam0bmx0 » Thu Jan 14, 2016 4:53 pm
First job though is to get the corroded Alu seat post out.
Box of bits to build it up with, going with 7-speed RSX shifters;
Frame in generally good nic, no rust, headset spins freely, all BB and derailleur threads fine.
- familyguy
Postby familyguy » Thu Jan 28, 2016 1:04 pm
Pedals are temporary, and the rear brake needs a dropper for the pads to hit rim not tyre. Might have to machine one, or see if someone can make (as above)?
Postby RobertL » Thu Feb 18, 2016 3:36 pm
I think that it is an early 90s model, based on it's components, a quick check on the internet and the general vibe of it.
There are a bunch of decals on it, still in pretty good condition. The head tube says Made in Taiwan. The seat tube says Cro-Mo Hand Welded. The fork says Tangaloy Tubing. And the seat stays say F.I.T. System (whatever that means).
It has 6-spead rear gears with Shimano Altus derailleur. The rear brake is a Shimano cantilever. The front brake is missing.
Do these give any better clues to its age?
The crankset has replaced by Raleigh cranks and single chain ring. That chain ring runs very close to the chain stay. In fact it runs a bit too close and there is some contact damage. I may need to swap that or modify it, if possible.
It also has a pretty good Selle Success aXpero cromoly saddle on it.
In general, I like the idea of this as a general runaround sort of a bike. I know that it's a Taiwanese model, but it's still a decent steel-framed bike that's worth saving, isn't it? The simplicity of the single chain ring and 6-speed rear end make it attractive, too.
Of course, I am not going to ride it with only one brake. I'd like to get the bike up and running as cheaply as possible at first, so as I see it, I have a couple of options:
1. Find a front cantilever brake and lever and put it on. Don't worry too much about whether it matches the back one exactly.
2. Upgrade to v-brakes or mini-v-brakes and levers, given their superiority to cantis.
Am I right in thinking that v-brakes will simply fit onto the same threaded attachment lugs that the cantis go on? And that the only difference between choosing v-brakes vs mini-v's is whether mini-v's can clear whatever size rim and tyre is on the bike? But that I need to make sure the levers suit v or mini-v? If so, then I might look for a cheap set of mini-v's, preferably donated from the proverbial "skip" bike.
The front fork and rear frame also have drilled holes for caliper brakes. However, they look like they are too far away from the tyre/rim to be of any use. Were these frames ever made with larger (700C) wheelsets? If so, then maybe that's an upgrade for down the track.
By the way, the story with this bike is that I started riding to work in the middle of last year. I work in a large office building, with dozens of bikes parked in our bike racks. This bike has been parked, with flat tyres, unmoved and unloved for that whole time. I plan on leaving a note on it to see if anyone knows who owns it, and letting them know that I will buy it off them for the right price. If, as I suspect, know one owns it anymore, then I may just take it for my use.
Postby Mediocratus » Fri Feb 19, 2016 7:06 pm
That could get a bit dicey if the owner turns up a few weeks later. Better to take it to the local police station and hand it in as lost property saying that it has been there for ages and no one knows who owns it. If it isn't claimed you get it back with clear title and no come back.RobertL wrote: If, as I suspect, know one owns it anymore, then I may just take it for my use.
- yugyug
Postby yugyug » Sat Feb 20, 2016 12:29 pm
I have a early 90s trail breaker 1 and while I'm looking for a 3 or higher, it's a solid bike. Well made, but heavy. Perfect for kid transport.
Postby miyoshi » Tue Feb 23, 2016 10:18 pm
I cannot believe how nice it is to ride. My carbon bike just gathers dust in the garage now.
- yugyug
Postby yugyug » Wed Feb 24, 2016 9:40 pm
That's really nice, though you seem to be missing some spokes from your wheels.miyoshi wrote:Early 90's Shogun team issue brought into the modern era. It now has ultegra 6800 groupset, carbon forks with threadless steerer, and modern everything. It only weighs 8.4kgs with everything – not bad for a steel frame!
I'm working on my ninja soon. Will update wheels, fork and maybe drive train to a single chain ring, but I probably won't get it below 10kg because I like spokes too much.
Postby miyoshi » Thu Feb 25, 2016 9:41 pm
You should be able to get under 10kgs pretty easily, depending on the size of your frame, and assuming the ninja is similar. Mine is 54cm (but really its 55c-c) and the bare frame is just under 2kgs. I weighed the bike in its original form and it was about 10.5kgs.
- yugyug
Postby yugyug » Sun Feb 28, 2016 12:07 am
Did you notice any handling difference with the new fork? I'm not sure but it looks like the rake/offset is a littl different on the new fork.miyoshi wrote:Thanks, I actually wanted to go even less spokes but I blew the budget already, and these wheels were a good price.
What did you do with the old one? Was that the original? Can't quite make out the decal.
