Downtube Shifters and different brazeon mount types
Postby mikeg » Thu Sep 20, 2007 11:39 pm
Hi all,
Cutting a long story short in converting a tange DB alloy frame bike from down tube to STI shifters, I have found out there are 2 types of brazeon mounts, the square type which the fit available cable housing stop adapters, and the type that is on this frame, a keyhole shaped brazeon mount.
Now the DT shifters that are on this keyhole type are Shimano 600 friction levers (for 6 speed), and if I don't complete the conversion intended, then I would like to substitute the DT shifters with indexed 6/7 speed type.
And to my question:
Are there indexed type DT shifters that will fit the keyhole type of brazeon mount?
Mike
[edit] Also the thread on the keyhole type is different (doesn't appear to be metric) and slightly smaller in diameter
mikeg
by Forum Ads » Sat Sep 22, 2007 12:46 pm
Postby GaryF » Sat Sep 22, 2007 12:46 pm
I can't recall the keyhole brazeon mounts. I suppose a photo is not possible?
I have some 6 speed Shimano shifters that work with the square based brazeon's and indexed Suntour and Campagnolo that work with square based brazeon's but i've never seen the keyhole type 6 speed brazeon.
My guess would be that the the 6/7 speed down tube shifters only attached to the square based bosses.
GaryF
Postby mikeg » Sat Sep 22, 2007 1:12 pm
GaryF wrote:I can't recall the keyhole brazeon mounts. I suppose a photo is is not possible?
I do have a not very good phone camera shot of the braze-on, but not enough post count
Mike
mikeg
Postby mikeg » Sat Sep 22, 2007 1:26 pm
Mike
Have just taken same better resolution photos
and increase the post count while I am at it
Mike
mikeg
Postby stryker84 » Sat Sep 22, 2007 3:58 pm
Or send them to a moderator (I forget which ones) to help you in posting them.
stryker84
Postby mikeg » Sat Sep 22, 2007 5:43 pm
the style is probably not called keyhole, but the shape somewhat keyhole shaped.
Mike
mikeg
Postby mikeg » Mon Sep 24, 2007 11:55 pm
Lets see if I can now post some images of the braze-on!
Did not work this was post no 11
Mike
mikeg
Postby mikeg » Mon Sep 24, 2007 11:57 pm
mikeg wrote:Lets see if I can now post some images of the braze-on!
Mike
Mike
[edit] Hooray, finally!!!
mikeg
Postby Minority » Tue Sep 25, 2007 3:32 pm
Hi Mike,
I am fairly sure that the indexed DT shifters I had to go with some Shimano RSX stuff were that style mount. I'll check when I get home tonight.
Minority
Postby GaryF » Tue Sep 25, 2007 5:08 pm
Minority wrote:Hi Mike,
Mike, thanks for the photo's - I haven't seen them before. I'll be interested in what Minority turns up.
GaryF
Postby Minority » Wed Sep 26, 2007 2:58 pm
Sorry Mike,
Obviously my memory is failing along with the rest of the body!
I would think you could carefully file the Shimano shifter to fit the "keyhole" protrusion, but not as standard.
Good luck with your hunt!
Minority
Postby MichaelB » Wed Oct 17, 2007 11:03 am
These look very similar to the style of braze-ons that I have seen on a late 90's Steel Cinelli frame.
Some people think that you can get adjusters to suit these so that you can use the modern day shifters - is this true ?
MichaelB
Users browsing this forum: redrover3
