Idiots guide to salvaged 80s roadiesRe: Idiots guide to salvaged 80s roadiesRear derailleur is 1989 model, front derailleur is 1988 model, I cant remember if they label the cranks with the same serial coding, but if they did the cranks are 1976, since they didn't do Edge until the mid to late 80's I'd guess the cranks aren't 70's, I'd hazard a guess that the gruppo is probably the standard ones (considering it's all Suntour 4000 series Edge) so I'd date the bike as around '89 or probably very early 90's.
Hi Zynster, saw this post a while back too and I'm seeing some Victory tri-a similarities here. Like others have mentioned it's def worth putting some time into. I think Wal42 has zoned in pretty close with the diag and the resto advice! Personally I'm thinking the original seller was actually spot on, it looks very very much like an original 89-90 Victory - sans wheels and paint! Suntour 4050 edge gruppo / dia compe "edge" brakes Accushift '7' speed shifter (series 1 shape) "strong" seatpost 26.4mm seat stay under-slung cable guides on top tube - bias left 1/2 filled dropouts Pump nipple Unicrown Ovaltech rings 52-42 (standard) 2nd set of bottle mounts (post 1988 tri-a) Sakae stem and bars 10.7 kg here.... lots of boxes ticked! some similar piccies in original coats (2 bikes to compare) bike #2 ![]() #1 original rings ![]() #1 "Accushift" 7 spd 1989 ![]() #2 "Accushift plus" 7 spd 1990 ![]() #1&2 ![]() #1&2 ![]() Hope this helps cheers, Andrew
Re: Idiots guide to salvaged 80s roadiesThanks Andrew. That looks like a total match. The guy I bought it off wasn't on crack after all.
And thanks Wal for your Suntour expertise. I'm gonna ride it for the time being and look at some new paint further down the track. Fausto Coppi Reparto Corse | Giant Farrago Cross
Who is onlineUsers browsing this forum: jbanh |
