It's a III....I have a couple in the same colour and same spec. Roughly 1985-86.jgs wrote:Greetings Apollophiles
Would anyone else like to venture any guesses about this bike? All I know is it's one of the most comfortable bikes I've ever ridden ..
Jon
Apollophiles - The Apollo Appreciation Thread
- Kermit TF
Re: Apollophiles - The Apollo Appreciation Thread
Postby Kermit TF » Sat Jan 25, 2014 5:49 pm
- Kermit TF
Postby Kermit TF » Sat Jan 25, 2014 6:04 pm
- munga
Postby munga » Sat Jan 25, 2014 6:16 pm
- Daus
Postby Daus » Sat Jan 25, 2014 8:31 pm
- The Fixer
Postby The Fixer » Mon Jan 27, 2014 6:53 pm
Here's my III in the process of shedding its MTB bars and controls (WHY?????) and having them replaced with something more fitting.
I've gone for friction-shifters rather than indexed. Bars are Nitto, Shimano shifters, Weinemann levers.
Shame about the tatty paint (will fix), but she's a nice frame to ride.
Second pic shows the III's brazed-on cable guides.
Third pic is the III with the '87 Clipper and the '88 Delta (Delie).
- The Fixer
Postby The Fixer » Mon Jan 27, 2014 7:15 pm
Pretty sure I haven't posted this one before, so here goes.... here's my 1983 Apollo II.
Planning to return this one to original specs... nice to ride. But those bars/controls...Sheesh! WHY???
Footnote: unlike all my other Apollos, this one's been in regular use since new. It shows.
Apart from a tendency to throw chains (yes, I know, but I haven't gotten around to it yet), it really
does ride like new.
- munga
Postby munga » Mon Jan 27, 2014 7:25 pm
thumbies are silly expensive tho, so i'll have to do some more research (i probably don't need xt spec shifters )
Postby dillyboy » Mon Jan 27, 2014 7:37 pm
look back a few pages - you pretty much have my bikeDaus wrote:My 1993 Apollo Eclipse- I recently updated the shifters with 7 speed Shimano Tourney's and a 7 speed cassette on Wolber rims and hubs I have had for a while. The rear brake cable is hidden in the top tube- I look at the posts on this thread often and have not seen any others the same. It is a big frame and fits me perfectly for commuting duties- it has no rear hanger on the frame just an axle mounted hanger so I figured it is not an upmarket frame. The frame is in original condition its previous owner had it since new and even gave me the owners manual when I bought it a couple of years ago- Don
mine's a 12 speed with down tube shifters though - and its of unknown age but I don't think its as new as '93
- The Fixer
Postby The Fixer » Mon Jan 27, 2014 8:29 pm
dillyboy wrote:look back a few pages - you pretty much have my bikeDaus wrote:My 1993 Apollo Eclipse- I recently updated the shifters with 7 speed Shimano Tourney's and a 7 speed cassette on Wolber rims and hubs I have had for a while. The rear brake cable is hidden in the top tube- I look at the posts on this thread often and have not seen any others the same. It is a big frame and fits me perfectly for commuting duties- it has no rear hanger on the frame just an axle mounted hanger so I figured it is not an upmarket frame. The frame is in original condition its previous owner had it since new and even gave me the owners manual when I bought it a couple of years ago- Don
Were you the bloke with the fluoro-green 'Eclipse'? That one was nice!
Postby dillyboy » Mon Jan 27, 2014 8:37 pm
- Daus
Postby Daus » Mon Jan 27, 2014 8:53 pm
Postby jools » Tue Jan 28, 2014 7:35 pm
I've got an early 80's Apollo IV that I commute on every day. It's pretty much the original running gear - shimano 600 arabesque group set, ukai 27x1 wheel set. It's brilliant to ride, but I'm concerned that I'm inflicting cruel and unusual punishment upon it by commuting every day. I'm a fairly big guy - over 110kgs - and I ride with a backpack full of clothes, shower gear, food etc, so the bike is well loaded down. I had the BB serviced last year as it was making creaking noises and it's starting to creak again under load. Rather than servicing it again I'll probably replace it with a sealed unit, but the bike also needs a new freewheel and possibly chainrings. I haven't snapped a spoke, which is quite surprising.
The frame, forks and headset etc seem solid enough still over bumps and the bits that need replacing are mostly wear and tear items that get replaced anyway, but I'm concerned that I'm loading it up and using more than it's really designed for.
Am I asking for trouble using it this way? or is lugging around fat albert and his sandwiches all in a day's work for the mighty apollo?
- singlespeedscott
Postby singlespeedscott » Tue Jan 28, 2014 10:29 pm
- Paddles
Postby Paddles » Tue Jan 28, 2014 10:53 pm
Postby jools » Tue Jan 28, 2014 11:24 pm
Thanks for the reassurance about riding it, I'll do the BB upgrade soon and see how it goes after that.
- singlespeedscott
Postby singlespeedscott » Wed Jan 29, 2014 7:10 am
If it is a freehub and not a freewheel. You can still make yourself a new one by butchering a new 7 speed cassette. Remove the spacers from the 7 speed body and use five of the new cogs with the spacers from the old cassette as well as the old 13t lock ring.
If it's a freewheel simply take it down to the LBS and get them to pull it off and spin on the new one. The shifting of the new freewheels is a lot better IMO.
Postby jools » Wed Jan 29, 2014 9:30 am
So when you say 'new 7 speed cassette' - are you talking about a current HG cassette? Wouldn't I also need to replace the 13t sprocket?
This is what mine looks like:
Postby Dow Jones Index » Wed Jan 29, 2014 1:09 pm
singlespeedscott wrote:Are you saying that you bike has an early Shimano freehub cassette body? This is unusual. All the Apollo IV's I've come across use freewheels.
My Apolo IV also came with a very early uniglide cassette body. I had it for about 2 years before I realised, kinda threw a spanner in the works so to speak.
Postby jools » Wed Jan 29, 2014 2:09 pm
Are you still running the same cassette or have you upgraded?Dow Jones Index wrote:
- singlespeedscott
Postby singlespeedscott » Wed Jan 29, 2014 2:34 pm
7 speed cassette sprockets are the same width as a 6 speed sprockets. The only difference is the width of the spacers separating the cogs. To make a new six speed cassette you use cogs off a new seven speed cassette with the spacers from your old cassette and the old lockring/cog off the old cassette. This off course depends on how worn the lockring is. But unless your racing crits it's very unlikely that it is as worn as the sprockets in the middle of the cassette.
Postby DarrylH » Wed Jan 29, 2014 4:26 pm
It also shows that I may have assembled that bike. The Cycle Inn was sold and renamed TLC Cycles and later moved about 50m around the corner where it still exists. When I worked there we were about the only bike shop on the south side of Canberra - now there are four within 200m - and I live only 2km away.Second pic shows the III's brazed-on cable guides.
Postby jools » Wed Jan 29, 2014 4:47 pm
- The Fixer
Postby The Fixer » Wed Jan 29, 2014 5:16 pm
Small world, eh? Thanks for that bit of info.DarrylH wrote:It also shows that I may have assembled that bike. The Cycle Inn was sold and renamed TLC Cycles and later moved about 50m around the corner where it still exists. When I worked there we were about the only bike shop on the south side of Canberra - now there are four within 200m - and I live only 2km away.Second pic shows the III's brazed-on cable guides.
If you did assemble it, you did a good job, as it still appears to be largely original, and rides quite nicely.
- The Fixer
Postby The Fixer » Wed Jan 29, 2014 5:21 pm
- Kermit TF
Postby Kermit TF » Wed Jan 29, 2014 7:14 pm
Ive learnt something about the early cassettes...
