The swap meet thread
Postby LG » Sat Sep 17, 2011 4:53 pm
All items used. Interested in swaps only, not sales. If of interest contact me for condition details:
Offer
Raleigh cottered 3 spider cranks - 165mm
Solida cottered non-drive side
Cherry brake levers and calipers
Shimano dual pivot RX100 rear brake caliper
Weinmann 610 centrepull front caliper
Mafac racer front caliper
Dura Ace ex crank set 170mm
46t cottered raleigh "heron" crank set 165mm
Shimano 600 6 speed screw on freewheel (13-18tooth)
drive side shimano selecta crank and chainwheels
AVA alloy stem and steel drop bars - 22.0mm for french forks
165mm 110 BCD Sugino crank set
shimano 500 braze on front derailluer
Suntour V-T luxe rear derailluer
Rigida pro tubular rim (I think its a 36 hole)
Odd spare shimano 6200 downtube shift lever - right side only
Spinaci style bar extentions
Sachs 8 speed screw on freewheel
52 tooth alloy biopace chainring
VP beartrap pedals
1st generation dura ace black shifters
165mm stronglight 49D crank set
Campy rear wheel 126mm hub spacing (unsure of model), mavic tubular rim from memory
54cm frame - lightweight, takes a 27.0mm seat post, nicely cutout lugs, campy fork ends and dropouts. In need of paint, has some dents in the cetre of the top tube, but no bends or cracks
20 inch gold araya BMX rim on a gold high flange sunshine hub
I have some more, but will wait and see what requests others put up in this thread if it takes hold.
Wanted:
an adaptor to turn a single puegeot downtube shifter braze on into both a front & rear shifter (hope this makes sense)
Dust caps for Olimpic 64 pedals (or an idea of where I can find some)
1970's shimano 600 non-drive side crank 170mm
1st generation dura ace brake levers, front derailluer & hubs
non-drive side crank for a zues 2000 partially drilled 170mm
170mm magistroni non-drive side cottered crank
stronglight 49D outer chainring of 46-50 tooth, with 86BCD inner and 30-34 tooth chainring
32 hole dunlop special lightweight rim
decent quality 40 and 32 spoke hubs from the 1950s
shimano 6400 left (front) downtube shifter for braze on
Bugger, I know there's more stuff I'm looking for, but can't think right now. Will add to the list as things come to mind.
LG = Low Gear
LG
by Forum Ads » Sat Sep 17, 2011 9:13 pm
Re: The swap meet thread
Postby rollin » Sat Sep 17, 2011 9:13 pm
interested in gold araya, if its a rear?
rollin
Postby LG » Sat Sep 17, 2011 9:46 pm
Sorry mate, front wheel.
LG = Low Gear
LG
Postby Tasman » Mon Sep 19, 2011 7:45 pm
PM sent
Tasman
Postby LG » Tue Sep 27, 2011 8:06 pm
LG wrote:All items used. If of interest contact me for condition details:
Offer
AVA alloy stem and steel drop bars perfect for a peugeot build - 22.0mm for french forks
VP beartrap pedals
Wanted:
an adaptor to turn a single puegeot downtube shifter braze on into both a front & rear shifter (hope this makes sense)[b]Received thankyou very much[/b]
32 hole dunlop special lightweight rim Another forum member is also looking for some of these, if you have a pair (or more) your happy to part with, please let me know
decent quality 40 and 32 spoke hubs from the 1950s Bayliss Wiley front hub offered, looking for a matching rear
1970s campy record low flange front road hub
Suntour superbe brake callipers
Was planning to update the original post to avoid confusion, but the edit function seems to have disappeared. Also hoping I wasn't the only member of the forum interesting in posting gear for a swap :lol: :wink:
Without turning this into a markplace topic, if you have something on my 'wanted' list, you'd consider selling, please let me know. My preference is for trade in the 'offer' list, but pm me if something takes your fancy.
LG = Low Gear
LG
Postby amrjon » Wed Sep 28, 2011 11:32 am
I've got several non-matching drive / non-drive crank arms, and some single pedals that might be good material for this thread.
When I get some pictures I'll add them.
amrjon
Suntour supurbe cranks
Postby amrjon » Sun Oct 02, 2011 12:16 pm
If anyone has a non-drive side arm that matches my drive side, and is interested in the suburbe pro arm as a swap, let me know and perhaps we could re-unite some members of the suntour family here.
There is some minor scuffing on arm - see the pictures.
Image Image Image Image Image
amrjon
Postby munga » Sun Oct 02, 2011 4:12 pm
hmm.. i don't have an arm for you but i do have a drive side superbe pro arm. what length is yours? uhh. your crank arm.
Postby amrjon » Sun Oct 02, 2011 5:40 pm
Oh yeah, I should have said, both 170mm
amrjon
Postby munga » Sun Oct 02, 2011 7:21 pm
hmm i know mine's not 170mm. it could well be 177.5 afaik, but i know for sure its not 170mm.
when i get my act together, i'll have a few things to post up.
Postby frog » Thu Oct 06, 2011 6:05 pm
Just a random wanted add I though I'd put out there:
I really (really) want a reynolds tubed Peugeot frame with decent paint.
[Dreaming] Ideally it would be the black & red PE 400 with Reynolds tubing[/Dreaming]
I've seen a few lately, but none in my size/location.
Anywhere from 55-57 cm Seat tube.
Thanks!
Edit: I've made a wanted add, see my signature.
frog
Postby LG » Sun Oct 09, 2011 7:17 pm
Another update and I've deleted the items that have gone from the list as well as those received. Gone are the araya BMX wheel, beartrap pedals & suntour VT-luxe RD, received are the dura ace brake levers & FD, as well as the peugeot shifter adaptor. If anybody has a reynolds framed peugeot slightly larger than the one frog is looking for, please let me know :lol:
Will look at purchasing if you have something on my wanted list, and will then likely go to the marketplace thread with some WTS's to make up the $.
LG wrote:All items used. If of interest contact me for condition details/photos etc:
Offer
Wanted:
1st generation dura ace hubs
LG = Low Gear
LG
Postby munga » Sun Oct 09, 2011 7:52 pm
munga wrote:hmm i know mine's not 170mm. it could well be 177.5 afaik, but i know for sure its not 170mm.
172.5mm superbe pro drive side road crank arm. anyone need it, or have its partner?
also have a 180mm stronglight "106" non-drive side arm
WTT/S (SYD) - Good CrMo MTB Frame 18.5" for a larger MTB fra
Postby Velo13 » Tue Oct 11, 2011 10:49 am
WTT/S (SYD) - Good CrMo MTB Frame 18.5" for a larger MTB frame:
All the details here.
Velo13
Postby nsr0772 » Wed Oct 19, 2011 8:50 am
Hey guys,
Will be coming down from Bathurst for the day. Have a few things to sell swap etc. If its ok I will also bring some bikes to sell, my campag 11 equipped pacer. A commuter equipped giant boulder ltd and a ladies twofold steel old style step through bike. All will be very cheap. Also have a child's seat, camelbacks, bars, tyres. Pumps, old tri bars, road and mtb bars and some other odds and sods.
I am not out to profit just wish to sell off stuff cheap to help fund my new Surly LHT. New bike is $1625 FYI.
Hope this will be OK. I'll be the fatty in the BNA cap. Come say hi.
nsr0772
Postby 240ZR » Wed Oct 19, 2011 5:26 pm
If anyone has a Shimano RSX FD, Shimano 600 Arabesque FD, Shimano Golden arrow F & R derailleur's bring them along.
Nick.
240ZR
Postby munga » Wed Oct 19, 2011 8:41 pm
uhh.. this thread is for stuff you want to swap. the sydney swap meet thread is over there, somewhere..
Postby nsr0772 » Thu Oct 20, 2011 4:56 am
Really, I was under the impression it was to list things you would be bringing to the swap meet. My mistake.
nsr0772
Postby LG » Thu Oct 20, 2011 6:43 am
If you don't find an arabesque FD at the swap meet, let me know. I think I have a spare tucked away somewhere.
Wish I was in Sydney this weekend :(
LG = Low Gear
LG
Postby LG » Thu Dec 01, 2011 9:25 am
Quick thread recovery following what appears to be some recent interest. The thread has worked for me and I've now received some airlight hubs, 6400 shifters, DA brake levers & FD, & peugeot shifter adaptor. Gone are the araya BMX wheel, beartrap pedals & V-T luxe RD.
I'll soon be away for a couple months, but if anybody has a spare old campy downtube shifter clamp band, I'll be most appreciative (have levers and fittings, but a broken clamp). Still looking for the other things on my list.
LG = Low Gear
LG
Postby munga » Thu Dec 01, 2011 9:34 am
can we get some sticky action here?
Postby LoveMiyata » Thu Dec 01, 2011 2:16 pm
Hi LG,
Do you still have that 8sp Sachs freewheel?
LoveMiyata
Need a NOS 5 speed freewheel
Postby marc2131 » Sun Dec 11, 2011 9:45 am
Looking for a unused 5 speed freewheel (13 or 14 to at least 24 tooth). Must be compatible with a Campagnolo record hub from the 60s/70s.
Have some 2nd hand ones lying around but too old - keep slipping.
I'm in Sydney.
..... 15km short of a cardiac arrest.
Late 1960s Jim Bundy-built, 531, Nervex Professional lugged Road Bicycle
Early 1950s Alcone 'Road Special'
1986 Team Raleigh Panasonic Replica
Early 1980s Bob Jackson 'Special Tourist'
marc2131
Postby Lark2004 » Sun Dec 11, 2011 3:37 pm
LoveMiyata wrote:Hi LG,
I have one if you're still looking
Lark2004
Postby LoveMiyata » Sun Dec 11, 2011 4:20 pm
for sure, what condition is it? how much would you want for it or is there anything you might be chasing?
LoveMiyata
