The swap meet thread
LG
Re: The swap meet thread
Postby LG » Sat Jan 26, 2013 8:11 pm
I have a Vitus 979 (55cm seat tube 57cm top tube) which is slightly too small :cry: . If the seat tube was an inch longer I'd be happy. Looking to swap for a similar quality frame at 58cm.
LG = Low Gear
metalrideroz
Postby metalrideroz » Sun Jan 27, 2013 1:07 pm
Looking for a late 70s to early 80s 54/5cm-ish frame hopefully with a brazed on centrepull hanger to replace a bent Carlton.
commando
Postby commando » Sat Feb 02, 2013 7:07 pm
Adelaide - FREE to a good home....
Or a not so good home, doesn't matter.
I've got 2 old road bikes that are of no use to me. Not exactly exotica but I'm sure someone can do something with these. They're taking up space in my shed.
Both are a bit rusty.
If you don't want to take them from me for free, I could do with a used set of 27 x 1 1/4, 26x1.9 or 700c road tyres.
Porshe
Roadmaster - Hey, the l/h crank arm still has some protective film on it, chrome is sweet as! That's a plus.
Ferrovelo
Postby Ferrovelo » Sat Feb 02, 2013 8:25 pm
A free Porsche! I'm sure someone in Adelaide will be in touch soon.
http://ajsblogcycle.blogspot.com
(Username changed from amrjon)
commando
Postby commando » Sat Feb 02, 2013 8:41 pm
amrjon wrote:A free Porsche! I'm sure someone in Adelaide will be in touch soon.
Even rarer than the German sportscar, it's a "Porshe". Gotta be worth somethin, eh?
morini
Postby morini » Tue Feb 19, 2013 12:56 pm
I've been offered a damaged Vitus 979 as a swap for my 86 Miyata 1400 Alumitech . The Vitus has loose tubes which I'm assuming just need re-glueing and it's group set is made up of a mixture of Campag, Zeus with a Shimano drive train and maybe Mavic hubs/rims.
It's tempting but I wonder what some of you thought? My Miyata is in pretty good nick and I was thinking of ebaying it anyway.
Chris
Postby Dan » Tue Feb 19, 2013 1:04 pm
Wasn't there discussion on gliders and adhesives for carbon repairs? I think dubrat was on the trail. You're in southern downs - plenty of gliding there, isn't there?
Take the trade- no ebay or paypal fees. That's my 2c anyway :)
morini
Postby morini » Tue Feb 19, 2013 1:52 pm
Yes there is, near Warwick. There's a massive set up at the airstrip for gliding and lots of what look like hanger/residential combos.
This Vitus is aluminium and probably 80's vintage.
Postby Dan » Tue Feb 19, 2013 1:58 pm
morini wrote:Yes there is, near Warwick. There's a massive set up at the airstrip for gliding and lots of what look like hanger/residential combos.
Of course it is! When I wrote carbon I meant alu, honest. Brain fail, apologies.
Lots of steel bikes
Postby Lots of steel bikes » Sat Mar 02, 2013 6:13 pm
Looking to trade this 53cm x 53cm Ken Evans frame for a frame of similar quality in size 60 - 62cm.
Bottom bracket is smooth. 105 headset is rough. Happy to answer any questions. Brisbane area.
Lots of steel bikes
Postby Lots of steel bikes » Sun Mar 03, 2013 6:52 pm
Will trade this Cinelli 101 stem 130mm for a shorter Cinelli stem 80mm - 100mm XA or 101
vaeske
Postby vaeske » Wed Mar 06, 2013 8:20 am
wows, that looks like a nice bianchi reparto course there. got lugs so late 80s?
HappyHumber
Postby HappyHumber » Wed Mar 06, 2013 8:20 pm
Lots of steel bikes wrote:Looking to trade this 53cm x 53cm Ken Evans frame for a frame of similar quality in size 60 - 62cm.
I tell you what - I wish more bikes had this style Cinelli BB shell with integrated cable guides AND the weight saving/drainage holes. My Ken just has a drilled hole with brazed on underside guides.
- Kym
Lots of steel bikes
Postby Lots of steel bikes » Wed Mar 06, 2013 9:27 pm
vaeske wrote:wows, that looks like a nice bianchi reparto course there. got lugs so late 80s?
Well spotted. Yes, late 80s. TSX Superlite tubing. This was my first build a few years ago and is still my favourite ride.
Lots of steel bikes
Postby Lots of steel bikes » Thu Mar 07, 2013 9:29 pm
Should have typed Ultralite not Superlite. Must have ben thinking of the Repco.
Postby munga » Sun Mar 10, 2013 1:36 pm
has anyone got any stronglight A9 headset bits?
i'm looking for a crown race, and a spacer for the top nut.
TedDancin
Postby TedDancin » Sat Mar 16, 2013 2:00 pm
I've got a few bits and pieces that aren't doing much at the moment, thought I'd update my swap list. If anyone is interested in anything let me know, happy to give away the crummy stuff for postage cost if anyone wants it.
Early Dura-Ace (7200?) non aero brake levers, black hoods in great condition, levers scratched up
Generic Shimano non aero brake levers, plenty of patina, no clamp bands
Generic Shimano single pivot brake caliper set, QR thing, recessed bolt
Dia Compe centrepull brake caliper set with straddle cable
Heaps of other bits of brake calipers that I've attacked for parts
Shimano 6 speed SIS light action group - RD with permanently attaced hanger, FD and downtube shifters
Suntour Vx touring groupset - long cage RD, FD, stem mount power ratchet friction shifters, 27" rear wheel with 5 speed freewheel 14-34?
Shimano 600EX Arabesque RD, missing jockey wheels and back plate
Mavic Module E 700c wheelset on Zeus hubs - front true, rear has a couple of flat spots in the rim, just rideable.
Alesa 700c wheelset on KK hubs, both rims true, but rear wheel has two broken spokes. All spokes probably need replacing
Nisi Corsa Toro front wheel on Maillard f20 hub - straight sided internal walls, but pretty sure its not for tubulars
LG
Postby LG » Sun Mar 17, 2013 10:28 am
Looking for 40 & 32 hole 27inch rims. I have to trade amongst other stuff - 28" westwood pattern rims, 36 hole 27" alloy and steel rims (araya, weinmann etc), 26 X 1 3/8 rims, a 650B rim, also a few high or low flange hubs or whole wheels to trade.
LG = Low Gear
frog
Postby frog » Tue Mar 26, 2013 1:33 pm
I'm looking for some Michelin Wildgripper MTB tyres 26 inch in the green/amber combination. I have money to swap! or some random shimano bits and pieces.
My wtb thread in the member to member section:
viewtopic.php?f=25&t=62770
TedDancin
Postby TedDancin » Tue Apr 30, 2013 2:28 pm
Hey team,
I've been noticing this thread doesn't get much love lately, and also been seeing quite a few people looking for small bits and pieces to finish off builds. I reckon between everyone on this part of the forum we'd have almost anything anyone is looking for, so was thinking of trying to revive this swap idea a bit.
Feel free to ignore if you think this is a bad idea, but I think it would be good to keep this going more along the lines of a Retro WTB/WTT thread. Rather than us posting lists of dags we have lying around, people could just ask for things they need and update their posts as they tick things off the list.
I think there's a general spirit of helpfulness and paying it forward on this sub-forum that you don't get through some of the more mercenary online sales sites. I've been the recipient of some very generous people on here, and would like to be a part of the cycle going forward (see what I did there? :wink:)
Anyway, not sure if it would be best in this thread, or in a new one, or in the new WTB sub-forum. Any thoughts?
funnybike
Postby funnybike » Tue Apr 30, 2013 2:34 pm
Yeah, I'll second having something specific in this thread or at least within the Retro section.
I think your idea of making it similar to the WTB or WTT threads is great.
Postby Dan » Tue Apr 30, 2013 2:47 pm
I've posted in the WTB/swap/trade/whatever thread, but you're right, it can just as easily go here.
I have a braze on FD-6401, and require a 28.6 clamp version. Any love?
HappyHumber
Postby HappyHumber » Tue Apr 30, 2013 2:49 pm
The browseability of this thread leaves a bit to be desired, I reckon. :|
- Kym
Postby Dan » Tue Apr 30, 2013 2:55 pm
HappyHumber wrote:The browseability of this thread leaves a bit to be desired, I reckon. :|
Openly editable google doc might address that?
The link should direct to a simple table. Any good?
HappyHumber
Postby HappyHumber » Tue Apr 30, 2013 3:36 pm
Maybe not an open editable doc - too much room for treading on people's toes and the doc being messed up I would reckon.
How about a Google Group or similar where everyone with wares to offer lists bits, say under their BNA user names, in their own document. It's Read-Only to other people, and the owner is responisble for deleting items as obtained or swapped?
Probably other open/free online collaborative tools that might do the job as well.
- Kym
Users browsing this forum: Torana68
