The swap meet threadRe: The swap meet threadA few more bits:
Campy: NR Rear Der - pat76 Victory Rear Der NR Front Der - Braze SR Front Der - Clamp Athena Rear Der - Missing adjust ring from mounting bolt Chorus 10 speed Crank set, 175mm, 53x39 8 speed Ergo shift cassette, 12-21 Shimano 105SC front hub, 36h, NOS Shimano 600 (6400)Front Der, Braze, shop wear only. Handle Bars: Deda Speciale, 31.8, 42cm, Classic bend, shallow drop Deda Newton, 31.8, 40cm, Classic bend, shallow drop Deda Newton, 31.8, 44cm, Classic bend, deep drop, Clamp area has been polished for retro look. Deda Newton, 31.8, 42cm, Classic bend, shallow drop Deda 215, 26.0, 44cm, Classic bend, deep drop Deda 215, 26.0, 42cm, Classic bend, shallow drop, Silver polished finished Deda, 4Girls, 26.0, 36cm, Anatomical bend Ritchey, Comp, Streem anatomical bend, 26.0, 44cm Ritchey, WCS Logic II, Streem anatomical bend, 31.8, 44cm (wet look black) Ritchey Biomax anatomical, 31.8, 44cm, (drops flare out to 46cm at the tips) PedalSoft, Epic, Anatomical bend, 31.8, 42cm Cinelli, Campione del Mondo, 26.4, 66-44cm, Shop wear Cinelli, Criterium, 26.4, 65-44cm, NOS Cinelli, Giro d'Italia, 26.4, 64-42cm, Used Cinelli, Giro d'Italia, 26.4, 64-38cm, Used
Re: The swap meet threadHi Funnybike, can you tell me if the athena rd is 8 speed?
cheers! Scott
Re: The swap meet threadSorry Servicimo
It's an old 1988 model. Pre-indexing. Will work great with some Simplex Retroshift levers and a 6 speed block though...... Probably should have mentioned that in the original post. oops.
Re: The swap meet threadAll good! thanks for letting me know
Re: The swap meet threadTo Trade:
Apollo Allegro Frame with cane creek headset and drop handlebars Mavic ma2cd2 tubular rim 32H Miche Competition Front wheel 36H Suntour rear wheel laced to Mavic MA2 rim Suntour Superbe front brake calliper - nutted Suntour arx rear derailleur Suntour Vx front derailleur – 28.8 clamp Maillard Front Hub 36H – no skewer Cinelli 1a stem 140mm - no clamp bolts or expander bolts Diacompe brake levers and calipers set Shimano 105 BL-1050 non aero brake levers Shimano 105 DT Shifters Shimano 105 HB-1050 F&R Hubs laced to Araya 700c rims 36H Shimano 105 RD-1050 rear derailleur Shimano 105 HB-5600 Black Front Hub laced to Alexrims race 18 white rim 32H Shimano 105 Rear Hub 32H Shimano 105 Golden Arrow DT shifters X2 Shimano 600 fd-6207 front derailleur (LF) X2 – clamp on Shimano 600 rd-6207 rear derailleur Shimano 600 Tri-colour BL-6403 aero brake levers Shimano 600 6400 rear brake single pivot Shimano SL-A500 7-8 speed shifter Shimano RD A350 (MA) rear derailleur Shimano A-351 Exxage aero brake levers 25.8mm seat post 300mm length X 2 26.6mm seat post 250mm length Campagnolo Xenon – F&R derailleur Mirage – Dual pivot brake calipers - recessed Record Road Hubs Front & Rear High Flange 36H Shamal Road Hubs Front & Rear 16H Record/Nuovo Record Front derailleur – clamp on. Continental Gatorskin 700X25c tyre brand new in box Looking for: Wolber TX Profile clincher rim 32H X2 Velocity Aerohead black clincher rim 32H Mavic Rear derailleur Shimano 600 6207 front and rear hubs/wheelsets Campagnolo triomphe brake levers Campagnolo Record High Flange Track Hubs, 32H or 36H Campagnolo Record/nuovo record brake caliper set Campagnolo Super Record brake lever (retro one with drilled lever) - any condition. Continental Force 700X23c/24c black rear tyre Inner tubes 700X25/28c
Re: The swap meet threadThis may be a long shot - does anyone have a cone for a Normandy Luxe Competition 126mm rear hub?
Death before Di2!
Are they a different size cone to the standard normandy hub found on all sorts of old french bikes? LG = Low Gear
Re: The swap meet threadI've probably got a couple of maillard ones lying around if that's any use. Off an Atom hub if i remember rightly.
Re: The swap meet threadTo trade - Shimano 105 super SLR F & R brake caliper
Ultegra clamp on FD 4500 (34.9) HG 7 sp cassette 12-21 teeth Twist grip shifters (7 speed were fitted to tri bars) Wanted (to finish wet weather pace bike) DT shifters Clamp on shimano FD circ is around 10cm around 28mm dia long drop front and rear brake calipers (bolt on type) dual pivot if possible And 26.4m seat post to suit new type seats Cheers chris Cruisin on an old 'DALE'
Racing on a C5 OPPY Dirt track on a Giant YUKON http://velospace.org/node/43068
Not sure, I haven't seen a Normandy hub before this, although I knew they're a pretty common brand. Here's a pic of the cone I need to replace, diameter at the widest point is 18mm. You can also see why I need to replace it. Rebuilt front hub is behind it. ![]() cone by benatherton71, on Flickr
Do they look anything like that? Open to offers of a tiny trade if anyone can help, or I can just send cash or something.. Death before Di2!
Re: The swap meet threadwill check tomorrow.
Re: The swap meet threadFrom Googling around it does look like Maillard/Atom/Normandy are pretty interchangeable.
Death before Di2!
Looks very similar to me. One is in great nic, while the other is quite pitted. I measure them at about 17mm though. They came off a rear atom hub that was destroyed. I've still got the full front hub on a rim, but likely won't use it. Did you want to pm me with an email address and i'll send you some pics. utedeej
Re: The swap meet threadIf things don't work out with utedeej, I have a spare cone, not perfect, but much better than the one in your pic!
LG = Low Gear
Re: The swap meet threadPopped it in the post today pentlandexile. Fingers crossed that she's the one.
utedeej
Yeah, fingers crossed: thanks for the offer LG. They're nice hubs these so it will be good to get them rolling again. Death before Di2!
Re: The swap meet threadThought I'd try here before I buy from Hillary Stone.
Anybody have spare stronglight 99 chainrings (86 BCD), looking for around 50 & 36 tooth rings. Have a fairly wide range of stuff to swap. Cheers. LG = Low Gear
Re: The swap meet threadI may be able to help you there LG,
Give me a day or so and ill check out what i have as i have more rings than a jewelers shop definitely have a heap of Stronglight. SL
Re: The swap meet threadSL, much appreciated. I don't necessarily need NOS. I probably don't have anything you need
LG = Low Gear
Re: The swap meet threadI'm looking for 90s deore dx rear dérailleur and cranks in decent shape...
Have a few bits for trade just lmk what your after..
Re: The swap meet threadTo trade: Campag Record downtube shifters, band-on model. Very good condition. These are the ones without the cable guide ferrules. Levers are marked "Patent Campagnolo Vicenza Italy"
Will trade for: The same, but for braze-ons. Here's a pic ![]() shifters by benatherton71, on Flickr Death before Di2!
Re: The swap meet threadI always thought that you could just pull clamp on shifters off the clamp and put them on the braze ons. Is that not right?
Tried that, I either don't get enough friction to hold it in gear or end up with the outer metal plate sticking out cos it's on top of the outboard side nylon washer, and it looks messy. Death before Di2!
Who is onlineUsers browsing this forum: marks, redrover3, sunho, TedDancin |
