For it's time it would have been a pretty basic machine however in some respects it's special; I like it because
• it was fairly well known local brand and was made only about 7ks from my home
• the humpback frame style is an attractive alternative to a skidstar
• the blue paint has a beautiful patina, the Swansea script on the downtube is faded but legible and the decals on the head and seat tubes are in good nick
• it seems to be unmodified except for the tyres
I haven't been able to ride it yet, things that should turn easily don't. I was originally interested in an older frame that I could do a path racer number on, something that I could do weekend rides with the family on, would look cool without sacrificing functionality.
The Swansea is so pretty and original I can't bring myself to do anything other that a renovation on it. To that end I have a couple of questions for cleverer people than me
Cleaned and regreased the front hub. The axle has a bit of a woof in it. The hub looks disturbingly like one off a Repco Traveller verge find I was about to throw in the bin. I'm going to investigate pilfering the axle and cones from that one.
The original steel seatpost (25.4) is functional but rusted and maybe a tad short for me, I think finding a replacement in good nick should be easy.
Pedal bearings seem perfect.
I've started dismantling the cranks and bottom bracket. A sticky cotter pin has halted progress there. I'll either buy a cotter press or take it to someone who has one.
I pulled the chain off. I think the chain is the stiffest thing on the bike. I've had it in kero today but it still does not want to go round corners. I have a few other chains kicking round but none of them mesh anywhere near correctly with the original chainring(they all sit proud of it - either too narrow or the links too short??). If I wanted to get a new chain what should I be looking for?
It has a single speed coaster brake rear hub. Centrix from W Germany. I can hold the axle with my fingers and roll the wheel forward without too much resistance. If I hold the axle and try to turn the wheel by turning the sprocket she's a no-go. Should I be afraid of pulling this to bits? Looks like it needs tools I don't have - where's a good place to look for them? Or should I just hand this over to someone else?
The original bars are fun but badly corroded. If I replace the bars where can I get some period handgrips?
The quill stem wedge bolt loosens up easily and I've tapped it down with a hammer, can't shift the stem though... anything else I can do? The headset feels good so maybe I should leave well enough alone.
What are the tusks that run from the stem to the front axle? Are they functional or decorative??
As I mentioned I quite like the state of the paint job but wouldn't want it to decay further. I don't even mind preserving the light rust on the rims. Will simply moving this bike indoors and not riding it too much be enough to protect it?
