by kukamunga » Tue Feb 26, 2008 8:25 pm
Just Ride
kukamunga
by Forum Ads » Wed Feb 27, 2008 10:20 pm
by ukalipt » Wed Feb 27, 2008 10:20 pm
wow.
i have almost the same frame but in green, currently running fixed as well.
i think it is a PE-8. lynn has one which looks pretty much the same.
did you do the conversion job, or was it that way when your brought it?
PM'd you
i like to pedal
ukalipt
by kukamunga » Thu Feb 28, 2008 7:59 am
Bought exactly as you see it, minus messy bar tape, gel seat cover, and chrome 'ringa-ringa' bell!! Couldn't find out any history about it. Think it may have been a 'deceased estate' or such-like. I'd say someone has converted their roadbike to track race many years ago, retired, then stuck a bell and seatcover on it later to got to church on Sundays on!
Just Ride
kukamunga
by Kid_Carbine » Thu Feb 28, 2008 9:50 am
Simply be aware that many Peugeots were fully imported FDM's [French Domestic Models] with French diameter tubing & French threads, none of which is interchangeable with the English standard size or threading that was widely used here.
At least a locally sourced rear derailleur should bolt up OK [I think] along with the down tube friction shifters but check the seat tube for diameter as it could be a different diameter & if so, a locally sourced one would not clamp on.
Buying French sized & threaded components on eBay is not hard as it is quite common, [in Europe] but is a little inconvenient.
None the less, it will build into a very nice exotic road bike.
Carbine & SJH cycles, & Quicksilver BMX Now that's AUSTRALIAN to the core.
Kid_Carbine
by kukamunga » Thu Feb 28, 2008 10:24 am
Kid_Carbine wrote:.....check the seat tube for diameter as it could be a different diameter.....
Yep, 28.1mm. Nothing a few layers of soft-drink-can can't fix!  Anyway, I think it may be staying a single-speed. Did sell a PE-8 last year with Simplex derailleurs, and it was then converted to a SS. Might be able to source back those parts if needed.
Just Ride
kukamunga
by ukalipt » Thu Feb 28, 2008 10:26 am
oh yes the french.
28 seat post size
double right handed threads on BB which are thin walled [ needing a 70mm shimano spindle marked "5" to replace the cottered spindle or the very nice phil woods replacement]
22mm stem - just purchased a 22mm 3ttt
22mm headset - [got that one covered]
25mm bars
nothing normal going on, but thats passion for you
i like to pedal
ukalipt
by kukamunga » Thu Feb 28, 2008 10:34 am
Now.... why didn't everyone follow the French lead and go METRIC ???
Just Ride
kukamunga
by ukalipt » Thu Feb 28, 2008 6:46 pm
yeh good point. but no one wants to follow the french
i like to pedal
ukalipt
by Kid_Carbine » Thu Feb 28, 2008 7:25 pm
kukamunga wrote:Now.... why didn't everyone follow the French lead and go METRIC ???
Because the British Imperial system was just fine.
An inch was divided in two, then again & again into equal portions untill we got down to 64ths of an inch. Even as a schoolboy I had no problem with this but apparently Napolion decided that the French were too stupid to count past 10 because that's all the fingers they had, & naturally, the Australian government of the day presumed that we were as stupid as the French & inflicted metrication on us as well.
Talk about Government mandated dumbing down.
They took another French trait, homosexuality, & made it legal. What's next, will they make it compulsory?
Kid_Carbine
by kukamunga » Thu Feb 28, 2008 8:50 pm
Hey Kid. How many fingers you got? And toes.....? Bonjour!
Homosexuality? I thought that was the ******
(EDIT: Hmmm, racial vilification laws  )
Maresi!
Just Ride
kukamunga
by CTA » Fri Feb 29, 2008 9:01 pm
All of my Peugeot UO-8's and UE-8's take a 25.6mm or 25.8mm seatpost(seatpin). Cheap and easy to find, about $25 for new alloy seatpost
CTA
by Kid_Carbine » Fri Feb 29, 2008 10:53 pm
kukamunga wrote:Hey Kid. How many fingers you got? And toes.....? Bonjour!  Homosexuality? I thought that was the ******  (EDIT: Hmmm, racial vilification laws  ) Maresi!
Sorry mate, I didn't think it would be you that rose to the bait like a hungry trout.
Most know by now that I like to generate a little "robust debate" as our former & somewhat disgraced Prime Minister called it, so I throw out a little bait now & then to see what happens.
I had actually expected someone else to come in.
Kid_Carbine
by kukamunga » Fri Feb 29, 2008 11:52 pm
Use grub worms next time, please!
Just Ride
kukamunga
by kukamunga » Sun Mar 16, 2008 8:51 pm
This Peugeot has now found a new home in Sydney  where it will have other Peugeots to keep it company. Bonjour!
kukamunga
