Pre 1930 Malvern Star serial numbers
narcotics
Re: Pre 1930 Malvern Star serial numbers
Postby narcotics » Mon Sep 04, 2017 4:23 pm
#01840 mens , rear facing dropouts, there is blue paint under the silver. Someone resprayed shimmed the handle bars on there & also put a nail in with seat pole.
Rear hub is immaculate, rims look like they were shiny when parked until the chain rusted itself together.
I have more photos I'll upload soon.
https://ibb.co/nJymKF
Favorit coaster hub.
magistroni cranks (italy)
Kaga 28" 1 3/8 rims (japan)
Bunged Knee
Postby Bunged Knee » Mon Sep 04, 2017 5:08 pm
^^^ narcotics pic
What's this of 6.1MB pic? Use the full image BBCode to copy and paste.
starnut
Postby starnut » Wed Sep 27, 2017 10:43 pm
Thanks tedsbikes and Clydesdale Scot. Much appreciated.
FJ45
Postby FJ45 » Wed Oct 18, 2017 9:39 am
Hello,
I have an old Malvern Star 2 star Ladies bicycle. The serial number is 5M 16180 located on the top of the frame where the seat post slides into the frame. Any idea on how old this bike is?
Postby Clydesdale Scot » Wed Oct 18, 2017 5:44 pm
1945, Melbourne build
elfoam
Postby elfoam » Thu Oct 19, 2017 1:31 am
maccayak wrote:Try again. Hopefully you can see photos.
Not pre 30, Im guessing about 65ish. Bought it on ebay over the weekend to add to my growing stable of Malvern Stars of a similar vintage. I know its a base model cheaper frame. Most of the frame looks the quality of basic skidstars I have. Just the rear drop out is different.
What can members tell me about this frame? Presume it was a budget model track bike that brakes could be fitted to. Looks like its had brakes fitted in a previous life.
Cheers Geoff
ImageUntitled by Geoff McDonald, on Flickr
Indeed that one is a Semi racer. they were called a Semi racer in fact. But it would have had mudgaurds and lights when new.
MHJonesRegister
Postby MHJonesRegister » Sat Dec 02, 2017 1:13 am
Hi, new to the forum and just found this old thread. Quite interested to know age of my 2star track bike frame numbered 4P 1586. The BB has stamped in it BB GR23 and "Made in England". The fork is not original and the groupset is a bit of a mismatch that I wouldn't rely on. That said, the quill stem is an old alloy Phillips (with open "rear end") I think Williams crank set. Much appreciated!
Postby Clydesdale Scot » Sat Dec 02, 2017 7:25 am
the numbering convention would indicate 1944 Perth build.
Whether it is a track frame or a road frame having rear facing dropouts would need photos.
RazzOnTheRoad
Postby RazzOnTheRoad » Thu Dec 14, 2017 8:24 pm
Hi, I've got my great grandfather's bike that I thought was a Malvern Star. It's got the right 2 star forks, but no stars on the frame. The frame serial number is D6806 which is stamped on the down tube near where the seat post goes in.
Any help with this would be great. I think it's early 30s or late 20s.
The bottom bracket is a Bayliss Wiley and the coaster hub is a Favorit (not sure it was original).
This is my first post, so if photos are needed I'll work that out later.
Thanks in advance, Ryan
Jojet
Postby Jojet » Thu Dec 28, 2017 11:59 am
I recently bought a second hand Malvern Star bike with M4J51960 imprinted below the crankshaft. Does this indicate it is a 1960 model? If not, please advise what year it would have been made. Thank you.
bicyclepassion
Postby bicyclepassion » Fri Dec 29, 2017 7:19 pm
It's not a 1960 model. It sounds like a much later model, but will require photos if you want an accurate opinion.
Torana68
Postby Torana68 » Mon Jan 01, 2018 5:29 pm
RazzOnTheRoad wrote:...................... It's got the right 2 star forks, but no stars on the frame. .............................n
photos would be needed but generally no stars = no malvern star , sounds like something else with MS forks
Ozpushies! for ALL Australian made bikes.
"It's only original once"
RazzOnTheRoad
Postby RazzOnTheRoad » Tue Jan 02, 2018 5:35 pm
Torana68 wrote:photos would be needed but generally no stars = no malvern star , sounds like something else with MS forks
Thanks for the response; here she is in all her glory...
Bike before any tear down
'D6808' stamped on seat post tube
front of frame
top of forks and down tube
...and a pile of parts
any help in working out the exact age or make of this bike would be great. Cheers, Ryan
Postby Clydesdale Scot » Tue Jan 02, 2018 6:42 pm
Ryan
any details on wheel size and are there any engravings on the chainset (look on the back of the ring and crank arms)?
Philip
Torana68
Postby Torana68 » Tue Jan 02, 2018 8:12 pm
what do the do the seat stays look like where they bolt to the chain stays? (pic please)
bicyclepassion
Postby bicyclepassion » Tue Jan 02, 2018 9:38 pm
Good old genetic roadster frame with pressed ends, with Malvern Star forks.
RazzOnTheRoad
Postby RazzOnTheRoad » Tue Jan 09, 2018 1:46 pm
Torana68 wrote:what do the do the seat stays look like where they bolt to the chain stays? (pic please)
Wheels are 28", not matching rims, front is a 40 hole hub, rear is 36 hole.
Seat post bolt section
Bolt section near rear drop out
bottom bracket
and sorry, I'm still trying to clean 80 odd years of grime from the crankset and crank arms, haven't seen any writing on those thus far, but there is a load of crust on them...
Torana68
Postby Torana68 » Tue Jan 09, 2018 3:49 pm
ok , it may be a Speedwell frame but there are some differences that leave me at "may be" not "is"
