Postby BRLVR.v2 » Fri Dec 07, 2012 8:05 pm
ldrcycles wrote:Took some pics of the Dawes with a few different wheelsets.
Sun CR18 rims on Novatec hubs
The blue wheels are definitely still my pick, the black ones don't stand out as much and the 27" wheels are downright boring.
I think the plain wheels tip this bike into a classic beauty territory. All it needs is some 600 arabesque cranks with that combo and it would be timeless. Buy a cheap ally (Visp) or the like to hang your garish high coloured hipster bits on. It's a classically styled bike with a soul, and you should treat her with some respect. Man, I sound like a retro grouch don't I ? :wink:
BRLVR.v2
by BNA » Fri Dec 07, 2012 8:25 pm
Postby grantw » Fri Dec 07, 2012 8:25 pm
BRLVR.v2 wrote: Man, I sound like a retro grouch don't I ? :wink:
You do, but you're right all the same.
The taper on that fork and the fine stays demand a light looking wheelrim.
grantw
Postby ldrcycles » Fri Dec 07, 2012 8:34 pm
Yes :lol: . But that's absolutely fine by me :) . The 1984 catalogue i got recently (which i will be popping up on the Dawes Appreciation Society thread as soon as i've scanned it), describes the Shadow (all 30lbs of it) as 'the envy of all the competition' :lol: . If it was anything else i would have left it on the tip, no derailleur hanger, crummy looking cranks and a rear brake bridge made from a flat plate. But by god it goes fast, she'll sit in the 40s all day.
To my eyes, that bike and the blue wheels are for good, can't have one without the other. But if you want to talk classic beauty?
This is what the 27" wheels belong to.
Postby BRLVR.v2 » Fri Dec 07, 2012 9:05 pm
ldrcycles wrote: But if you want to talk classic beauty?
You've aced me there.
BRLVR.v2
Postby grantw » Sat Dec 08, 2012 3:59 pm
Verrry nice
grantw
Postby ldrcycles » Sun Dec 09, 2012 7:06 pm
Wait til you see the Viscount Sebring i'm working on, the way it's coming along Joe Cosgrove would be happy with the paint job.
The original Shimano 500 gear is too shabby for my liking so i'll be using a 600 Arabesque group, but the front shifter cable is set up to have casing going straight to the stop on the 500 derailleur, the 600 hasn't got such a stop so how can i get it to work with that?
Postby munga » Sun Dec 09, 2012 7:13 pm
not sure without a pic, but something like this to terminate the cable outer/casing?
Postby ldrcycles » Sun Dec 09, 2012 7:20 pm
Yeah that's about all i can think of, but it then leaves a redundant cable stop on the non drive side of the downtube, near the BB. There's no way i could grind it off (least of all because i'm already more than halfway through painting).
Postby munga » Sun Dec 09, 2012 8:07 pm
sorry mate, i can't visualise what's there, what used to be there, and what needs to be done to run the 600 FD.
too much cheese. :oops:
Postby ldrcycles » Sun Dec 09, 2012 8:17 pm
Bugger wouldn't you know it, none of the 5 bikes i have to hand have anything like it i could photograph, it'll have to wait til the next time i'm out at my farm. Not too much of a rush on it anyway, it only needs to be ready in time for the next L'Eroica.
Postby LG » Mon Dec 10, 2012 5:41 am
ldrcycles wrote:The original Shimano 500 gear is too shabby for my liking so i'll be using a 600 Arabesque group, but the front shifter cable is set up to have casing going straight to the stop on the 500 derailleur, the 600 hasn't got such a stop so how can i get it to work with that?
I snookered myself with a similar issue a while ago. Ended up just using a short section of cable housing from a stop at the lower end of the down tube under the bottom bracket. It doesn't need to go all the way to the FD, it just provides a guide for the cable.
LG = Low Gear
LG
Postby Clownshoes » Mon Dec 10, 2012 4:41 pm
Early 90's Vetta Titanized (Columbus Gara fillet brazed tubing) with Campagnolo Mirage and Campy wheels. Runs a dream.
Clownshoes
Postby munga » Mon Dec 10, 2012 4:42 pm
nice work.
Postby ldrcycles » Mon Dec 10, 2012 8:53 pm
Facepalm. OF COURSE, the casing isn't under any kind of pressure so it doesn't NEED to have a 2nd stop. The best solution is always the simplest one, thanks LG.
Postby munga » Mon Dec 10, 2012 9:30 pm
stoner
Postby rkelsen » Tue Dec 11, 2012 10:06 am
:?: The 600 Arabesque FD [FD6200] has a cable stop on it, no?
http://velobase.com/ViewComponent.aspx?ID=d808bd8e-537d-481a-a503-eee96e10dfc6&Enum=113
It's right next to the spring at the back. You can see it in the photos.
volutamus scandemus
rkelsen
Postby LG » Tue Dec 11, 2012 12:12 pm
The cable stop on most of the 6200 FD's is a small piece of steel which fits to the FD where it clamps to the frame. These appear to have been only press fitted in place. Many of these FD's are now missing this piece. If you look at the inside of the clamp, there will be a small groove where this used to fit. Some were manufactured without them at all.
LG = Low Gear
LG
Postby rkelsen » Tue Dec 11, 2012 1:06 pm
The one I have [an Arabesque FD6200] has its cable stop moulded in alloy behind the clamp, exactly like the one in the pictures on Velobase.
Ebay item no 110983495649 has some close up pictures of one:
volutamus scandemus
rkelsen
Postby LG » Tue Dec 11, 2012 1:36 pm
... and then there is also the version you post in your pic of which are on some of the FD's (these are ones not covered by my "most" comment. I currently have 2 Arabesque FD's, neither have a cable stop or groove for the stop, 2 non-arabesque FD's - 1 with a stop as mentioned above, the other missing the stop but with the groove where it used to be. Just depends how lucky you are with the one you get I guess. Idrcycles maybe should swap for yours :wink:
LG = Low Gear
LG
Postby rkelsen » Tue Dec 11, 2012 1:57 pm
LG wrote:Idrcycles maybe should swap for yours :wink:
:lol: Sorry, I've got plans for it. Big plans. Can't talk about it yet, 'cos I'm still collecting bits...
volutamus scandemus
rkelsen
Postby seddo » Sat Dec 15, 2012 1:10 pm
New upgrades to the Moser full Dura Ace - mix of 7700&7400, panto stem,Mavic wheels with Dura Ace Hubs and new bar tape
Image - crank caps have been added
seddo
Postby ldrcycles » Sat Dec 15, 2012 6:33 pm
Sorry to take things off topic, but just to finish the discussion re derailleurs, the one i have hasn't got the moulded in stop or any kind of protrusion that one could clip on to. LG's idea will work just fine though, i hardly ever change out of the big ring anyway so the front derailleur is only there for decoration :) .
Postby Kermit TF » Sat Dec 15, 2012 8:58 pm
Please remove the pics of that Moser...i-pad covered in drooool :D
Nice job Richard.
When in doubt......mumble.
Kermit TF
Postby munga » Sun Dec 16, 2012 8:26 am
nice Moser, seddo!
vaeske's green one is also running dura ace, and also gorgeous to look at, and lovely to ride as well, apparently.
Postby Daus » Sun Dec 16, 2012 5:49 pm
I wanted to share this picture of my old beast- the frame is early 70's and I have no idea what it was however I powder coated it about 10 years ago and the running gear is 105. It still gets out on commute duties 2 to 3 times a week- Don
Daus
