by funnybike » Fri Sep 28, 2012 7:14 pm
Anyone got some advice of removing paint without damaging alloy beneath?
I have acquired a pair of Cinelli LA84 cow horn bars that have been rattle canned black. I'm concerned that paint stripper with damage the alloy bar thus requiring me to polish it to get that "I'm trying too hard to make these look like NOS" kind of finish. I would like to preserve the original Cinelli matte finish if possible.
Suggestions? Or better yet, experience?
funnybike
by Forum Ads » Fri Sep 28, 2012 7:21 pm
by munga » Fri Sep 28, 2012 7:21 pm
if it's acrylic, try metho. wrap a rag and 'soak' to soften the acrylic, then rub off if it's enamel, try mineral turps.
by Wal42 » Fri Sep 28, 2012 8:19 pm
I was thinking maybe use 1200 or 1600 wet & dry sanding paper, gently with a mild soapy water.
Wal42
by BRLVR.v2 » Fri Sep 28, 2012 9:09 pm
Are these the ones from the Triple Tri funny bike?
The seat post had a heavy coating of paint when I extracted it that made it a slow and painful process.
Maybe suss out some of the specialists who dip and strip stuff for plating, may be more gentle than abrasive actions.
BRLVR.v2
by Crowz » Fri Sep 28, 2012 9:24 pm
If all else fails, hydrochloric acid seems to strip most things
Crowz
by funnybike » Sat Sep 29, 2012 7:10 am
BRLVR.v2 wrote:Are these the ones from the Triple Tri funny bike?
Was that you as the seller? Yeah, I bought it specifically for the frame. The bars were a complete surprise. If I can clean them up I have a perfect home for them. Crowz: Gee, thanks.
funnybike
by RonK » Sat Sep 29, 2012 8:18 am
Automotive paint thinners will probably lift it, or acetone. You should be able to get either from Supercheap.
by BRLVR.v2 » Sat Sep 29, 2012 9:10 am
funnybike wrote:BRLVR.v2 wrote:Are these the ones from the Triple Tri funny bike?
Nah, Paul. It's Dave , the beer swilling packer and sender.
BRLVR.v2
by funnybike » Sat Sep 29, 2012 1:02 pm
Aha! Thanks again, mate. Enjoy those brews, you earned it.
funnybike
by vaeske » Sat Sep 29, 2012 1:13 pm
awesome to see the community working out another deal where everyone is a happy chappy.
vaeske
by Mustang » Mon Oct 01, 2012 6:12 pm
RonK wrote:Automotive paint thinners will probably lift it, or acetone. You should be able to get either from Supercheap.
Acetone will move it!
Mustang
by bicyclepassion » Tue Oct 02, 2012 12:30 pm
The Cinelli LA 84 bars are clear anodised. You need to trial various strippers on a damaged or redundant set of anodised Cinelli bars to make sure it doesnt melt the anodising. Then try the successful product on an end of the LA84 handlebars that will eventually be covered by tape. Most strippers and thinners etc wont touch anodising, as anyone who has tried to strip anodising will attest. Also, most paint doesnt adhere well to good anodising, so the paint will not take much persuasion to come off with whatever thinners is appropriate to the type of paint. Definitely do not use wet and dry paper, as this will scratch the anodising beyond salvage, even if you are very carefull. If the anodising is damaged under the paint, the only way to get that 'matt finish' back will be to strip the anodising, and have them re-anodised. Or polish them and have the over-restored look. Warren
bicyclepassion
by toofat » Tue Oct 02, 2012 2:03 pm
Chemical engineers have spent years perfecting paint strippers and there are plenty out there, for cheap and simple and effective try diggers from bunnings, yellow tin ( metheleyene chloride based) for oil based paint and the green tin for water based paints. a soft brush and a pressure washer will help
toofat
