Bike photography
Bike photography
Postby Lots of steel bikes » Sat Nov 03, 2012 7:47 pm
A short while ago someone mentioned a couple of tips for taking better bike photos. Was it cranks horizontal and rear derailleur at full stretch? Any other tips? I think that bidon cages sometimes spoil the aesthetics of a bike. I'll never be a Ray Dobbins but I'd like to do a bit better.
Lots of steel bikes
by Forum Ads » Sat Nov 03, 2012 8:01 pm
Re: Bike photography
Postby GaryF » Sat Nov 03, 2012 8:01 pm
I like the rim decals to be in a similar orientation on both wheels as well as the valves. I like to see the biddon cage but I can see where it could be distracting. I like to see the RH crank arm pointing to around 2:30 o'clock or pointing down to continue the line of the seat tube.
Do I ever think of these things when I take a photo of a bike? No!
GaryF
Postby toolonglegs » Sat Nov 03, 2012 8:02 pm
Show us some of your examples to critic :P .
I haven't done many... quite like to do more but haven't got around to it.
French 1940's velo / bicycle
Simplex plunger/push-rod derailleur
French Cycling Components
Simplex Tour de France derailleur 1940's
1984 Raymond Poulidor Bicycle
Postby ldrcycles » Sat Nov 03, 2012 8:12 pm
Postby toolonglegs » Sat Nov 03, 2012 8:21 pm
:lol: If I can pull to bits one of these and reassemble it in a day...
Don't think I will have much trouble with a SIMPLEx :P
Postby Lots of steel bikes » Sat Nov 03, 2012 8:30 pm
[quote="toolonglegs"]Show us some of your examples to critic :P .
Well, this will be embarrassing!
Lots of steel bikes
Postby toolonglegs » Sat Nov 03, 2012 8:37 pm
Location baby!... find a location that suits the bike.
If you have an SLR camera shoot it on a longer lense to blur out the back ground a bit and make the bike stand out a bit, it will also reduce the distortion that happens when shooting on a wider lense.
If you haven't got your own lighting ( most people )... shot it in early morning or late afternoon when the sun is a bit lower and the light is a bit warmer. It will make all the metal work sparkle.
Get photoshop or similar for the finishing touches :D .
Postby ldrcycles » Sat Nov 03, 2012 8:44 pm
My most recent effort. I was hoping the location would suit.
Or to follow the 'instagram' fad (although i did this on photobucket and i think it suits the bike)
Oh and TLL, i took over a month to reassemble a SunTour VX GT once!
Postby Clydesdale Scot » Sat Nov 03, 2012 8:56 pm
When this topic was discussed on LFGSS the comments were distilled to
Aesthetic examples:
Tyre labels in line with tyre innertube valves.
Quick releases both on non drive side.
Saddle horizontal to the ground
bottom of drops horizontal to the ground/or lined up to point at the rear brake. I read it in the internetz.
One neat strip of tape around the bar tape to finish of
hub logo on front hub should face the same as rear and read from the right.
-Rim labels should read from the right.
-Cable routing to be as neat as neat can be.
-Seat and bar tape to be the same colour. Or not. It depends.
etc, etc
Photographing
Valves both at the lowest point, highest point or somewhere else as long as they're in the same place. Can be hidden to astound if no tyre labels present.
logo on crankset should be upright
-Photograph should be from the right.
-Geared bikes should have chain on big ring.
-seat post should show sufficiently, but bars & saddle to be same height. (Rando-luv)
-pedals should be fixed in the ridden position, not at rest. (by tightening bearings just for the shot. Ha.)
-Angle of shot should be such that lh drop is all but hidden by rh drop.
-Downtube shifters should be parallel.
-Either lh crank to be in line with seat tube, or rh crank in line with chain stay, ahead or behind bottom bracket. In line with something anyways.
-Background to be unconfusing. And any lines to speak to frame tubing.
Postby toolonglegs » Sat Nov 03, 2012 9:06 pm
^^^ now that's detailed :-) .
Nice pic with Massey Ferg :-) .
Postby Clydesdale Scot » Sat Nov 03, 2012 9:24 pm
I like the clean appearance of the bikes on Speedbicycles.
But he doesn't follow all the rules^^
Postby RobertFrith » Sat Nov 03, 2012 9:39 pm
The style guide is good in as much as it makes person actually think about the positions of various bits and pieces. Some of them are silly though; I like downtube shifters to be not parallel and pedals as ridden, daaaaaaggy!
I earn a crust as a phototgrapher (credentials here). You can write all the "rules" you want but good photography comes back to content, composition and lighting. The rules above apply mostly to composition.
Bikes are a really tough subject. A bike is bunch of skinny tubes with a lot of air in between. Air is invisible. You should give some, actually a lot, of thought into what is going to fill that space. Garage doors, brick walls and white, black or grey in a studio are the most popular options, they're the ones that provide the most reward per unit of effort.
Check out these two posts on Cycle Exif. They've broken plenty of rules but you have to agree the photos are beautiful. And it's mostly because the photographers have considered the location for the shoot, the lighting and the composition, which isn't always about the bike. Mind you, they're pretty nice bikes :wink:
http://www.cycleexif.com/chiossi-cycles-gloria
http://www.cycleexif.com/kinfolk-autumn-2
RobertFrith
Postby Tinker » Sun Nov 04, 2012 10:02 am
Can you create that white room look at home? Or is there some photo-shopping involved with those type shots?
Tinker
Postby ldrcycles » Sun Nov 04, 2012 10:35 am
Postby Tinker » Sun Nov 04, 2012 12:03 pm
Fantastic indeed! Great insight into setting up a DYI photo shot.
Tinker
Postby ghostpoet » Sun Nov 04, 2012 1:57 pm
I was going to dob Frithy in, but he did it himself. If he can polish the t#rd that is Port Hedland, he is the man to speak to...great chap too.
ghostpoet
Postby frailer5 » Sun Nov 04, 2012 5:04 pm
A fan of oblique composing/framing here. If you picture the bike being at the centre of a square box. Then envisage the box having intersects across every diagonally opposite corner, through the centre of the box; that's 4 lines. I try and do most (not all shots), in that rough line-of-sight. This tends to add some 3D to what is a pretty 2D machine.
The shots I put up of the Pegasus in 'Let's see what...' kind of show that, I think (Gallery link there). Not a big fan of the 90º/0º level shot. IMO, getting angles (vertical and horizontal together), is the main prerequisite. Then there's ugly stuff in the background to be left out/taken out.
Yes, early morning/late afternoon give better light, too, as suggested earlier.
These are all very amateur suggestions; I'm no pro.
Ever noticed how quiet steel bikes are?
frailer5
Postby RobertFrith » Sun Nov 04, 2012 5:33 pm
ghostpoet wrote:I was going to dob Frithy in, but he did it himself. If he can polish the t#rd that is Port Hedland, he is the man to speak to...great chap too.
Too kind. You'll notice I haven't been game to put up any of my bike pics though!
frailer5 wrote:The shots I put up of the Pegasus in 'Let's see what...' kind of show that, I think (Gallery link there)
No link, am I missing something? Want to see..
RobertFrith
Postby Stuey » Sun Nov 04, 2012 7:01 pm
Tinker wrote:Can you create that white room look at home? Or is there some photo-shopping involved with those type shots?
Yeah, with a light box....although I'm not saying TLL used one (and not Photoshop).
Stuey
Postby Lots of steel bikes » Sun Nov 04, 2012 8:05 pm
1984 Raymond Poulidor Bicycle[/quote]
Very nice! Do you have a pre photoshop image you could show and perhaps share some of the photoshop techniques you used to get to the final image.
My apologies if no photoshop used.
Lots of steel bikes
Postby frailer5 » Sun Nov 04, 2012 8:09 pm
RobertFrith wrote:No link, am I missing something? Want to see..
Pegasus Link
Taken with a Fujifilm S1600, not a particularly high-end camera.
frailer5
Postby toolonglegs » Sun Nov 04, 2012 8:21 pm
the pre-photo shop image would be a raw file... All I would have done is brightened it up. Cant remember exactly but probably used 3 lights... 2 on the background and one front on. The front on one would have blasted through a white sheet (as metal only reflects what it sees, you need a big white light source to get the nice reflections ).
Photography is my job as well http://icj.carbonmade.com/
But usually people :-)
Postby rkelsen » Tue Nov 06, 2012 9:21 am
Raymond has no FD.
Probably didn't need one, eh? :lol: Very neat bike though! And the Kenevans too.
I had to make these comments although they contribute nothing to the topic. Sorry.
volutamus scandemus
rkelsen
Postby toolonglegs » Tue Nov 06, 2012 5:43 pm
:-) hadn't quite finished it when I took that picture. Took a long time to find a Bakelite front derailleur in one piece !.
Postby amrjon » Tue Nov 06, 2012 7:25 pm
Great topic and tips guys. Some impressive examples too.
Very timely for me as Ive just finished off a bike and I'm waiting for some nice weather to try a get a few pictures before I hand it over to its new owner.
I agree that a great backdrop can make a big difference. A couple of my favorite bike pictures are ‘real’ scenes from my travels with the bike itself in the background rather than being the main subject.
amrjon
Users browsing this forum: Kermit TF, muzzie
