Jockey wheels
Jockey wheels
Postby Lots of steel bikes » Sat Nov 10, 2012 6:50 pm
I need a jockey wheel for an shimano arabesque derailleur. Do I just buy a modern generic jockey wheel? Anything to watch out for? Thanks all.
Lots of steel bikes
by Forum Ads » Sat Nov 10, 2012 7:36 pm
Re: Jockey wheels
Postby Velo13 » Sat Nov 10, 2012 7:36 pm
As long as it is designed for Shimano, 8 speed (only because it's a close as you'll get to 6 speed) and has the same number of teeth, you should be just fine.
Or let me know how many teeth it has and I'll see what I have.
Velo13
Re: Jockey wheels
Postby Lots of steel bikes » Sat Nov 10, 2012 8:03 pm
Velo13 wrote:As long as it is designed for Shimano, 8 speed (only because it's a close as you'll get to 6 speed) and has the same number of teeth, you should be just fine.
Thanks for the reply Velo13. It has 10 teeth.
Lots of steel bikes
Re: Jockey wheels
Postby drubie » Sat Nov 10, 2012 8:47 pm
BBB Rollerboys - they come with a big plastic flat thing with all sorts of axle adapters on it - it's like an old Airfix kit only there's no glue involved. Pick the jockeys with the right number of teeth, then snap off the axle adapters you need and you're done. They work with everything ever made that was indexed as far as I can tell. It's even clever enough to include axle adapters with enough wobble/play for the top pulley.
drubie
Re: Jockey wheels
Postby Velo13 » Sun Nov 11, 2012 7:10 am
Nice one Drubie.
Velo13
Re: Jockey wheels
Postby Lots of steel bikes » Sun Nov 11, 2012 8:23 am
Thanks Drubie. I've seen the BBB range of parts in bike shops but never jockey wheels.
Lots of steel bikes
Re: Jockey wheels
Postby Nobody » Sun Nov 11, 2012 10:23 am
drubie wrote:BBB Rollerboys - they come with a big plastic flat thing with all sorts of axle adapters on it - it's like an old Airfix kit only there's no glue involved. Pick the jockeys with the right number of teeth, then snap off the axle adapters you need and you're done. They work with everything ever made that was indexed as far as I can tell. It's even clever enough to include axle adapters with enough wobble/play for the top pulley.
Yeah I've got these too. Work well, last a long time.
Nobody
Users browsing this forum: QuangVuong, rebelcontender
