by Mustang » Sat Nov 24, 2012 6:53 pm
I need help to Identify the brand of this frame, Warren (from this forum) has discounted its not a Malvern Star as logoed. Headset is Made in England, only identifying marks apart from the frame numbers. My mate has asked me to get it to a rideable state before he paints it. (Next Year) It was his grandmothers bike & is known to be 40 plus years old. He wants to show his grandfather at Xmas as pop is not expected to make another year? Q2) He supplied me with 28"tyres but they will not fit. Bead Depth of the wheel measures 642mm & the tyres are labelled (37-622) which is the depth of a 700c wheel????? so the 28" must be a misnomer, the tyres are new but carry no company brand, supplied by a retro bike supplier on the net. Q3) can any member shed some light on a correct tyre & where to obtain same?    The seat stays are screwed to the frame not shown in the image.
Mustang
by Forum Ads » Sat Nov 24, 2012 9:08 pm
by Torana68 » Sat Nov 24, 2012 9:08 pm
photo of front of head lugs needed but could be Speedwell, tyres should be 28 x 1 3/8.....
Ozpushies! for ALL Australian made bikes. "It's only original once"
Torana68
by ldrcycles » Sat Nov 24, 2012 9:29 pm
I have a Healing (or at least that's what the decals said when i found it) which is identical, it has 26 x 1-3/8 wheels.
by bicyclepassion » Sun Nov 25, 2012 6:52 am
There are several different 28" tyre sizes. 37 642 is 28 x 1 3/8", the most common 28" tyre size in Australia up until the mid 1960's. These are available, and this is what you need. Dont buy 28 x 1 1/2", as these are 635mm, and wont fit your aussie rims. 28 x 1 1/2" fits a lot of the old style roadster bikes from aailable from India and China now. As you have found, 37 622 is 700C, sometimes called 28", and labelled as 28".
As an aside, '700C', 622mm rim size was available as an option from about 1895 to 1905 on Australian bikes, as it took a tyre size called 28 x 1 3/4", a big tyre for rough roads. These very early 28" rims are super rare, but if you find some, a modern 700C tyre will fit! Warren
bicyclepassion
by Mustang » Sun Nov 25, 2012 8:08 am
Thanks to those who replied, Sheldon Brown also suggests that the Bead Seat Dia, of 642 is a 700A (28 x 1,3/8) BSD of 635 is a 700B (28 x 1,1/2 ) BSD of 622 is a 700C (28 x 1,5/8 x 1,1/4) (The tyre I have is a 700C & the BSD measures 642!!!) STOPPRESS: I,ve found a supplier of 642BSD in AUS http://www.moruyabicycles.com.au/contents/en-uk/d973_28-inch-tyre.html
Mustang
by Torana68 » Sun Nov 25, 2012 12:45 pm
[ double post
Torana68
by Mustang » Sun Nov 25, 2012 5:20 pm
Mustang
by Torana68 » Mon Nov 26, 2012 4:06 pm
has it been sandblasted whilst assembled?  edit: anyway I'd say Speedwell c late WW2 ish
Torana68
by Mustang » Tue Nov 27, 2012 9:01 pm
Torana68 wrote:has it been sandblasted whilst assembled?  edit: anyway I'd say Speedwell c late WW2 ish
Yes it was sandbalsted while assembled you can only imagine the Bl**d* mess!!!!!!!!! Tyres arrived today & they fit  , wrong ball bearing size sent for the headset, can it be so hard  .Re- order tomorrow, New cones for the front axel, but of course they fit the hub ,but not the axel, so get a new axel made? Recut all the axel nuts as they are so rounded, meanwhile my friend is a Chiropractor so I hope his cheque book is open???? All being well granfather will see it riden at Xmas? Stay tuned for images????
Mustang
by Mustang » Tue Dec 04, 2012 6:44 pm
Well "Nan" is resurected & rideable for now. It will be stripped down again & painted after Xmas. The owner is searching period colours & is keen to have all bright ware replated, hopefully he will respoke the rims for a better look. Riding this old girl is like a recliner with pedals  really puts a  on your face.  The rake on the forks is amazing   Good job its a stepthrough, I don't think I could swing my leg over a crossbar this size  the wheels at 642 seem massive. Must weigh it tomorrow. Cheers, I'll post again when its painted.
Mustang
by Torana68 » Tue Dec 04, 2012 7:09 pm
Yes it was sandbalsted while assembled you can only imagine the Bl**d* mess!!!!!!!!! I can imagin the mess , its not recommended to do that  otherwise its getting there, is there a date code on crank or chainwheel?
Torana68
by Mustang » Tue Dec 04, 2012 8:07 pm
Torana68 wrote:Yes it was sandbalsted while assembled you can only imagine the Bl**d* mess!!!!!!!!! I can imagin the mess , its not recommended to do that  otherwise its getting there, is there a date code on crank or chainwheel?
Only the numbers I've previously posted, the chain ring has only 44. The owner has been researching & as others have posted the frame appears to be a Speedwell. Would like to know the age?
Mustang
by BRLVR.v2 » Tue Dec 11, 2012 8:41 am
Is it just me or is that fork bent. The top of the crown where it enters the bottomof the head tube is not in alignment with the tube. Looks like its been pushed backward. Have you inspected it thoroughly?
BRLVR.v2
by munga » Tue Dec 11, 2012 9:44 am
no problem - gaspipe strong!
by Mustang » Tue Dec 11, 2012 5:52 pm
BRLVR.v2 wrote:Is it just me or is that fork bent. The top of the crown where it enters the bottomof the head tube is not in alignment with the tube. Looks like its been pushed backward. Have you inspected it thoroughly?
First request was to get the bike rideable to show the Grandpa at Xmas. There were bearings missing from the lower headset, so I substituted with larger, I suspect thats what the photo is showing. Now its to be painted before Xmas???? don't like the chances? so I stripped it today & have ordered correct bearings. I didnt notice any damage when dis-assembling, but I'm no expert.
Mustang
by ldrcycles » Wed Dec 12, 2012 9:15 pm
I'm liking the gunmetal grey, very period correct  .
by Mustang » Thu Dec 13, 2012 8:21 am
ldrcycles wrote:I'm liking the gunmetal grey, very period correct  .
The owner suggests he will surprise me???????
Mustang
by Mustang » Sun Dec 23, 2012 6:53 pm
Here Tis; NOW its be given to the Dad for Xmas?? If my friend gets it back it will be again stripped & pro painted & pinstriped like when Nan had it. The whole bike is so solid cosidering 4x grandsons couldn't break it, virtually no wear, bearings/chain/ rear end . Badly needs a set of guards.
Mustang
by ldrcycles » Sun Dec 23, 2012 7:28 pm
That looks really good, i'm keeping an eye open for an old men's roadster to restore and that paint scheme would be great. Mustang wrote:The whole bike is so solid cosidering 4x grandsons couldn't break it, virtually no wear, bearings/chain/ rear end .
They sure made em to last back then  .
by Mustang » Mon Dec 24, 2012 8:20 am
ldrcycles wrote:That looks really good, i'm keeping an eye open for an old men's roadster to restore and that paint scheme would be great. Mustang wrote:The whole bike is so solid cosidering 4x grandsons couldn't break it, virtually no wear, bearings/chain/ rear end .
Thanks Lachlan, the paint is so fresh it still smells, I had to be so careful assembling. I think the owner nailed with the colour scheme.
Mustang
