Widening Dropouts on Steel Frame
Postby mattwilkinson » Wed Dec 26, 2012 6:52 pm
So I bought an old steel frame bike. And wanting to do it up into a SS.
The wheels it came with, Have a mallard hub/free-wheel. And I don't know if I can remove the freewheel without a tool, Then how would I get a SS cog onto it?
The frame has 125mm rear dropout spacing. And I have a spare 10 speed road bike wheel, with appropriate SS conversion kit.
Only problem is that is has a 130mm hub, and will not fit.
Is there any way to widen the chainstays on the frame? Would a bike shop do it?
Matt
Matt | Bendigo | 14
Road: 2011 Malvern Star Oppy C6
MTB: 2012 Giant Anthem X2
mattwilkinson
by BNA » Wed Dec 26, 2012 7:09 pm
Re: Widening Dropouts on Steel Frame
Postby Stepr » Wed Dec 26, 2012 7:09 pm
the LBS should be able to remove the old freehub and sell you a single speed freehub to go back on it. then there's no need to mess about re-spacing the rear, just need to sort out alignment with the front chainring.
Stepr
Postby RonK » Wed Dec 26, 2012 8:43 pm
Read Sheldon Brown on cold setting frame spacing.
Postby mattwilkinson » Wed Dec 26, 2012 9:08 pm
Do you reckon I could fit a 120mm wheel in there?
Would it be loose or would it be fine?
Matt | Bendigo | 14
mattwilkinson
Postby scratchman » Thu Dec 27, 2012 6:46 am
mattwilkinson wrote:Do you reckon I could fit a 120mm wheel in there?
sure, a couple of washers will make up the difference
I couldn't get the brakes on my bike to work so I got a really loud horn, crisis over!
scratchman
Postby mattwilkinson » Fri Dec 28, 2012 1:52 pm
Well i managed to fit a wheel on..
10 speed road bike wheel, 2 people pulling and someone to seat the wheel.
Lets hope I don't get a flat :P
Next question, Are all brakes generic? The brakes that came on it went through the slot with a nut on the other side.
Are all brakes like this?
Matt | Bendigo | 14
mattwilkinson
