Superbe pro replacement hoods
Postby dayne » Fri Dec 28, 2012 9:53 am
So I have been chasing hoods for my Llewellyn
It has superbe pro aero levers.
I have done a bit of googling but most threads are a few years old
My question is , Does any body know what modern hoods work well with these levers.
dayne
by Forum Ads » Fri Dec 28, 2012 10:10 am
Re: Superbe pro replacement hoods
Postby munga » Fri Dec 28, 2012 10:10 am
the $9 ones from ridgeways. take your lever and hood along and compare.
Postby bicyclepassion » Fri Dec 28, 2012 10:42 am
I presume you mean Superb Pro with exposed cables coming out the top, and gum hoods. These levers take the same hoods as 1970's and '80's Campagnolo Record and Super Record levers. And Modolo. The lever bodies are exactly the same shape.
The cheap hoods available now that fit on standard Dia Compe, early Shimano and Weinmann type bodies do not fit properly on Superbe Pro. I used up my remaining Superbe hoods on Campagnolo levers over the last few years. They were a better quality hood than the Campagnolo version.
Modolo hoods were the best qulaity, and I preferred them on all three brands, but I have not seen any of these available for a while now.
Repro Campagnolo gum hoods are available, and probably the easiest thing to get, that will fit properly.
Warren
bicyclepassion
Postby munga » Fri Dec 28, 2012 11:18 am
mms sent re: superbe pro aero hoods
Postby bicyclepassion » Fri Dec 28, 2012 11:32 am
Just re-read the original post, I obviously did not see the word 'aero' !
Apologies, and disregard everything I said about Campagnolo/Modolo compatibility etc.
Warren
bicyclepassion
Postby jbchybridrider » Fri Dec 28, 2012 12:58 pm
The last NOS gummy colored pair I saw on ebay "the only one's I've ever seen" were $100 not including postage and that was alot by it's self. I opted for brown colored DiCompe hoods, from memory around $15.
Last edited by jbchybridrider on Fri Dec 28, 2012 1:16 pm, edited 1 time in total.
jbchybridrider
Postby LG » Sat Dec 29, 2012 7:07 am
I'm running aero superbe pro levers with dia-compe hoods. The hoods came off a set of dia-compe levers and are slightly loose, but a reasonable fit. Not sure if new hoods will be a tighter fit. Perfectly functional if you want to run with this cheap option.
LG = Low Gear
LG
Postby spinner » Wed Jan 02, 2013 11:22 am
bicyclepassion wrote:I presume you mean Superb Pro with exposed cables coming out the top, and gum hoods. These levers take the same hoods as 1970's and '80's Campagnolo Record and Super Record levers. And Modolo. The lever bodies are exactly the same shape.
Warren
I'm on the lookout for some non-aero hoods, so thanks for that!! :D
spinner
Postby xerlex » Fri Jan 04, 2013 7:29 pm
Dayne, "Bikelane" hoods are a near perfect fit.
xerlex
Postby dayne » Mon Jan 07, 2013 7:43 pm
Thanks guys,
The ones from ridgeway cycles are the brick lane ones they fit pretty good
Way better than the dia compe ones I had.
dayne
Postby Rob74 » Tue Jan 22, 2013 12:32 am
+ 1 to Munga.
Great recommendation, they also fit "Suntour Sprint 9000 Aero Brake Levers" very well...very little difference to the originals, a good firm/snug fitting.
Ridgeway Cycles provided great service...hats off to Graham & Simon...rang up they sent me photos, rang back & ordered over the phone, they posted them to NSW.
BikeLane
Made in Taiwan
1546 Hoods for Aero type lever Black
$9.85 ea
Rob
Rob74
Users browsing this forum: Howzat
