Wondering if anyone can help me out and identify the frame below. I picked it up from a fellow cycling enthusiast and I am unsure whether its authentic.
The frame has Hillman decals and is very light, sporting a Reynolds 501 Double Butted sticker. The paint scheme I suspect is original; there is yellow overspray inside the head tube and areas where the colours merge are untouched. However, the bottom bracket and drop outs have been attacked with paint, likely from a spray can.
The frame measures 48cm seat tube with a 52cm top tube, which is meant to be unusual. The frame has two bolts positioned on the down tube, near the bottom bracket and feature V brake bosses. I've stripped paint from the bottom bracket and can't find a build number.
Before I send Hillman a email - is there anyone that can shed some light on the frame?
