Replacement Tyres for 28 x 1 3/8
Typhoon Ken
Postby Typhoon Ken » Sat Apr 20, 2013 6:44 am
G'day All,
Any thoughts on a suitable replacement for 28 x 1 3/8 tyres. I am restoring a Speedwell Super Club Racer and although I can source the correct tyres they are only in a block tread pattern which is not really in keeping with racing tyres so I was looking for a modern 700c x ? to suit. Tubes are ok I have some to suit with Woods Valves which are more in keeping with the era (circa 1940s).
Ken
Re: Replacement Tyres for 28 x 1 3/8
Postby ldrcycles » Sat Apr 20, 2013 6:57 am
While you could get a 700C tyre to match the overall size (something like 38mm or thereabouts), it wouldn't fit on the rim, going off the ISO or ETRTO numbers (which are a lot easier to understand) 700C uses a 622mm rim, while 28 x 1-3/8 is a 642mm rim.
How about getting the block tread tyres and doing a Burt Munro on them? :)
Typhoon Ken
Postby Typhoon Ken » Sat Apr 20, 2013 7:06 am
Yep I sort of knew as much, I have studied the ETRO chart, I have a couple of sets of the Block Treads so may I will Burt a set.
WyvernRH
Postby WyvernRH » Sat Apr 20, 2013 9:55 am
Typhoon Ken wrote:Yep I sort of knew as much, I have studied the ETRO chart, I have a couple of sets of the Block Treads so may I will Burt a set.
Hmm, while I must admit the block tread does not look good to modern eyes perusal of some road racing photos from the 20s-30's in Oz show the tyres used where not too much different. Roads were a lot worse back then!
Whatever, let us know how it goes if you do cut them down. I know Kid Carbine has done this but I reckon I would have to make up a jig to get tyre properly round and smooth.
Postby ldrcycles » Sat Apr 20, 2013 12:19 pm
Or if you wanted to get really brave/stupid, a belt sander... :)
Postby Clydesdale Scot » Sat Apr 20, 2013 8:05 pm
need one of these
WyvernRH
Postby WyvernRH » Sat Apr 20, 2013 9:32 pm
Clydesdale Scot wrote:need one of these
YES! That's what I was thinking of! having done a bit of motorcycle racing in the past I remember the tyre company reps cutting our 'rain' tyres with jigs like that (not quite so fancy but..)
Typhoon Ken
Postby Typhoon Ken » Sun Apr 21, 2013 6:27 am
That would be perfect but I might just have to settle on using the tyres as is with the block tread. As Richard pointed out they may be more period correct than I realised.
